Amstrad 6128
Revision as of 17:56, 1 October 2026 by Josh (talk | contribs) (Link the hosted dk'tronics Peripheral Technical Manual (memory expansion and silicon disc))
The Amstrad CPC 6128 is the 128 KB, disc-based model of the Amstrad CPC range. It has the architecture of the Amstrad CPC 464 and 664 with 128 KB of RAM in two banks, a built-in 3-inch disc drive and CP/M Plus. Amstrad released it in the United States on 13 June 1985 and in Europe on 15 August 1985, where it replaced the 664; the UK prices were £299 with a green monitor and £399 with a colour monitor. The 6128 Plus replaced it in 1990.[1] It was sold with either the GT65 green monitor or the CTM644 colour monitor.[2]
Amstrad CPC 6128
CPC 6128 with its colour monitor
DeveloperAmstrad
ManufacturerAmstrad Consumer Electronics plc
TypeHome computer
Released13 June 1985 (US), 15 August 1985 (Europe)
Discontinued1990
Intro price£299 with green monitor, £399 with colour monitor
CPUZilog Z80A at 4 MHz
Memory128 KB RAM in two 64 KB banks
StorageBuilt-in 3-inch disc drive
Display160 × 200 (16 colours), 320 × 200 (4) or 640 × 200 (2) from 27
SoundGeneral Instrument AY-3-8912, three voices
Graphics6845 CRT controller with gate array
ROM48 KB (operating system, Locomotive BASIC 1.1 and disc extensions)
Input74-key keyboard
Power5 V and 12 V DC from the monitor
OS / FirmwareAmstrad firmware, Locomotive BASIC 1.1, AMSDOS, CP/M 2.2 and CP/M Plus
PredecessorAmstrad CPC 664
SuccessorAmstrad 6128 Plus
Model no.CPC 6128
Power
The CPC 6128 has no mains connection and no power supply of its own. Amstrad's specification gives the supply as "Screen System: 240V AC 50Hz (keyboard and disc drive power supplied by screen system)", with a 5 mm socket for the 5 V supply, "supplied exclusively from monitor", and a 5 mm plug and lead to the 12 V disc power socket on the monitor.[2] The computer needs both. A 6128 that starts but cannot read a disc may simply have its 12 V lead unplugged. The monitors contain the mains supply and a CRT; the service manual gives a parts list, alignment instructions and a voltage chart for each, and CRT Discharge Procedure covers the hazard.[3]
A CPC 6128 with the keyboard removed: main board at left, disc drive at right (photo: Jesus Abizanda, CC BY 2.0)
Amstrad's specification lists a Z80A at 4 MHz; 128 KB of RAM in two 64 KB banks, with over 41 KB available in BASIC and 61 KB of TPA under CP/M Plus; 48 KB of ROM containing BASIC, the operating system and the disc extensions; a 6845 CRT controller; an AY-3-8912 (three voices, eight octaves); an 8255 parallel interface; and a 74-key keyboard.[2] The external sockets are edge connectors for expansion and the Centronics printer, a second-drive socket (DI-2 lead), a 9-pin joystick socket, a 6-pin DIN for RGB or luminance video, a 5-pin DIN for an external cassette recorder (CL1 lead) and a 3.5 mm stereo output. Up to 252 additional 16 KB ROMs can be added. The keyboard unit measures 510 × 48 × 170 mm and weighs 2.0 kg.[2]
The parts list for the original board names the Z8400APS CPU (IC111), the TMM-23256P-1953 system ROM (IC103), the TMM-23128P-1851 AMSDOS ROM (IC204), the HSG3130/3170 gate array (IC116), a PAL16L8AC (IC118), sixteen MSM3764-20RS DRAMs (IC119–134), the µPD765AC-2 disc controller (IC201), the FDC9216BT data separator (IC202) and a 16 MHz crystal (X101).[3] The specification page prints the disc controller as "7653"; the parts list shows it is a µPD765AC-2.
