Apple Color Plus 14 Service Source
Revision as of 07:36, 25 September 2026 by Josh (talk | contribs) (P4: turn document holder into a real documentation page (verification drive))
The Apple Color Plus 14" Display volume of Apple's Service Source is an 8-page service document for the Apple Color Plus 14-inch display. The PDF was distilled on 14 November 1995.
Specifications as printed
Item Value
Picture tube 14 in diagonal, 11.9 in viewable; 0.28 mm dot pitch
Screen resolution 640 x 480, 68 nominal dpi
Scan rates vertical refresh 67 Hz; horizontal 31.5 kHz
Mains domestic 100-125 VAC; international 220-240 VAC; 50-60 Hz
Power 70 W
Size / weight 14.1 in (328 mm) H x 14.7 in (368 mm) W x 15.4 in (385 mm) D; 25.3 lb (11.5 kg)
User controls front panel: power switch, brightness and contrast
The 31.5 kHz horizontal rate at 67 Hz vertical is the giveaway that this is a fixed-frequency 640 x 480 monitor and will not sync to a machine set to 832 x 624.
Contents
  • Specifications - Characteristics, Controls, Physical and Electrical, Operating Environment (pdf pp. 3-6)
  • Troubleshooting - "Before Replacing the Unit . . ." (pdf pp. 7-8)
Almost everything. There is no Take Apart, no Adjustments, no Exploded View and no symptom chart. The entire Troubleshooting chapter is a single page headed "Before Replacing the Unit . . .", because Apple's repair strategy for this display was whole-unit exchange. No parts list, no schematic, no component values, no fuse rating, no rail figures. A reader intending to recap or realign one of these gets nothing from this document except the scan rates and the two mains ranges.
A note on duplication
This page and Apple Color Plus 14 Display Service Source embed the same file, Color plus 14 display.pdf. There is one Color Plus 14 Service Source volume on this wiki, not two.
Pages that cite this document
A CRT display holds a lethal charge on the anode after the mains is removed. Follow CRT Discharge Procedure before working inside one.
Download: Color plus 14 display.pdf
