Macintosh Classic Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh Classic is essential for restoring power stability, ensuring clean video output, and preventing long-term damage due to capacitor leakage. This guide outlines the recommended procedure and provides complete analog and logic board capacitor specifications.
๐ Capacitor Inspection
- Bulging Tops โ Swollen or domed caps indicate internal gas buildup.
- Electrolyte Leakage โ Brown/white crust or residue near leads shows capacitor failure.
- Corroded Pads or Traces โ PCB staining or corrosion suggests leakage damage.
๐ Macintosh Classic Capacitor List
๐งฏ Analog Board Capacitors
The Macintosh Classic analog board has several capacitors that may require replacement. Due to variations in board revisions, consult the specific schematic for your model. Common capacitor values include:
| CF3 | 1000ยตF | 16V | 1x |
| CF4 | 470ยตF | 25V | 1x |
| CL1 | 1000ยตF | 25V | 1x |
| CL2 | 4.7ยตF | 250V | 1x |
| CL3 | 1ยตF | 50V | 1x |
| CP1 | 220ยตF | 250V | 1x |
| CP10 | 470ยตF | 25V | 1x |
| CP11 | 220ยตF | 50V | 1x |
| CP12 | 1000ยตF | 16V | 1x |
| CP13 | 220ยตF | 250V | 1x |
| CP2 | 470ยตF | 50V | 1x |
| CP34 | 1ยตF | 50V | 1x |
| CP36 | 2200ยตF | 10V | 1x |
| CP4 | 47ยตF | 25V | 1x |
| CP5 | 1ยตF | 50V | 1x |
| CP6 | 2200ยตF | 10V | 1x |
| CP7 | 1000ยตF | 10V | 1x |
| CP8 | 2200ยตF | 16V | 1x |
| CP9 | 470ยตF | 25V | 1x |
| CV2 | 470ยตF | 10V | 1x |
| CP3 | 10ยตF | 25V | 1x |
| CP37 | 1ยตF | 50V | 1x |
| CL11 | 47ยตF | 16V | 1x |
| CF2 | 220ยตF | 16V | 1x |
| CF1 | 47ยตF | 25V | 1x |
- Note: Capacitor labels and values may vary between board revisions. Always verify with your specific board.*
๐ง Logic Board Capacitors
The Macintosh Classic logic board contains surface-mount electrolytic capacitors prone to leakage and corrosion.
| C1 โ C7 | 47ยตF | 16V | 7x |
| C8 | 1ยตF | 50V | 1x |
- Note: When replacing with tantalum capacitors, consider using 25V rated caps for the 47ยตF positions to ensure longevity.*
๐ ๏ธ Capacitor Replacement Procedure
- Discharge the CRT โ Follow standard CRT discharge procedures before working inside.
- Remove the Logic & Analog Boards โ Label cables and safely extract both boards.
- Desolder Old Capacitors โ Use a quality soldering iron, braid, or pump to remove components cleanly.
- Clean the Board โ Thoroughly clean any electrolyte residue with isopropyl alcohol.
- Install New Capacitors โ Insert with correct polarity (check for stripe on negative side).
- Solder Carefully โ Ensure clean, shiny joints without cold solder bridges.
- Trim Leads & Inspect Work โ Cut excess and examine under light or magnification.
- Test for Shorts โ Use a multimeter to confirm there are no shorts across power rails.
๐งฐ Recommended Tools
- Desoldering braid or vacuum pump
- Quality leaded solder (0.5 mm recommended)
- Isopropyl alcohol and ESD brush
- Multimeter
- Safety goggles and insulated gloves
โ๏ธ Voltage Adjustment After Recap
- +5V rail: 4.90V โ 5.15V
- +12V rail: 11.9V โ 12.7V
Use the analog board's trimmer potentiometer (R56) to fine-tune if necessary.
๐ก Tips for Best Results
- Always recap the logic board first โ leaking caps often cause corrosion damage.
- Use quality capacitors (e.g., Nichicon, Panasonic, Rubycon).
- Turn on the system periodically to prolong capacitor lifespan.
- Replace in full sets for even aging and reliability.
- Clean the board thoroughly with isopropyl alcohol after removal.
