IBM Proprinter 420X Service Information and Parts Catalog
Proprinters: Service Information and Parts Catalog is IBM's service and parts manual for the Proprinter family of dot-matrix printers, document number SA38-0099-02, Third Edition (November 1993). The PDF has 68 pages. It is a text conversion of IBM's softcopy edition: pages are numbered within each topic ("1.15 - 1") and the 22 illustrations are replaced by "PICTURE" placeholders. The edition notice says IBM prepared it "for the use of customer engineers in the installation, maintenance, or repair of the specific machines indicated".
The machine identification table (topic 1.1) covers the 9-wire Proprinter (4201-001), Proprinter II (4201-002), Proprinter III (4201-003), Proprinter XL (4202-001), II XL (4202-002) and III XL (4202-003), and the 24-wire Proprinter X24 (4207-001), X24E (4207-002), XL24 (4208-001), XL24E (4208-002) and Proprinter 24P (4212-001). The title's "420X" is IBM's name for the common parts of the 4201 to 4208 printers (topic 3.1).
Contents
[edit | edit source]| Topic | Subject |
| 1.1 | Machine type and model identification |
| 1.2 | Read this before replacing any FRUs: the Proprinter initialization procedure |
| 1.3, 1.4 | Bidirectional print adjustment for the Proprinter III and III XL, and for the X24E and XL24E |
| 1.5 to 1.10 | Self-test; function (switch) settings; soft switch configuration; serial-interface card switches for the Proprinter I, II and X24 and for the model 003 and model 002 machines; mode selection switches |
| 1.11 to 1.14 | General checkout, clearing paper jams, common printer problems, common sheetfeeder problems |
| 1.15 | Sheetfeeder drive gear kit, P/N 51F3712 |
| 1.16 | Adjustments: print head to platen adjustment (all Proprinters) |
| 2.0 | The 4212 Proprinter 24P: related publications, checklist, font or pitch lock, thermal protection slowdown, switch settings, printer test, bidirectional alignment |
| 3.0 | Parts catalogue: 420X common parts, ECA part-number information, assemblies 1 to 7 (main cover, base logic, the paper-feed variants, the 24P) |
| 4.0 | Part number index |
Procedures a repairer can use
[edit | edit source]- Initialization (1.2.1): for the 4201 and 4202 model 003 and the 4207 and 4208 model 002, IBM says to run this before replacing any FRU when the printer shows missing or wrong characters, bad spacing, forms or head motor failures, shifting margins or is locked in Propark mode. With the printer off, paper out and the head at the far left, hold the two blue keys (Propark and NLQ) while switching on, and release them when the panel lights flash in rotation. It resets the soft switch settings, so print them first (1.7).
- Print head to platen adjustment (1.16.1): recommended when fitting a new print unit (new units come unadjusted), when the left margin shifts to the right, or when head impact varies across the page. A 1-inch square of 20 lb paper is the gauge: with the forms-thickness lever at 1 there should be slight drag, and at 2 none. Parallelism is set with a 5 mm Allen key on the rear guide rod bushing in the right side-frame.
- Sheetfeeder drive gear kit 51F3712 (1.15): repairs narrow and wide sheetfeeders whose main drive gear mounting stud is damaged or broken.
[edit | edit source]There are no schematics, no component values and no board-level parts list: the logic card, power supply and motors are FRUs in the parts catalogue. The illustrations, including the adjustment drawings and the exploded assembly views, are missing from this PDF, so the parts lists have no pictures to go with their index numbers.
Download: IBM Proprinter 420X Service Information and Parts Catalog.pdf
