Macintosh Service Source
Revision as of 08:28, 25 September 2026 by Josh (talk | contribs) (P4 verification: turn document holder into a real documentation page (contents with PDF page numbers, Apple's own specifications, honest gaps, citing pages))
The Macintosh volume of Apple's Service Source is a 79-page service manual covering the original Macintosh 128K and 512K (Apple's cover carries no model numbers at all — the volume is titled simply Macintosh). The PDF was distilled on 15 December 1995.
This page and Macintosh 128K/512K Service Source embed the same file. The fuller treatment of the manual — including Apple's Adjustments → Voltage procedure verbatim — is on that page; this page records the manual under the title Apple actually printed on it.
Service Source volumes are module-level documents. They give Apple's own specifications, symptom charts, take-apart procedures and module part numbers, but they do not carry schematics, board-level parts lists or component values, so they cannot be used to source a capacitor table. Where a figure below is quoted, it is quoted as Apple printed it.
Specifications as Apple prints them
Item As printed
CPU Motorola 68000 at 7.83 MHz
Line voltage 105–125 VAC (no 220–240 V figure is printed)
Maximum power 60 W
PRAM cell 4.5 V, user-replaceable
Contents
Reconstructed from the manual's own running headers; page numbers are positions in the PDF, so a citation can be checked directly.
  • Basics — Overview (pdf p. 3)
  • Specifications — Processor (pdf p. 5), Memory (pdf p. 6), Disk Storage (pdf p. 7), I/O Interfaces (pdf p. 8), I/O Devices (pdf p. 9), Sound and Video (pdf p. 10), Electrical (pdf p. 11), Physical (pdf p. 12)
  • Troubleshooting — General (pdf p. 14), Symptom Charts (pdf p. 15)
  • Take Apart — Cover (pdf p. 24), Power/Sweep Board (pdf p. 28), Logic Board (pdf p. 32), CRT (pdf p. 36), Floppy Drive (pdf p. 39), Chassis (pdf p. 42)
  • Upgrades — Floppy Drive Upgrade Kit (pdf p. 45), Logic Board Upgrade Kit (pdf p. 51), 400K Drive ROM Upgrade (pdf p. 56)
  • Adjustments — Voltage (pdf p. 61), Yoke (pdf p. 67), Tilt Adjustment (pdf p. 69), Video (pdf p. 74)
  • No parts list, no schematic, no component values.
  • Only the 105–125 V machine is specified; the 220–240 V board is not covered.
Pages that cite this document
This machine contains a high-vacuum picture tube and a live analogue board. Follow CRT Discharge Procedure before working inside one.
Download: Macintosh_128k.512k.pdf (585 KB)
