Commodore 64 Capacitor Replacement Guide
The tables below give the electrolytic capacitors on the Commodore 64 long boards (assemblies 326298, 250407, 250425 and 250441) and on the 250466 (B-3) board. Every value comes from Commodore's own parts lists in the Service Manual C64/C64C (March 1992, PN-314001-03).[1] The 250469 (E) board used in most Commodore 64C machines has a different power circuit and its own list in the Commodore 64C Capacitor Replacement Guide.
The ceramic, mica and film capacitors on these boards are not included. Commodore's lists give their values if one is damaged.
Identify the board
The assembly number is printed on the board, usually near the cartridge port edge. Commodore's identification table:[2]
| Version | Assembly | Schematic | Identifying factor (Commodore) |
| Original | 326298-01 | 326106 | 5-pin video connector (CN5) |
| A (CR) | 250407 | 251138 | 8-pin video connector |
| B | 250425 | 251469 | 8-pin; reduced oscillator circuit |
| B-2 | 250441-01 | 251469 | As B, with component location changes |
| B-3 | 250466-01 | 252278 | Only two RAM chips, U9 and U10 |
| E | 250469 | 252312 | BASIC and KERNAL combined in U4; memory controller at U8 |
Commodore's table prints the B-3 assembly as "250446"; its parts list and board layout for the same board say 250466.[3] The manual has no separate parts list for the B-2 (250441): Commodore says all its circuits are those of the B (schematic 251469), with resistors R28, R29, R30, R36 and R48 replaced by resistor pack RP5 and diodes CR100-CR105 moved to CR9 and CR12-CR16.[2] Use the 250425 list and check positions against the board.
The power section
The external supply delivers regulated +5 V DC on CN7 pin 5 and 9 V AC on pins 6 and 7; pins 1, 2 and 3 are ground. The +5 V from the brick passes the power switch and powers the logic directly. On the board, the 9 V AC is used three ways:[4]
- Bridge rectifier CR4 and reservoir C19 feed VR2 (MC7805CT), whose output, "+5 V CAN", is filtered into Vvid for the video circuits and Vc for the clock circuits.
- The 9 V AC is "added to 9VDC through CR6, and rectified by CR5"; on Commodore's diagram C90 couples the AC into this circuit. The result is filtered by C88 and C89 and regulated to +12 V by VR1 (MC7812CT) for the VIC-II, the SID and the audio stages.
- CR4's output, unregulated, is the +9 V supply for the cassette motor circuit and, on the B board, the RF modulator.
C91 (100 µF) sits on the +5 V input after the power switch.[4]
Electrolytic capacitors by board
All values and ratings below are as printed in Commodore's parts lists. Fit at least the voltage rating shown.
326298-01 (original)
| Ref | Capacitance | Rating | Tolerance |
| C19 | 2200 µF | 16 V | |
| C88 | 470 µF | 50 V | |
| C90 | 470 µF | 50 V | |
| C91 | 100 µF | 16 V | |
| C8, C12, C13, C14, C15, C17, C24, C34, C57, C62, C64, C65, C94, C102 | 10 µF | 25 V | +50 % / −10 % |
250407 (A)
| C88 | 1000 µF | 25 V | |
| C91 | 100 µF | 16 V | +50 % / −10 % |
| C8, C13, C14, C15, C17, C24, C34, C57, C62, C65, C94, C102 | 10 µF | 25 V | +50 % / −10 % |
| C108 | 10 µF | 25 V | 20 % |
C88 differs between documents. Commodore's 1983 drawing for assembly 250407 revision B lists C88 and C90 as 470 µF 50 V (part 900101-34), and C12 as a 10 µF electrolytic; the service manual's 250407-04 list gives C88 as 1000 µF 25 V and C12 as a 0.1 µF ceramic.[7][6] Console5's kit list gives 470 µF at C88 for revision B and earlier boards and 1000 µF from revision C.[8] Read the part fitted to your board; a 1000 µF 25 V part covers either.
