LaserWriter Pro 600/630 Service Source
Revision as of 14:36, 30 September 2026 by Josh (talk | contribs) (Correct page range for board diagrams)
The LaserWriter Pro 600/630 volume of Apple's Service Source is a 296-page service manual for the LaserWriter Pro 600 and LaserWriter Pro 630. The PDF's creation date is 26 October 1995.[1] It includes theory-of-operation sections, board locator diagrams with designators, a wiring diagram, a printer self-diagnostic and a measured registration adjustment.
LaserWriter Pro 600/630 specifications[2]
Item Value
Engine Canon LBP-B270; single-component microfine toner; semiconductor laser with a rotating six-faced prism scanning mirror
Resolution 600 dpi (the Pro 630 prints at 300 dpi when PhotoGrade is on)
Controller Motorola 68030 at 25 MHz; 8 MB RAM, expandable to 32 MB; 2 MB ROM
Speed 8 pages per minute (letter or A4); 6 envelopes per minute with the optional envelope feeder
Power consumption About 0.66 kW at 71 °F (20 °C)
Operating environment 10-32.5 °C (50-90.5 °F); 20-80% RH; 570-760 mmHg
Consumables service life Pickup rollers, separation pad, fuser assembly and transfer roller 200,000 pages each; exhaust fan 25,000 hours
The Pro 600 needs 8 MB of RAM to print at 600 dpi or to use PhotoGrade. Apple notes that in early 1993 some Pro 600s shipped with 4 MB and a free upgrade kit that dealers were to install.[2]
Contents
  • Basics (PDF pp. 3-43): product information, LaserWriter Utility, paper path, mechanical drive theory, sensing system theory, hard drives, test and configuration pages, configuration switch, LaserWriter safety
  • Specifications (PDF pp. 45-54): engine, I/O board, sheet feeder, envelope feeder, paper
  • Troubleshooting (PDF pp. 56-125): general, printer diagnostic, maintaining I/O connectivity, troubleshooting tips, capacitor discharge, fuser roller modes, expansion post connectors, circuit board diagrams (Pro 600 and Pro 630 I/O boards, DC controller, pickup controller, pickup sensor board, high-voltage power supply, envelope and sheet feeder controllers), wiring diagram, J136 and J743 locators
  • Take Apart (PDF pp. 127-273): the whole engine, from the rear panel and I/O board through the fuser assembly and its thermoprotector, heater bulb and thermosensor to the delivery and pickup assemblies
  • Upgrades (PDF pp. 275-285): RAM, I/O board, PhotoGrade medallion
  • Adjustments (PDF pp. 287-291): registration adjustment
  • Exploded View (PDF pp. 292-296)
What it settles
Capacitor C202: on a fusing failure the DC controller cuts current to the fuser heater and charges C202 on the DC controller board. Leave the power off for about 10 minutes, or discharge C202 manually by jumpering the two wires at its base after removing the rear panel and I/O shield.[3] The fuser rollers themselves need at least 5 minutes switched off to cool before servicing.[4]
Printer diagnostic: switch off, jumper pins 7 and 9 on the I/O board DB-9 connector, and switch on. The LEDs flash for about 15 seconds and then hold the "diagnostic executing" pattern for about 2 minutes; if no error is found, all LEDs light and two pages print. Error patterns identify the I/O board, ROMs, SIMMs, fuser assembly, laser/scanner, main motor and fan. If the executing pattern lasts more than 3 minutes, the error is unknown.[5]
Registration: leading-edge registration is set by paper sensor PS602 and variable resistor VR202 on the DC controller board, and the optimum distance is 2 mm. Set VR202 to 0, print three service test pages, measure from the top of each page to the edge of the printed pattern, average the three, and turn VR202 clockwise if the average is under 2.0 mm or anticlockwise if over. Apple requires this whenever the DC controller board, paper pickup block or laser/scanner is replaced.[6]
The board diagrams carry designators: VR202, C201, C202 and TB201 on the DC controller; SW601-SW605 and J601-J605 on the pickup controller; PS701 and PS702 on the pickup sensor board; VR401, J401, J402 and TB401-TB406 on the high-voltage supply.[7]
There is no schematic and there are no component values: the board diagrams are locators and the wiring diagram shows connections between parts. No fuse ratings, supply-rail tolerance table or resistance figures for the fuser heater or thermoprotector are printed.[1]
Pages that cite this document
Download: Laserwriter pro 600.630.pdf
  1. ↑ 1.0 1.1 Apple Computer, Inc., LaserWriter Pro 600/630 (Service Source), 296 pp. Hosted as File:Laserwriter pro 600.630.pdf.
  2. ↑ 2.0 2.1 LaserWriter Pro 600/630 Service Source, Specifications, Engine and I/O Board, pp. 1-6 (PDF pp. 45-50).
  3. ↑ LaserWriter Pro 600/630 Service Source, Troubleshooting, Capacitor Discharge, pp. 18-20 (PDF pp. 73-75).
  4. ↑ LaserWriter Pro 600/630 Service Source, Basics, LaserWriter Safety, p. 41 (PDF p. 43).
  5. ↑ LaserWriter Pro 600/630 Service Source, Troubleshooting, Printer Diagnostic, pp. 2-4 (PDF pp. 57-59).
  6. ↑ LaserWriter Pro 600/630 Service Source, Adjustments, Registration Adjustment, pp. 2-6 (PDF pp. 287-291).
  7. ↑ LaserWriter Pro 600/630 Service Source, Troubleshooting, Circuit Board Diagrams and Wiring Diagram, pp. 25-34 (PDF pp. 80-89).
