Macintosh SE/30 Troubleshooting
Revision as of 17:51, 4 April 2025 by Josh (talk | contribs)
This guide provides solutions to common faults experienced in the Macintosh SE/30. From power issues to Simasimac patterns and SCSI failures, these diagnostics will help identify, isolate, and resolve problems.
๐Ÿ”Œ Preliminary Checks and Power Supply Basics
Begin by verifying the analog board delivers proper voltages:
  • +5V rail: 4.90V โ€“ 5.10V
  • +12V rail: Confirmed at floppy or hard drive connectors
If the unit is completely dead (no fan, CRT glow, or chime), inspect:
  • Fuses
  • Rectifiers CR2 and CR3
  • Transistor Q2
  • Resistor R22
Also:
  • Disconnect external peripherals and cards
  • Check logic board for PRAM battery corrosion
  • Replace all electrolytic capacitors on the logic board
๐Ÿ“บ "Simasimac" โ€“ Horizontal Stripe Pattern
Macintosh SE/30 Simasimac pattern
The infamous "Simasimac" pattern shows horizontal black-and-white lines with no startup chime. Causes include:
  • Leaking capacitors disrupting the reset circuit
  • Corroded traces or vias near RAM/ROM
Solutions:
  • Clean and reseat ROM and RAM SIMMs
  • Replace PRAM battery if < 3V
  • Check for reset pulse at CPU
  • Test for 16 MHz clock at CPU
  • Inspect Apple Sound Chip (ASC) at UB11 and filter RP2
  • Use multimeter or oscilloscope to confirm continuity
๐Ÿ’€ Chimes of Death and Sad Mac Codes
The Chimes of Death signify early boot failureโ€”commonly RAM or ROM faults.
Checklist:
  • Use 4 matched SIMMs per bank
  • Larger-capacity SIMMs go in Bank A
  • Clean/reseat ROM SIMM
  • Check address/data continuity near capacitors
  • Replace 74F258 multiplexers or RAM if needed
  • Check VIA chips for overheating or corrosion
See: Sad Mac Error Codes for detailed interpretation.
๐Ÿ–ฅ๏ธ Video Display Issues
๐Ÿ”‡ No Video but Chime Present
  • Verify brightness knob
  • Confirm CRT glow
  • Check UE8 (video multiplexer)
  • Probe video/sync signals at P1 connector
๐Ÿ“ถ Vertical "Jailbar" Stripes
  • Indicates incorrect RAM configuration
  • Use identical SIMMs per bank (larger ones in Bank A)
๐Ÿงฉ Checkerboard Pattern
Checkerboard error screen
  • Typically a ROM failure
  • Clean/reseat the ROM SIMM
  • Confirm compatibility (use SE/30 or IIsi ROMs only)
๐Ÿ’พ Disk Drive and SCSI Issues
โ„๏ธ Frozen Mouse on Gray Screen
  • Possible failure of SCSI controller (NCR 53C80)
  • Disconnect all internal/external SCSI devices
  • Inspect and replace termination resistors
๐Ÿฅ Floppy Drive Issues
  • Dirty mechanism
  • Faulty SWIM controller
  • Cold solder joints on VIA or SWIM ICs
For more, see:
๐Ÿ”Š Audio and ADB Issues
๐Ÿ”‡ No Sound
  • Test audio at the headphone jack
  • Inspect ASC (Apple Sound Chip)
  • Inspect analog board audio amplifier
โŒจ๏ธ ADB Malfunction
  • Blown fuse F1
  • Failed ADB microcontroller (Egret)
  • VIA chip solder cracks or corrosion
โฑ๏ธ Reset and Clock Problems
  • Random resets: Check power rail stability
  • No time retention: Dead PRAM battery or failed 32.768 kHz crystal
  • Check surrounding electrolyte residue near Egret or VIA chips
โšก Brief Analog Board Troubleshooting
  • Vertical line only: Horizontal deflection fault โ€“ reflow P1 connector and replace C15
  • Horizontal line only: Vertical deflection fault โ€“ reflow P1 and replace TDA1170A
  • Wavy or distorted video: Failing flyback transformer
  • PSU clicking repeatedly: Shorted logic board or failed CR2, CR3, Q2, or R22
