iMac G3
Revision as of 07:27, 2 October 2026 by Josh (talk | contribs) (Link the iMac G3 capacitor guide)
The iMac G3 is Apple's first iMac: an all-in-one Macintosh with a 15-inch CRT, a PowerPC G3 processor and USB in place of Apple's older ports, introduced in August 1998 in a translucent coloured case. There are two physical designs. The tray-loading iMac of 1998-1999 (233, 266 and 333 MHz) has its logic board on a chassis that slides out of the bottom and RAM on the processor card. The slot-loading iMac of October 1999 onwards (350 to 700 MHz) is a revised case with a slot-loading optical drive and memory behind a door under the machine.[1][2]
iMac G3
The original Bondi Blue iMac (David Fuchs and Rama, Wikimedia Commons, CC BY-SA 4.0)
TypeAll-in-one personal computer
Released15 August 1998
CPUPowerPC G3 at 233 MHz to 700 MHz
Memory32 MB to 256 MB standard; SO-DIMMs (tray-loading) or PC100 DIMMs (slot-loading)
Storage4 GB to 60 GB ATA hard disk
DisplayBuilt-in 15-inch CRT, 13.8-inch viewable
Sound—
GraphicsATI Rage IIc, Rage Pro, Rage Pro Turbo, Rage 128 Pro and Rage 128 Ultra
MediaTray-loading CD-ROM (1998-1999); slot-loading CD-ROM, DVD-ROM or CD-RW (1999-2001)
Ports / interfaceTwo USB; 10/100BASE-T Ethernet; modem; audio; FireWire and VGA out on later models
OS / FirmwareMac OS 8.1 (first model) to Mac OS 9 and Mac OS X
The iMac G3 has a CRT and an internal power supply on the same board as the CRT drive circuits. Read CRT Discharge Procedure before opening one: Apple's Service Sources call for the CRT to be discharged before work on the analogue and power boards.[1][2]
Models
iMac G3 models
Model Introduced Processor RAM (standard / maximum) Graphics Notes
iMac, Bondi Blue (M6709LL/A) 15 August 1998[3] 233 MHz 32 MB / 128 MB ATI Rage IIc, 2 MB SGRAM IrDA port; reset button on the side; Mac OS 8.1[1]
iMac, Bondi Blue (M6709LL/B) 26 October 1998[4] 233 MHz 32 MB / 256 MB ATI Rage Pro, 6 MB SGRAM No IrDA; reset with the front power button; Mac OS 8.5[1]
iMac (266 MHz), five colours 5 January 1999[5] 266 MHz 32 MB / 256 MB ATI Rage Pro Turbo, 6 MB SGRAM Blueberry, Strawberry, Grape, Tangerine, Lime; 6 GB disk[1]
iMac (333 MHz) 15 April 1999[6] 333 MHz 32 MB / 256 MB ATI Rage Pro Turbo Same five colours; only the processor changed[1]
iMac (Slot Loading), iMac DV, DV Special Edition 4 October 1999[7] 350 or 400 MHz 64 MB / 512 MB not given FireWire and VGA out on the DV and Special Edition
iMac (Summer 2000), including DV+ 19 July 2000[8] 350 to 500 MHz 64 MB / 1 GB not given FireWire and VGA on all models[8]
iMac (Early 2001) 22 February 2001[4] 400, 500 or 600 MHz 64 or 128 MB / 1 GB ATI Rage 128 Pro (8 MB) or Rage 128 Ultra (16 MB)[9] Flower Power and Blue Dalmatian patterns[4]
iMac (Summer 2001) 18 July 2001[4] 500, 600 or 700 MHz 128 or 256 MB / 1 GB ATI Rage 128 Ultra, 16 MB[10] Indigo, Snow and Graphite; CD-RW in all models
Apple gives the slot-loading iMac as introduced on 4 October 1999; Wikipedia gives 5 October.[7][4]
Tray-loading models
The logic board, hard disk and CD-ROM drive sit on a logic board/mass storage chassis that slides out of the bottom after the lower access cover is removed. The processor and boot ROM are on a plug-in processor card, which also carries the two SO-DIMM sockets for 144-pin SDRAM. The power supply board, analogue/video board and CRT are in the upper housing; power runs from the power supply board through a power filter board to the logic board.[1] Apple introduced "Version 2" analogue/video and power supply boards, CRTs and cables that are not interchangeable with the originals, so exchange like for like.[1]
Slot-loading models
A single power/analog/video board drives the CRT and supplies trickle power. The down converter board, attached to the logic board, produces the +12 V, +5 V and +3.3 V rails, and the logic board and down converter board come out of the machine together. A PMU microcontroller handles power, sleep, PRAM and the clock, powered from the logic board battery when the machine is unplugged.[2] Memory is two PC100 DIMMs behind a door in the bottom of the case; there is no soldered system RAM, so the machine will not run with both slots empty.[2][11]
Clock battery
Apple's specification pages give a 3.6 V lithium cell.[3][7] On the slot-loading models a good battery reads 3.3 to 3.7 V; below 3.2 V, replace it and reset the PMU.[2]
Common problems
  • No power, a CRT that does not light, or a machine that switches off after the chime: work through Apple's power tests on iMac G3 Troubleshooting.
