Amstrad PC 2640 Service Manual
Revision as of 23:17, 24 September 2026 by Josh (talk | contribs) (Corrected a vague and partly wrong description: the document is a Schneider (German) Kundendienst-Handbuch, Ident-Nr. 36523, for an 80286 machine with a C&T 82C201/202/206 chipset - not simply 'the workstation variant of the PC2000 series'. Listed the real contents (CPU, Multi I/O and slot board schematics, jumper/DIP defaults) and recorded the significant gap that the parts lists contain no capacitors and no component values at all)
The document held under this title is a Schneider service manual, not an Amstrad-branded one: "Kundendienst-Handbuch / Service Manual, PERSONAL COMPUTER PC 2640, Ident-Nr.: 36523". 42 pages, German with English column headings throughout, and a text layer. The last page is a Schneider Service-Information notice, number 884433.
Schneider distributed Amstrad's machines in German-speaking Europe and later built its own; the PC 2640 is documented here in Schneider's house style, with order numbers and price groups rather than component values.
Contents
  • Exploded view; spare parts list for the PC 2640 (bilingual: Bezeichnung / Description, Zeichen-Pos. / Ref.-No., Best.-Nr. / Part-No., Preisgruppe)
  • Exploded view โ€” keyboard
  • Wiring diagrams
  • LED board schematic diagram and component location
  • CPU board: parts list, block diagram, component side, soldering side, and seven pages of schematic diagrams
  • Multi I/O board: parts list, component side, soldering side, block diagram, and thirteen pages of schematic diagrams
  • Slot board: parts list, component side and soldering side
  • Jumper and DIP switch default settings for the Multi I/O and CPU boards
  • Ordering note and the Schneider service bulletin
What it settles
  • The PC 2640 is an 80286 machine. The CPU board parts list gives U63 as an 80286-12, with 41256-12 DRAMs at U1–U9 and U12–U20, 4164-12 DRAMs at U23–U31 and U33–U41, an 80C42C keyboard controller at U32, 27128-15 EPROMs at U44 and U45, and a Chips and Technologies chipset โ€” 82C201 (U56), 82C202 (U49), 82A203.12 (U51), 82A204 (U64), 82A205.12 (U53) and 82C206 (U50) โ€” plus a PAL20R6 at U54.
  • Crystals are listed with frequencies: 32.768 kHz and 14.318 MHz on one board, 15 MHz and 10 MHz on the other.
  • The jumper and DIP switch page gives Schneider's factory default settings for both boards โ€” the fastest way to recover a machine somebody has reconfigured.
  • Schneider's own service policy, printed on the last page: in the event of a fault, return the complete system unit or the complete board set (CPU, Multi I/O, SLOT).
  • No capacitors and no component values. This is the important limitation. The parts lists cover ICs, resistor networks (by designator, not by value), crystals, connectors, cables, mechanical parts and assemblies โ€” and not one capacitor appears in any of them. Values for passives must be read off the schematics or the board.
  • No power supply data. The supply is a single line item, "Netzteil / Power supply".
  • No alignment, adjustment or fault-finding procedures and no diagnostic flowchart.
  • No monitor coverage.
  • Prices are given as price-group letters, not figures, so the list carries no cost information.
Download here: Amstrad PC 2640 Service Manual.pdf
