Atari Stacy Schematics and Drawing Package
Revision as of 23:51, 22 September 2026 by Josh (talk | contribs) (Documentation page for newly hosted Atari STacy drawing package)
Atari's engineering drawing set for the Atari Stacy, which Atari referred to internally as the LST (Laptop ST). Forty-nine sheets, 1989โ€“1990.
The most useful parts for a repairer are the bills of material. CA200464-XXX ASSY PCB LST, sheets 1โ€“9 lists every component on the Stacy main board with its reference designator, description and Atari part number โ€” including all nine electrolytic capacitors (all of them 16 V), the 41 ceramic decoupling capacitors that occupy the low-numbered designators, the sockets, and the 3 V 560 mAh lithium clock battery at location LB. CA200528-XXX ASSY SUB PCB LST-4 does the same for the sub board. The set also contains the LED board assembly CA200478, the drive mounting assemblies CA200470, the approved-vendor drawing C103641 for the 1 M ร— 1 CMOS ZIP DRAM used in the machine, the main-board circuit diagrams, the power board schematic, which specifies a DC input of 11โ€“18 V, and the LCD interface and low-battery sheets.
Download the Atari Stacy Schematics and Drawing Package here: File:Atari Stacy Schematics and Drawing Package.pdf
