Macintosh Centris 650 Troubleshooting
Revision as of 13:21, 16 July 2026 by Josh (talk | contribs) (Deep dive: SMD cap leakage signatures, PRAM battery, analog/sound specifics, chime/Sad Mac; cited)
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh Centris 650 (and Quadra 650). This guide covers the most common problems encountered with these systems.
Note: The Centris 650 and Quadra 650 share the same hardware, so this guide applies to both models.
Before detailed troubleshooting, verify:
  • Power cable is securely connected
  • Wall outlet is functional (test with another device)
  • Power switch on the rear is in the ON position
  • No visible damage to the power cord
Expected Voltages
Rail Expected Range
+5V 4.85V – 5.15V
+12V 11.9V – 12.7V
-12V -11.9V – -12.7V
No Power (Unit Dead)
Macintosh Centris 650. Source: Wikimedia Commons.
No response when power button pressed Dead power supply Test PSU voltages; check/replace PSU capacitors
No response Failed PRAM battery Replace 3.6V lithium battery
No response Shorted tantalum capacitor Inspect logic board for burn marks; replace failed cap
Clicking sound from PSU PSU overload protection triggering Disconnect all drives and cards; test bare system
PSU fan spins briefly then stops PSU capacitor failure Recap power supply
Burning smell Component failure Immediately unplug; inspect for burnt components
Power Supply Troubleshooting
The Centris/Quadra 650 power supply contains electrolytic capacitors that degrade over time. Common failures include:
  • Bulging or leaking capacitors
  • Dry joints on high-current connections
  • Failed rectifier diodes
Warning: Discharge the power supply before servicing. High-voltage capacitors can retain charge.
Startup Chime but No Video
Chime with No Display
Chime, no video on internal video VRAM issue Reseat or replace VRAM SIMMs
Chime, no video Monitor not connected properly Check video cable and adapter
Chime, no video Monitor settings Try different resolution sense pins
Chime, no video Logic board video failure Test with NuBus video card
Video Resolution Sense Pins
The Centris/Quadra 650 detects monitor resolution via sense pins on the DB-15 video connector. If using a modern monitor with an adapter, ensure proper sense pin configuration for your desired resolution.
No Startup Chime
No Chime Diagnostics
Power light on, no chime RAM failure Reseat SIMMs; test with known good RAM
Power light on, no chime ROM SIMM issue Reseat ROM SIMM
Power light on, no chime Logic board failure Test with minimal configuration
No power light, no chime Power supply failure Test PSU; recap if needed
Sad Mac Error Codes
If the system displays a Sad Mac icon with an error code, see the Sad Mac Error Codes page for a full list.
Common codes for the Centris/Quadra 650:
Code Meaning
0000000F ROM checksum failure
000000XX (01-05) RAM test failure (bank indicated by XX)
0000000E ROM SIMM error
Stability Issues
Random freezes Overheating Clean dust; verify fan operation
Random freezes Bad RAM Run memory diagnostic; test SIMMs individually
Random freezes Failing hard drive Back up data; replace drive or use BlueSCSI
Freeze during disk access SCSI termination issue Verify termination at end of chain
Crashes after warmup Thermal issue Check thermal compound; verify cooling
Intermittent boot Oxidized contacts Clean SIMM slots and card slots with DeoxIT
SCSI Issues
SCSI Troubleshooting
Drive not recognized SCSI ID conflict Ensure unique IDs (0-6) for all devices
Drive not recognized Bad SCSI cable Replace internal SCSI ribbon cable
System hangs at startup Missing termination Add terminator to last device in chain
Intermittent disk errors Loose connection Reseat SCSI cables
Blinking question mark No bootable system Install System software; check drive
SCSI ID Notes:
  • Internal drives typically use ID 0
  • CD-ROM often uses ID 3
  • External devices: ID 1-6
  • Host adapter is always ID 7
  • Termination required at the end of the chain
Floppy Drive Issues
Floppy Drive Problems
Won't read disks Dirty heads Clean heads with cleaning disk
Won't eject Mechanical failure Manual eject with paperclip; service drive
Disks unreadable Worn drive heads Replace floppy drive
Grinding noise Dried lubricant Lubricate drive mechanism
Ethernet Issues (AAUI)
Some Centris 650 configurations include onboard Ethernet via AAUI-15 connector.
No network connection Missing transceiver Connect AAUI-to-10BaseT transceiver
Intermittent connection Bad transceiver Replace AAUI transceiver
No Ethernet option No onboard Ethernet Install NuBus Ethernet card
NuBus Card Issues
Card not recognized Poor seating Reseat card firmly
Card not recognized Slot failure Try different NuBus slot
System won't boot with card Card conflict Remove card; test system; reinstall
Intermittent issues Oxidized contacts Clean card edge connector
The Centris 650 carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
Unlike the LC and Mac II surface-mount-electrolytic boards, the 68040-family Centris 650 logic board uses tantalum capacitors, which do not leak with age — the logic board does not normally need recapping. If the board misbehaves, look to leaked-PRAM-battery corrosion, socket/connector contacts and the power supply rather than to board capacitors.[2]
  1. "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
  2. "Apple Macintosh Quadra 650", Retro Viator; and the Apple Macintosh Quadra/Centris 650 Service Source. Source for the 68040-family logic boards using tantalum capacitors (no logic-board recap needed) while the power supply uses electrolytics that do need replacing.
  3. "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
Surface-mount capacitor leakage
The Macintosh Centris 650 logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Macintosh Centris 650 backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
  1. Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
  2. Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
