Macintosh LC III+ Troubleshooting
Revision as of 13:21, 16 July 2026 by Josh (talk | contribs) (Deep dive: SMD cap leakage signatures, PRAM battery, analog/sound specifics, chime/Sad Mac; cited)
Macintosh LC III+. Source: Wikimedia Commons.
This guide covers common issues and diagnostic procedures for the Macintosh LC III+.
Preliminary Checks
  • Power cable is securely connected.
  • Monitor cable is properly attached.
  • Keyboard and mouse are connected to ADB port.
  • No external SCSI devices are causing conflicts.
No Power
No Power Diagnostics
Symptom Possible Cause Action
Completely dead, no fan Power supply failure Check power supply capacitors; test with known-good PSU
Clicks or ticks repeatedly Short circuit or capacitor failure Inspect logic board for leaked capacitors; check for shorts
Fan spins briefly, then stops Thermal protection or PSU fault Check PSU output voltages; inspect for overheating
LED on but no startup Logic board issue Reset PRAM (Cmd+Opt+P+R); inspect for capacitor damage
Power Supply Voltages
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
Chimes but No Video
Chime But No Video
Normal chime, black screen VRAM failure or video circuit issue Reseat VRAM SIMM; test with different monitor
Chime with garbage display VRAM or logic board damage Check VRAM; inspect for capacitor leakage
Distorted or shifted image Video timing issue Check video output connector; try different monitor cable
Startup Chime Errors
Error Chime Codes
Chime Pattern Meaning Action
No chime CPU or ROM failure Inspect logic board
Single tone (not normal chime) RAM failure Reseat 72-pin SIMM; test with different SIMM
Four tones (ascending) RAM failure Replace RAM SIMM
Sad Mac Errors
Sad Mac Error Codes
Code Meaning Action
0000000F / 00000001 ROM test failure ROM or logic board problem
0000000F / 00000002 Memory test failure Check RAM SIMM
0000000F / 00000003 Memory addressing error Reseat or replace RAM
Intermittent Operation
Intermittent Issues
Random freezes Capacitor failure or bad RAM Recap logic board; test RAM
Works when cold, fails when warm Thermal-related component failure Inspect capacitors; check solder joints
Spontaneous restarts Power supply instability Check PSU capacitors and output voltages
SCSI Problems
SCSI Troubleshooting
Hard drive not recognized SCSI ID conflict or cable issue Check SCSI ID (drive should be ID 0); reseat cables
Flashing question mark No bootable system found Boot from floppy; check hard drive
External devices not detected Termination or ID issue Verify termination; check all SCSI IDs are unique
Floppy Drive Issues
Floppy Drive Problems
Disk not ejecting Mechanical jam or failed eject motor Manually eject with paperclip
Cannot read disks Dirty heads or misalignment Clean heads with IPA
Disks not recognized Drive failure or controller issue Test with known-good drive
FPU Issues
If you have installed an optional 68882 FPU:
FPU Problems
FPU not detected Poor socket contact Reseat FPU; check for bent pins
System unstable after FPU install Wrong FPU speed Use 33 MHz or faster 68882
Crashes in FPU-intensive apps Defective FPU Test with different 68882
Audio Issues
Audio Problems
No sound output Capacitor failure in audio circuit Recap logic board
Distorted audio Failing capacitors Replace capacitors
Crackling or popping Bad solder joints or capacitors Reflow solder joints; replace capacitors
The Macintosh LC III+ uses a 3.6 V 1/2AA lithium PRAM battery (often a red Maxell). These are notorious for leaking and even exploding, spraying corrosive electrolyte across the logic board — a battery can burst while the machine sits in storage and destroy the board. Remove the PRAM battery from any un-serviced unit immediately. If one has leaked, neutralise and clean the residue and check the traces and vias around the battery and the nearby chips for corrosion, repairing any that are damaged.[1]
⚠️ Surface-mount capacitor leakage
The Macintosh LC III+ logic board uses surface-mount electrolytic capacitors that leak electrolyte from the bottom with age. The leakage corrodes traces and vias and is a leading cause of faults, so recap and clean the board as a first step. A common pattern is a board that chimes but shows no video after servicing — usually corrosion damage (broken traces or vias) around the leaked capacitors (for example near C136/C137), which must be traced and repaired.[2]
The compact LC "pizza-box" power supply also uses electrolytics that leak with age. A dead LC PSU can usually be revived by replacing all its electrolytic capacitors and cleaning the leakage; any working LC PSU should be recapped pre-emptively, as it will otherwise fail. Confirm the +5 V and +12 V rails after servicing.[2]
  1. 1.0 1.1 "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and "Mac Battery Leaks", MacDat. Source for the exploding/leaking Maxell PRAM battery and the resulting board damage, and the LC not booting without a battery.
  2. 2.0 2.1 "Quadra 605 / LC 475", Quagmire Repair; the Apple Macintosh LC/LC II/LC III/LC 475/Quadra 605 Service Source; and "Macintosh LC Recap", PAPPP's Rambling. Source for the SMD-capacitor leakage, the PSU recap, and the trace/via damage causing chime-but-no-video.
The Macintosh LC III+ logic board uses surface-mount electrolytic capacitors whose electrolyte turns corrosive with age and creeps across the board, eating through traces, pads and IC pins. Typical signatures are a machine that will not chime, chimes but shows no video, plays distorted or missing audio, or shows a garbled or checkerboard screen. Wash the affected area and replace every electrolytic with a tantalum or polymer part, then repair any lifted traces. The switch-mode power supply (ASTEC or TDK on the LC-family machines) holds its own electrolytics and fails the same way, so recap it alongside the board.[1]
PRAM battery
The Macintosh LC III+ backs up its clock and Parameter RAM from a 3.6 V ½AA lithium cell. These cells — red Maxell parts especially — leak or burst and corrode the board, so remove an aged one on sight. A flat cell can also stop a soft-power machine booting or disturb the video; left plugged in, trickle power preserves the settings, but a machine switched off at the wall with a dead cell loses them. Clean the area and fit a fresh 3.6 V cell.[2]
Boot chime and Sad Mac
  1. Mac84, Macintosh LC series power-supply recapping guide; the MacCaps capacitor reference; and iFixit. Source for surface-mount electrolytic leakage eating traces, pads and pins, the ASTEC/TDK LC power-supply cap failures, and Apple's use of tantalum (non-leaking) capacitors on the Quadra 700/900 logic boards.
  2. Warning! Exploding Maxell PRAM batteries, 68kMLA; and Mac Battery Leaks, MacDat. Source for the 3.6 V ½AA lithium PRAM cell, the Maxell leak/explosion board damage, and soft- versus hard-power PRAM retention.