Main board versions
CPCWiki's catalogue of photographed boards records three 6128 board versions.[4]
CPC 6128 main board versions
Version Silkscreen Size Notes
1 Z70210 MC0009A–C, MC0012A/B; Z70270 MC0016A 320 × 155 mm 8-pin data separator; pads for both the old and new gate array
2 (©1985) Z70290 MC0020A–I, MC0023D–G, MC0026B, MC0057A 320 × 155 mm 24-pin data separator; pads for the new gate array only
3, cost-down (1988) Z80330 MC0100A 310 × 145 mm 100-pin surface-mount gate array combining the gate array, PAL, CRTC and some floppy, DRAM and reset logic; can take four 64K × 4 RAM chips
Amstrad's amendment manual has two later CPC6128 sections with their own board drawings.[5]
Disc system
The drive is a 3-inch unit to the Hitachi/Panasonic standard; the software is set for a 12 ms step rate and 30 ms settling time, and the system controls at most two drives. The discs are single-sided in use, 40 tracks of 512-byte sectors; the user turns the disc over, and each side has its own write-protect clip.[2] The parts list gives the drive as a Compact Floppy Disc Drive EME-155 (FDD201).[3] CPCWiki records that early 6128s used the earlier EME-150A.[6]
AMSDOS and CP/M Plus on the 6128 use two formats: SYSTEM, with 9 sectors per track, two reserved tracks and 169K of file space, and DATA only, with no reserved tracks and 178K. Amstrad notes that CP/M applications generally assume an 80-column screen, which the 6128 provides.[2]
Amstrad's service policy was that the drive mechanism and its board, PCB30001, went back for exchange; the manual gives no part numbers for that board but includes its circuit diagram.[3] The usual fault is a perished drive belt; CPCWiki gives the replacement as 3 mm wide, 0.6 mm thick and 230 mm in outer circumference, and describes the removal procedure for the 6128.[7]
Capacitors
The parts list gives twelve electrolytic capacitors on the original board.[3]
CPC 6128 electrolytic capacitors (parts list, p. 21)
Value Circuit reference Amstrad part no.
100 µF / 16 V C315 20028
100 µF / 10 V C301, C304 20028
47 µF / 10 V C136, C303, C306 1400244
22 µF / 10 V C308 20025
1 µF / 50 V C309, C311, C314, C317, C318 20062
  1. ↑ Wikipedia, "Amstrad CPC", sections "CPC 6128" and "CPC 664". Retrieved 2026-10-01. Gives the US and European release dates, the launch prices, the replacement of the 664 and the 1990 replacement by the 6128plus.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Amstrad Consumer Electronics plc, CPC6128 Micro Computer / CTM644 Colour Monitor / GT65 Green Monitor Service Manual, back page "Technical Specification". Described at Amstrad CPC 6128 Service Manual.
  3. ↑ 3.0 3.1 3.2 3.3 3.4 Amstrad Consumer Electronics plc, CPC6128 Micro Computer / CTM644 Colour Monitor / GT65 Green Monitor Service Manual, p. 2 "Contents" and p. 21 "Electrical Parts List". Described at Amstrad CPC 6128 Service Manual.
  4. ↑ CPCWiki, "Mainboard Versions". Retrieved 2026-10-01. Community catalogue of board markings, sizes and per-version changes.
  5. ↑ Amstrad plc, CPC464 / CPC6128 / GT65 / CTM644 / MP3 / CT1 Amendment Service Manual, contents and pp. 11–24. Described at Amstrad CPC 464 / CPC 6128 / GT65 / CTM644 / MP3 / CT1 Service Manual Amendment.
  6. ↑ CPCWiki, "Amstrad FDD part". Retrieved 2026-10-01. Lists the Matsushita mechanisms used in the CPC range and their differences.
  7. ↑ CPCWiki, "Changing the drive belt". Retrieved 2026-10-01.
