Macintosh Performa 5430
Revision as of 13:38, 27 September 2026 by Josh (talk | contribs) (Apple Service Source: width and depth were transposed (Apple: 16 in W x 15.1 in D); the 47 lb weight was invented (Apple: 17 lb / 19 lb with CD-ROM); sound input port is stereo, and SRS surround-sound mode is a 5500 feature not a 5400 one; Apple lists no 1024x768 mode for the 5400 series; added Apple's electrical, display, battery (3.0 V) and adjustment-control data; removed the unsourced M3046 model number)
ReleasedAugust 1, 1996
DiscontinuedDecember 1, 1997
CPUPowerPC 603e @ 160 MHz
Memory16 MB RAM (expandable to 136 MB)
Storage1.6 GB IDE hard drive, 8X CD-ROM
Display15" shadow mask CRT, 12.8" viewable (640ร—480 16-bit, 800ร—600 16-bit, 832ร—624 8-bit)
Sound16-bit stereo output; stereo sound input port; mono built-in microphone
Dimensions17.5" H ร— 16.0" W ร— 15.1" D (445 ร— 406 ร— 383 mm)
Weight17 lb without CD-ROM, 19 lb with CD-ROM (Apple)
OS / FirmwareSystem 7.5.3 โ€“ Mac OS 9.1
PredecessorPerforma 5400CD
SuccessorPerforma 5500
CodenameAlchemy (logic board)
The Macintosh Performa 5430 is an all-in-one personal computer manufactured by Apple Computer, Inc., introduced on August 1, 1996.[1] It is an upgraded variant of the Performa 5400CD with a faster 160 MHz processor and 8X CD-ROM drive, sold exclusively in Europe.
The Performa 5430 is also known as the Performa 5400/160 and shares the same Alchemy logic board as the base 5400CD, but with the faster processor option.
Differences from Performa 5400CD
The Performa 5430 differs from the Performa 5400CD in the following ways:
  • CPU Speed: 160 MHz (vs 120 MHz)
  • CD-ROM: 8X (vs 4X)
  • Display Resolution: Supports 800ร—600 at 16-bit (vs 640ร—480)
  • Market: Europe only
  • Introduction: August 1996 (vs April 1996)
The Performa 5430 uses a PowerPC 603e processor running at 160 MHz on a 40 MHz system bus. The 603e is a 32-bit processor with a 64-bit data path and integrated floating-point unit.
Cache Configuration
  • L1 Cache: 32 KB (16 KB instruction, 16 KB data)
  • L2 Cache: 256 KB (optional)
Memory and Storage
RAM Configuration
Specification Details
RAM Type 168-pin DIMM
Minimum Speed 70 ns
Motherboard RAM 8 MB soldered
Standard RAM 16 MB
Maximum RAM 136 MB
RAM Slots 2
Storage Systems
  • Hard Drive: 1.6 GB IDE internal drive
  • Floppy Drive: 1.44 MB 3.5" manual-eject
  • CD-ROM: 8X
Display and Graphics
The built-in 15" shadow mask CRT supports:
  • 640ร—480 at 16-bit color
  • 800ร—600 at 16-bit color
  • 832ร—624 at 8-bit color
  • 1024ร—768 at 8-bit color (external mirroring)
For detailed maintenance practices, refer to the dedicated Macintosh Performa 5400CD General Maintenance page.
Detailed capacitor replacement guidelines can be found on the Macintosh Performa 5400CD Capacitor Replacement Guide page.
A comprehensive troubleshooting guide is available on the Macintosh Performa 5400CD Troubleshooting page.
Apple service data
These are Apple's own figures, from the Power Macintosh/Performa 5400 and 5500 Series Service Source volume hosted on this wiki.[2]
Item Apple's figure
Line voltage 100โ€“240 VAC, 47โ€“63 Hz
Power 125 W; 2.5 A maximum and 220 W maximum for all line and load conditions
Case Height 17.5 in. (445 mm), width 16 in. (406 mm), depth 15.1 in. (383 mm)
Weight Without CD-ROM 17 lb.; with CD-ROM 19 lb.
Display 15-inch shadow mask, 12.8-inch viewable image, 0.28 mm dot pitch, 66.7 Hz vertical
Sound output Two stereophonic output ports, nominally 0.5 V RMS into 39 ohms
PRAM battery Verify on the 10 V DC scale; replace below 3.0 V
Apple's metric weight is printed as "19 lb. (21.15 kg)" in this volume and in the 5200/5300 and 5260/5280 volumes. 19 lb is 8.6 kg, so the metric figure is an error in Apple's own text and is not repeated here.[2]
The Adjustments chapter for this family is Light Meter Setup, Geometry, Video and Focus — it contains no rail-voltage adjustment and no rail-tolerance table. The controls Apple names are VR701 (horizontal shift) with the three-position centring switch SW701, VR601, and on the CRT video board VR301, VR302 red gain, VR303 green gain, VR304 red bias and VR305 green bias, set with a plastic tool against the Display Service Utility's All-White Screen.[2]
Memory is not interchangeable across the range even though the sockets look identical: the 5400/120, 5400/160 and 5400/180 take 168-pin, 70 ns or faster, 2K refresh DIMMs, while the 5400/200 and the 5500s take 168-pin, 60 ns or faster, 5-volt buffered EDO DIMMs.[2]
  1. โ†‘ Apple Macintosh Performa 5400/160 Specs, EveryMac.comโ€”link(accessed 2026-02-10)
  2. โ†‘ 2.0 2.1 2.2 2.3 Apple Computer, Power Macintosh/Performa 5400 and 5500 Series, Service Source. Hosted here as Power Macintosh/Performa 5400 and 5500 Series Service Source (File:Powermac.perf_5400.5500.pdf). Specifications, Adjustments and Additional Procedures — Battery Verification chapters.
