Macintosh LC II
Revision as of 12:25, 27 September 2026 by Josh (talk | contribs) (Verify against Apple's Macintosh LC Series/Quadra 605 Service Source (hosted): sound is monophonic in and out, not stereo; corrected dimensions; added Apple's ROM, VRAM, 96-pin PDS, 50 W maximum power, line voltage and replace-below-3.0 V battery figures)
Macintosh LC II
Macintosh LC II
TypePersonal Computer
ReleasedMarch 23, 1992
DiscontinuedMarch 15, 1993
Intro priceUS$1,699
CPUMotorola 68030 @ 16 MHz
Memory4 MB RAM (expandable to 10 MB)
Storage40 MB, 80 MB, or 160 MB SCSI HDD, 1.44 MB SuperDrive
Display512ร—384 (8-bit) or 640ร—480 (8-bit with 512K VRAM)
Sound8-bit monophonic sound input and output (Apple's figure)
Dimensions3.0" H ร— 12.2" W ร— 15.0" D (7.7 ร— 31.0 ร— 38.2 cm)
Weight8.8 lbs (4.0 kg)
OS / FirmwareSystem 6.0.8 โ€“ System 7.6.1
PredecessorMacintosh LC
SuccessorMacintosh LC III
CodenameFoster Farms
Model no.M1700
The Macintosh LC II is a personal computer released by Apple on March 23, 1992, as a direct replacement for the original Macintosh LC.[1] The LC II upgraded the processor to a Motorola 68030, adding a PMMU (Paged Memory Management Unit) for virtual memory support while maintaining price parity with the original LC's launch price.[2]
Model Variants
The LC II was sold under several Performa brand names for consumer markets:
  • Performa 400 โ€” Base configuration
  • Performa 405 โ€” With 4 MB RAM and 80 MB hard drive
  • Performa 410 โ€” With 4 MB RAM and 80 MB hard drive (different bundle)
  • Performa 430 โ€” With 4 MB RAM and 120 MB hard drive
All variants use the same logic board and hardware.
The LC II uses a Motorola 68030 processor running at 16 MHz. Despite the upgraded processor, the LC II retains the 16-bit memory bus from the original LC, which limits memory bandwidth.[3] The 68030 includes an integrated PMMU, enabling System 7's virtual memory feature.
The Gestalt ID for the Macintosh LC II is 19 or 37 (depending on ROM version).
Note: Although the 68030 supports an FPU, Apple did not include an FPU socket on the LC II logic board as a cost-saving measure.
Memory and Storage
RAM Configuration
The LC II shipped with 4 MB standard, expandable to 10 MB โ€” Apple's figures[4] โ€” in two 30-pin SIMM slots, matched pairs, 100 ns or faster.
The sound on the LC, LC II and LC III is monophonic in and out. Apple's own wording is a mono sound input and output port on a mini phono plug, and a monophonic 8-bit sound generator supplying the same signal to both channels of stereo equipment.[4] Stereo output arrives with the LC 475 and Quadra 605. A stereo input/output description on the earlier machines is wrong, and it matters when diagnosing a channel that sounds dead: on an LC, LC II or LC III both channels carry the same signal by design.
Apple's other figures for this machine: ROM 512K; VRAM 256K SIMM upgradable to 512K; a 96-pin processor-direct slot taking 020/030 cards; maximum power 50 W excluding the monitor; 100โ€“240 VAC automatically configured at 47โ€“63 Hz; PRAM battery replaced below 3.0 V.[4]
RAM Configurations
Configuration Slot 1 Slot 2
4 MB 2 MB 2 MB
6 MB 2 MB + 2 MB soldered 2 MB
10 MB 4 MB 4 MB + 2 MB soldered
Video RAM
The LC II includes 256 KB of VRAM standard, expandable to 512 KB:
  • 256 KB VRAM: 640ร—480 at 4-bit (16 colors)
  • 512 KB VRAM: 640ร—480 at 8-bit (256 colors)
Storage Systems
Storage options included:
  • 40 MB, 80 MB, or 160 MB internal SCSI hard drive
  • 1.44 MB SuperDrive (reads/writes 400K, 800K, and 1.44 MB disks)
Input/Output and Expansion
Port Configuration
  • 1ร— Apple Desktop Bus (ADB) port
  • 1ร— External SCSI (DB-25)
  • 1ร— monophonic audio input (mini phono plug)
  • 1ร— monophonic audio output (mini phono plug)[4]
  • 2ร— Serial ports (Mini DIN-8)
  • 1ร— Video output (DA-15)
Expansion
The LC II features a single LC Processor Direct Slot (LC PDS), compatible with the same expansion cards as the original LC.
For detailed maintenance practices including cleaning, PRAM battery management, and connector care, refer to the dedicated Macintosh LC II General Maintenance page.
A comprehensive troubleshooting guide addressing common issues with the Macintosh LC II is available on the Macintosh LC II Troubleshooting page.
Capacitor Replacement
The Macintosh LC II logic board contains 17 surface-mount electrolytic capacitors that commonly fail due to age. Detailed replacement guidelines can be found on the Macintosh LC II Capacitor Replacement Guide page.
Macintosh LC II Technical Specifications
Component Specification
CPU Motorola 68030 @ 16 MHz
FPU None (no socket provided)
PMMU Integrated in 68030
Data Bus 32-bit (16-bit memory controller)
System Bus 16 MHz
ROM 512 KB
RAM 4 MB (max 10 MB)
VRAM 256 KB (max 512 KB)
  1. โ†‘ Macintosh LC II, Apple Historyโ€”link(accessed 2026-02-09)
  2. โ†‘ Apple Macintosh LC II Specs, EveryMac.comโ€”link(accessed 2026-02-09)
  3. โ†‘ Macintosh LC II, Low End Macโ€”link(accessed 2026-02-09)
  4. โ†‘ 4.0 4.1 4.2 4.3 Apple Computer, Macintosh LC Series/Quadra 605 Service Source (Macintosh LC Series/ Quadra 605 Service Source, File:Quadra_605.lc_series.pdf), Specifications chapter and Additional Procedures, Battery Replacement (below 3.0 volts, replace the battery). This volume has no Adjustments chapter, so Apple publishes no rail tolerance and no power-supply adjustment for any LC.