250425 (B) and 250441 (B-2)
| Ref | Capacitance | Rating | Tolerance | Type |
| C19 | 2200 µF | 16 V | Electrolytic | |
| C88 | 1000 µF | 25 V | Electrolytic | |
| C90 | 470 µF | 50 V | Electrolytic | |
| C91 | 100 µF | 16 V | +50 % / −10 % | Electrolytic |
| C24 | 22 µF | 25 V | +50 % / −10 % | Electrolytic |
| C13 | 10 µF | 25 V | +50 % / −10 % | Electrolytic |
| C15 | 4.7 µF | 16 V | 20 % | Tantalum |
The 250425 has far fewer electrolytics than the earlier boards: positions such as C8, C14, C17, C34 and C57 are 0.1 µF ceramics or are not fitted.[9]
250466-01 (B-3)
| Ref | Capacitance | Rating | Package | Commodore part no. |
| C19 | 2200 µF | 16 V | Axial | 900101-33 |
| C88 | 1000 µF | 25 V | Axial | 900101-50 |
| C90 | 470 µF | 25 V | Axial | 900101-49 |
| C91 | 100 µF | 16 V | Radial | 900100-40 |
| C24 | 22 µF | 25 V | Radial | 900100-24 |
| C13 (C210) | 10 µF | 25 V | Radial | 900100-01 |
| C200 | 2.2 µF | not stated | Radial | 251079-06 |
| C15 | 4.7 µF tantalum | 16 V | Radial | 900410-13 |
C90 is rated 25 V on the B-3 and 50 V on the earlier boards. C20 on the B-3 is a 0.22 µF 100 V film capacitor, not an electrolytic.[3]
Faults Commodore traces to these parts
Commodore's troubleshooting table names capacitors in three symptoms.[10]
| Symptom | Commodore's check |
| Intermittent display | C88 (possible bad connection) |
| Black band scrolls through screen when system warms up | External power supply; C90, C88, CR4; VR2 (5 V regulator) |
| Wrong frequency | C70 |
C70 is a 10 pF mica capacitor in the clock oscillator on the 326298, not an electrolytic.[5] The guide lists the external power supply first for the black-band symptom, and the same check heads its "white band scrolls down the screen (60 Hz hum)" entry, which names VR2 but no capacitor.[10]
Procedure
- Measure the power supply's +5 V output before opening the machine. The C64-Wiki treats 4.95-5.10 V as normal and above 5.2 V as a failing supply; most machines it records as killed by their supply had seen more than 6 V.[11] Replace a high supply before working on the board.
- Note the assembly number and use that board's list. Photograph the power section first.
- Record the polarity of each part. C19, C88 and C90 are axial on the B-3 list; check which end carries the negative stripe before removing them.
- Replace each electrolytic with the same capacitance and a voltage rating at least that shown. C15 on the 250425 and the B-3 is a tantalum part.
- Clean flux from the power section and inspect the joints on VR1, VR2 and CR4, which Commodore names in its "blank screen on power up" entry.[10]
- Power up and measure the regulator outputs.
Checks after the recap
| Point | Nominal | Acceptable |
| CN7 pin 5 (+5 V from the external supply) | 5.0 V | 4.95-5.10 V[11] |
| VR2 output (+5 V CAN) | 5.0 V | 4.8-5.2 V[12] |
| VR1 output (+12 V) | 12.0 V | 11.5-12.5 V[12] |
The two regulator ranges are the 78xx datasheet limits, not Commodore figures; Commodore's manual gives no tolerance for either rail.[4]
- Commodore 64 · Commodore 64C · Commodore 64C Capacitor Replacement Guide
- Commodore 64 General Maintenance · Commodore 64 Troubleshooting Guide
- Commodore 64 / 64C Service Manual · Commodore 64 Technical Manual and Parts List
- Commodore 64 Power-Supply Protector (C64 Saver)
- Capacitor Failure Symptoms · Recommended Tools
- ↑ Commodore Business Machines, Service Manual C64/C64C, March 1992, PN-314001-03, hosted at Commodore 64 / 64C Service Manual. Board identification p. 17; parts lists for 326298 pp. 19-20, 250407-04 pp. 24-25, 250425-01 pp. 29-30, 250466-01 (B-3) pp. 34-35.
- ↑ 2.0 2.1 Service Manual C64/C64C (1992), "C64 Board Identification" and "C64C Board Identification", p. 17.
- ↑ 3.0 3.1 3.2 Service Manual C64/C64C (1992), "Parts List, PCB Assembly #250466-01 C64-B3", pp. 34-35, and "B-3 Board Layout", p. 36.
- ↑ 4.0 4.1 4.2 Service Manual C64/C64C (1992), Circuit Theory, "The Power Supply", p. 4 (text and power-input diagram).
- ↑ 5.0 5.1 Service Manual C64/C64C (1992), "Parts List - PCB Assembly #326298", pp. 19-20.
- ↑ 6.0 6.1 Service Manual C64/C64C (1992), "Parts List - PCB Assembly #250407-04", pp. 24-25.
- ↑ Commodore, Commodore 64 Computer Technical Manual, P/N 990439, drawing 250407 rev. B, sheet 3 of 7 (PDF p. 6), items 47-50, hosted at Commodore 64 Technical Manual and Parts List.
- ↑ Console5 TechWiki, "Commodore 64", capacitor lists for assemblies 326298, 250407, 250425, 250466 and 250469 (secondary source). Retrieved 2026-10-01.
- ↑ 9.0 9.1 Service Manual C64/C64C (1992), "Parts List - PCB Assembly #250425-01", pp. 29-30.
- ↑ 10.0 10.1 10.2 Service Manual C64/C64C (1992), "64 Troubleshooting Guide", pp. 14-16.
- ↑ 11.0 11.1 C64-Wiki, "Power Supply", section "Failure". Retrieved 2026-10-01.
- ↑ 12.0 12.1 Texas Instruments, LM340, LM340A and LM7805 Family Wide VIN 1.5-A Fixed Voltage Regulators, SNOSBT0L (revised September 2016), tables 6.6 and 6.7, output voltage at TJ = 25 °C. Commodore fitted Motorola MC7805CT and MC7812CT parts of the same 78xx type.
