IBM PC XT/370 Capacitor Replacement Guide
Revision as of 22:32, 23 May 2026 by Josh (talk | contribs) (Deep technical XT/370 + 3270 PC family page with verified sources (IBM SA38-0037-00 Service Info Manual, IBM GA33-3141-0, IBM 1502336, Kozuh/Livingston/Spillman IBM Systems Journal 1984, seasip.info, Wikipedia))
This guide documents capacitor diagnosis and replacement for the IBM PC XT/370. Because the XT/370 is mechanically an IBM PC XT (5160) chassis with three add-in 370PC cards, the capacitor topology is identical to a stock XT for chassis-level work — the canonical XT failure points (RIFA mains-suppression caps in the PSU and through-hole tantalum bypass caps on the planar) are the primary targets. The three 370PC cards each carry their own through-hole electrolytics that should be inspected separately.
Important Caveat
Per-board exact capacitor parts lists for the 370PC-P, 370PC-M, and PC3277-EM cards are not transcribed in any publicly accessible source that this guide author has located. The XT/370 cards are unique IBM products and their service documentation (SA38-0037-00 chapter 6) describes FRU-level replacement only — IBM expected service engineers to replace whole cards rather than re-component them. This guide therefore documents the typical late-1970s / early-1980s ISA card practice for capacitor recap; verify printed values on each cap before ordering replacements.
Safety Warning
The XT/370 uses the standard IBM 130 W switching PSU (Astec / Zenith) with mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any PSU work:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge each bulk capacitor through a 1 kΩ / 5 W resistor.
  4. Verify with a multimeter.
The integrated 5151 monochrome or 5153 CGA display (if a 5151-style cabinet is fitted) carries high voltage on the flyback transformer. Discharge the CRT anode to chassis ground via a high-voltage probe before any work on the deflection / flyback board.
Chassis-Level Capacitor Work
Identical to the IBM PC XT (5160) Capacitor Replacement Guide:
  • RIFA-branded X / Y class mains-suppression capacitors in the PSU. These are the canonical failure target on any IBM PC family system of this era — replace immediately as a preventive measure regardless of visible condition. They vent over time, producing smoke, a fishy odour, and on rare occasions a small fire.
  • PSU bulk filter electrolytics — 30+ years old; replace with 105 °C low-ESR equivalents.
  • PSU secondary-side electrolytics — same.
  • Planar through-hole tantalum bypass caps — diode-test each in-circuit; remove any showing close to 0 Ω.
For the full XT PSU and planar cap list refer to IBM PC XT (5160) Capacitor Replacement Guide.
370PC-P (Processor Card) Capacitors
The processor card carries the modified Motorola 68000 pair and the modified Intel 8087, plus glue logic. Typical capacitor types:
370PC-P card capacitor inspection (representative; verify in situ)
Value Voltage Type Position
10 µF 16 V Tantalum bypass Around the 68000 packages (multiple positions)
10 µF 16 V Tantalum bypass Around the modified 8087
47 µF 16 V Aluminium electrolytic Card-edge +5 V bulk filter
22 µF 16 V Tantalum bypass Glue-logic ICs
Failure mode of concern: tantalum short circuit. A shorted tantalum near the 68000 will pull down the +5 V rail and prevent the card from being detected by VM/PC. Diagnostic procedure:
  1. Multimeter on diode test.
  2. Probe each tantalum in-circuit: black to ground, red to +5 V rail.
  3. Good cap reads open / high resistance; shorted cap reads close to 0 Ω.
  4. Remove the shorted cap to confirm.
  5. Replace with a fresh tantalum or low-ESR ceramic of equal value, equal or higher voltage rating.
370PC-M (Memory Card) Capacitors
The 512 KB dual-ported memory card has more capacitance per board than the P card because of the DRAM array. Typical cap inventory:
370PC-M card capacitor inspection (representative)
Value Voltage Type Position Quantity (approx)
0.1 µF 25 V Ceramic decoupling One per DRAM (32 positions for 32-chip 512 KB) ~32
10–47 µF 16 V Tantalum or aluminium electrolytic Bulk DRAM array decoupling 4–6
100 µF 16 V Aluminium electrolytic Card-edge +5 V bulk 2
22 µF 16 V Tantalum bypass Glue-logic ICs 4–6
The per-DRAM ceramic caps rarely fail. The card-edge bulk caps and tantalum bypass caps are the more likely failure points after 40+ years.
PC3277-EM Card Capacitors
The 3277 Emulation Adapter is the smallest of the three cards and carries the BNC twinax interface to the host controller. Typical capacitor inventory:
PC3277-EM card capacitor inspection (representative)
10 µF 16 V Tantalum bypass IC bypass throughout
22 µF 16 V Tantalum bypass BNC interface circuit
Same as for any IBM PC era restoration:
  • Manufacturer: Panasonic FR / FM / FC, Nichicon HE / HZ (post-2007 date codes), Rubycon ZLH / ZLJ / YXJ, United Chemi-Con KZH / KZE.
  • Avoid generic Chinese-brand electrolytics.
  • 105 °C rated.
  • Voltage equal or higher than original.
  • Capacitance equal to original.
For tantalums:
  • Vishay 593D / 595D or KEMET T491 / T494 — modern high-reliability tantalum.
  • OR substitute with a low-ESR ceramic (X7R or X5R) of the same value — ceramics do not fail short and are a safer long-term choice for low-current bypass positions.
Recap Procedure
  1. Discharge the PSU bulk capacitors.
  2. Remove the chassis cover (5 rear screws, slide cover forward).
  3. Remove the three 370PC cards as a matched set — the backplane connector between 370PC-P and 370PC-M is sensitive; do not force.
  4. Photograph each card from both sides at high resolution.
  5. Mark each cap's polarity before desoldering.
  6. Desolder with solder wick. Limit each cycle to 5–7 seconds at no more than 350 °C.
  7. Fit replacements matching the silkscreen polarity.
  8. Solder both leads; inspect for clean fillets; trim flush.
  9. Reinsert cards as a matched set, ensuring the rear-edge backplane connector is fully seated.
Post-Recap Verification
  1. Power on with the original (uncapped) PSU first to verify chassis still POSTs cleanly.
  2. Once XT POST passes, reseat the three 370PC cards.
  3. Boot PC DOS 2.10.
  4. Load VM/PC.
  5. Verify VM/PC initialises the 370PC-P card (initialisation message).
  6. Verify VM/PC sees the 370PC-M card's full 512 KB (initialisation message).
  7. Connect to host mainframe; verify CMS prompt appears.
If any test fails after recap, re-inspect the polarity of every replaced cap before suspecting another fault.
Polarity Reference
Polarity reference for IBM motherboard and add-in card tantalum capacitors. Match the silkscreen "+" to the cap "+" side. (Image: minuszerodegrees.net)
When Not to Recap
If the XT/370 POSTs cleanly, DOS boots, VM/PC initialises the cards, host connection succeeds and CMS runs reliably with no instability, the caps are within tolerance.
Always recap if:
  • RIFA-branded X / Y mains-suppression cap present in the PSU (preventive replacement).
  • Visible cap failure on the planar, any 370PC card, or the PSU.
  • PSU smoke, fishy odour or audible whine.
  • System unstable when warm but stable when cold.
  • 370PC card fails to be detected by VM/PC and reseating did not help (suspect a shorted tantalum on the card).