  • Error beeps instead of a chime: memory, including EDO modules fitted by mistake, or the boot ROM.[1]
  • A PMU that crashes and drains the battery in days on slot-loading models.[2]
  • The inner bezel of slot-loading models is brittle and can break into pieces when the case is opened; MacEffects makes a replacement.[12]
Maintenance and repair
A slot-loading iMac G3 in Indigo (katz2110, Wikimedia Commons, CC BY 2.0)
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Apple Computer, iMac Service Source (tray-loading models), hosted here as File:iMac G3 tray-loading Service Source.pdf (see iMac G3 Service Source (tray-loading)). PDF page numbers: Standard Configurations pp. 19-20; Model Comparison pp. 21-25; Memory pp. 62-66; Testing for Power pp. 86-91; Power-On Self Test p. 94; Take Apart pp. 126-256; Adjustments pp. 270-295.
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Apple Computer, iMac (Summer 2001) Service Source, hosted here as File:iMac G3 Summer 2001 Service Source.pdf (see iMac G3 Service Source (Summer 2001)). PDF page numbers: What's New pp. 3-6; SDRAM DIMM pp. 17-19; Logic Board p. 44; Power/Analog/Video Board pp. 81-98; Testing for Power pp. 135-139; PMU pp. 140-141; Logic Board Battery p. 143.
  3. ↑ 3.0 3.1 Apple, "iMac - Technical Specifications" (retrieved 2026-10-02). Introduced 8/15/1998; G3 at 233 MHz; 512K backside cache; two SO-DIMM slots, 32-128 MB; 80 W; 3.6 V lithium battery; 15.8 × 15.2 × 17.6 in, 40 lb.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 Wikipedia, "iMac G3" (retrieved 2026-10-02). Release dates of the revised Bondi Blue, slot-loading, Summer 2000, Early 2001 and Summer 2001 models; DV and DV+ models; Flower Power and Blue Dalmatian patterns. Used for dates and history only.
  5. ↑ Apple, "iMac (266 MHz) - Technical Specifications" (retrieved 2026-10-02). Introduced 1/5/1999, discontinued 4/15/1999; five colours.
  6. ↑ Apple, "iMac (333 MHz) - Technical Specifications" (retrieved 2026-10-02). Introduced 4/15/1999, discontinued 10/7/1999.
  7. ↑ 7.0 7.1 7.2 Apple, "iMac (Slot Loading) - Technical Specifications" (retrieved 2026-10-02). Introduced 10/4/1999, discontinued 7/19/2000; G3 at 350 or 400 MHz; two PC100 DIMM slots, 64-512 MB; VGA and two FireWire ports on DV and Special Edition; 150 W; 3.6 V lithium battery.
  8. ↑ 8.0 8.1 Apple, "iMac (Summer 2000) - Technical Specifications" (retrieved 2026-10-02). Introduced 7/19/2000, discontinued 2/22/2001; 350 to 500 MHz; up to 1 GB in two PC100 DIMM slots.
  9. ↑ Apple, "iMac (Early 2001) - Technical Specifications" (retrieved 2026-10-02). 400, 500 or 600 MHz; 512K backside or 256K on-chip L2 cache; two DIMM slots to 1 GB; Rage 128 Pro or Rage 128 Ultra.
  10. ↑ Apple, "iMac (Summer 2001) - Technical Specifications" (retrieved 2026-10-02). 500, 600 or 700 MHz with 256K L2; two DIMM slots to 1 GB; Rage 128 Ultra with 16 MB; 15-inch shadow-mask CRT, 13.8-inch viewable.
  11. ↑ Apple Computer, Apple Memory Guide (May 2000), hosted here as File:Apple Memory Guide (May 2000).pdf (see Apple Memory Guide). Power Macintosh pp. 28 and 32: original iMac (PDF p. 92); slot-loading iMac, DV and DV Special Edition (PDF p. 96).
  12. ↑ TinkerDifferent forum thread "iMac G3 service and rebuild (with MacEffects inner bezel)", August 2025 (retrieved 2026-10-02). Community repair report. Secondary source.
