IBM ThinkPad X30 X31 Service Manual
Revision as of 00:17, 25 September 2026 by Josh (talk | contribs) (P4 verification: real documentation page - title as printed, part/form number, edition, contents, honest gaps, what it settles, cross-links)
IBM Mobile Systems — ThinkPad Computer Hardware Maintenance Manual, January 2003, part number 92P1288, First Edition. 176 pages.
It supports ThinkPad X30 and X31 (MT 2672/2673), the ThinkPad Dock (MT 2631) and the ThinkPad Dock II (MT 2877).
What it contains
IBM's ThinkPad hardware maintenance manuals all follow the same plan, and knowing it saves hunting:
  • About this manual and Introduction — the strategy for replacing FRUs (reinstall the original part if the replacement does not fix the fault; if a machine has both a processor board and a system board, put the first one back before trying the second; remove multi-FRU assemblies one part at a time), how to use error messages, and the diskette compatibility matrix.
  • Safety information — general and electrical safety, the safety inspection guide, ESD handling, grounding requirements and the laser compliance statement, with the safety notices repeated in every supported language.
  • General descriptions and Related service information — restoring the preloaded system, passwords (including what can and cannot be cleared), and power management.
  • Checkout guide — testing the computer, detecting system information with PC-Doctor, and the power system checkout: checking the AC adapter, operational charging, the main battery pack and the backup battery, each with its own measurement.
  • Product overview — specifications, status indicators, FRU tests and the Fn key combinations.
  • Symptom-to-FRU index — numeric error codes, error messages, beep symptoms, LCD-related symptoms, intermittent problems and undetermined problems.
  • FRU replacement notices — the screw notices (torque and thread-lock rules, which matter on magnesium frames) and retaining serial numbers.
  • Removing and replacing a FRU — the numbered 10xx sequence, which must be followed in order because later steps assume earlier ones.
  • Locations — front, rear and bottom views by machine type.
  • Parts list — FRU part numbers, including the keyboard and LCD part numbers by country and panel supplier.
What it does not contain
Module level, and firmly so. These manuals name FRU part numbers, not component values. Across a typical ThinkPad maintenance manual the word "capacitor" appears once, in the ESD handling note. There is no schematic, no board layout, no parts list below FRU level and no component data of any kind. A system board is one line item with one part number.
That is IBM's service model, not a gap in the scan, and it is why no ThinkPad on this wiki has a component-level capacitor list. If you need a board-level repair on a ThinkPad, this manual will tell you which board and how to get it out; it will not tell you what is on it.
What it settles
This is the IBM-era X30/X31 manual. The later IBM ThinkPad X30 X31 X32 Hardware Maintenance Manual (July 2005, part number 39T6189) is a Lenovo publication that adds the X32 and machine types 2884 and 2885. For an X30 or X31 either will serve; for an X32 you need the later one.
Download it here: IBM ThinkPad X30 X31 Service Manual.pdf
