Macintosh LC II Capacitor Replacement Guide
Revision as of 21:52, 21 September 2026 by Josh (talk | contribs) (Verification drive: flag unverified component data pending check against a primary source)
Replacing the electrolytic capacitors (recapping) in the Macintosh LC II is essential for long-term reliability. The original capacitors used in these machines are now over 30 years old and commonly leak, causing corrosion and circuit damage.
Symptoms of Capacitor Failure
  • No audio — Most common early symptom
  • Distorted or crackling audio
  • Boot failures or instability
  • Visible electrolyte leakage — Brown or black residue around capacitors
  • Corrosion on PCB traces
Capacitor List
Logic Board Capacitors
The Macintosh LC II logic board contains 17 surface-mount electrolytic capacitors, identical in specification to the original LC.
Macintosh LC II Logic Board Capacitors
Designator Capacitance Voltage Type
C1 1 µF 50V SMD Electrolytic
C2 1 µF 50V SMD Electrolytic
C3 10 µF 16V SMD Electrolytic
C4 10 µF 16V SMD Electrolytic
C5 10 µF 16V SMD Electrolytic
C6 10 µF 16V SMD Electrolytic
C7 47 µF 16V SMD Electrolytic
C8 47 µF 16V SMD Electrolytic
C9 47 µF 16V SMD Electrolytic
C10 47 µF 16V SMD Electrolytic
C11 47 µF 16V SMD Electrolytic
C12 47 µF 16V SMD Electrolytic
C13 47 µF 16V SMD Electrolytic
C14 47 µF 16V SMD Electrolytic
C15 100 µF 6.3V SMD Electrolytic
C16 100 µF 6.3V SMD Electrolytic
C17 100 µF 6.3V SMD Electrolytic
Macintosh LC II logic board capacitor locations. Source: Recap-a-Mac
Power Supply Capacitors
The LC II uses the same power supply as the original LC. Refer to the Macintosh LC Power Supply Recap Guide for PSU-specific information.
Macintosh LC power supply capacitor locations. Source: Recap-a-Mac
Tools Required
  • Temperature-controlled soldering iron (recommended: 300-350°C)
  • Fine tip for SMD work
  • Desoldering braid or solder wick
  • Flux (no-clean recommended)
  • Isopropyl alcohol (99%)
  • Soft brush (ESD-safe)
  • Multimeter
  • Replacement SMD electrolytic capacitors
Procedure
  1. Remove the logic board — Disconnect all cables, remove screws, and carefully lift the board.
  2. Document capacitor positions — Note polarity markings before removal.
  3. Clean the area — Remove any leaked electrolyte with isopropyl alcohol.
  4. Remove old capacitors — Heat one pad while gently lifting the capacitor. Alternate between pads. Use flux to help solder flow.
  5. Clean the pads — Remove old solder with desoldering braid. Clean with IPA.
  6. Inspect for damage — Check traces and vias for corrosion. Repair any damaged traces.
  7. Install new capacitors — Observe polarity. The stripe on the capacitor indicates negative. Tin one pad, position capacitor, solder second pad, reflow first pad.
  8. Clean residue — Remove flux with isopropyl alcohol.
  9. Test continuity — Verify no shorts between +5V, +12V, and ground.
  10. Reassemble and test — Listen for the startup chime, verify video, and check audio output.
Important Notes
  • Polarity matters — SMD electrolytics will fail if installed backwards.
  • Use equivalent or better specs — Match capacitance; voltage rating can be equal or higher.
  • Low-ESR capacitors — Modern low-ESR replacements are acceptable.
  • No FPU socket — Note that the LC II does not have an FPU socket on the logic board, despite the 68030's FPU support.
External Resources
