Schematic 320026 (Sheet 3 of 3, Board 320008)
Revision as of 02:05, 25 September 2026 by Josh (talk | contribs) (P4 verification: real documentation page โ€” identifies the sheet from its own title block, records that sheet 1 of every set is drawing 320130, and links the parts lists and display-assembly documents)
Commodore drawing #320026, sheet 3 of 3, titled PET Computer Main Logic โ€” Video Logic and subtitled "pertaining to board assembly #320008". Commodore Business Machines, Inc., Palo Alto, California.
This is the character generator, video timing and display output of the static Commodore PET 2001 board fitted with 6540 ROMs and 6550 RAM. It is the video half of what distinguishes the four original board assemblies from one another โ€” sheet 1 of every set is the same universal drawing, Schematic 320130 (Sheet 1 of 3, Static PET).
Commodore's note is printed on sheets 2 and 3 of every set: "All locations are same on all boards; only the specific components will differ on boards numbered 320132, 320081, 320137, 320008. The identifying board number is in upper left corner." So a component location read off one of these drawings is valid for any static PET 2001 board; only the fitted part changes.
Board assembly ROMs RAM Drawing number for sheets 2โ€“3
320008 6540 6550 320026
320081 2316B 6550 320082
320132 6540 2114 320130
320137 2316B 2114 320135
Circuits marked with an asterisk on this sheet are annotated "all ckts marked * are for BC machine only" โ€” the business-keyboard variant.
This drawing carries no parts list. For component values and Commodore part numbers see System Board Parts List (1 of 3); for the machine's power supply and monitor, which are a separate assembly entirely, see Video Board Schematic.
The same sheet is page 3 of the complete set at Schematic 320026 (Complete, Board 320008), which is the better link to cite if you want all three sheets together. This page holds the higher-resolution scan of this sheet on its own.
Commodore drawing 320026, sheet 3 of 3 โ€” PET Computer Main Logic, Video Logic, board assembly 320008.
Download: 320008-3.gif
