Macintosh Classic II Capacitor Replacement Guide
Revision as of 16:03, 19 April 2025 by Josh (talk | contribs) (Created page with "{{Infobox computer | name = Macintosh Classic II | image = 250px | manufacturer = Apple Computer, Inc. | type = Personal Computer | release_date = October 15, 1991 | discontinued = September 15, 1993 | price = US$1,000 – 1,300 | cpu = Motorola 68000 @ 8 MHz | memory = 1 MB RAM (expandable to 4 MB) | storage = 800 KB 3.5″ floppy drive | display = 9″ monochrome CRT (...")
TypePersonal Computer
ReleasedOctober 15, 1991
DiscontinuedSeptember 15, 1993
Intro priceUS$1,000 – 1,300
CPUMotorola 68000 @ 8 MHz
Memory1 MB RAM (expandable to 4 MB)
Storage800 KB 3.5″ floppy drive
Display9″ monochrome CRT (512×342)
SoundMonaural, 8‑bit
Dimensions13.6″ H × 9.6″ W × 10.9″ D
Weight17.6 lbs (8.0 kg)
OS / FirmwareSystem 6.0.7 – System 7.5.5
PredecessorMacintosh Classic
SuccessorMacintosh Color Classic
Codename“Holborn”
Model no.M0100
Replacing electrolytic capacitors (recapping) in your Macintosh Classic II is essential for restoring power stability, ensuring clean video output, and preventing long‑term damage due to leakage. This guide outlines the recommended procedure and provides complete analog and logic board capacitor specifications.
🔍 Capacitor Inspection
  • Bulging Tops – Swollen or domed caps indicate internal gas buildup.
  • Electrolyte Leakage – Brown/white crust or residue near leads shows failure.
  • Corroded Pads or Traces – PCB staining or corrosion suggests damage.
If any symptoms are present, immediate replacement is advised.
📋 Macintosh Classic II Capacitor List
🧯 Analog Board Capacitors
The Classic II shares its analog board with the Classic. Due to board revisions, labels may vary—always verify against your schematic.
Macintosh Classic I + II Analog Board Capacitor Specifications
Label Capacitance Voltage Qty
CF3 1000 µF 16 V 1
CF4  470 µF  25 V  1
CL1  1000 µF  25 V  1
CL2  4.7 µF  250 V  1
CL3  1 µF  50 V  1
CP1  220 µF  250 V  1
CP10  470 µF  25 V  1
CP11  220 µF  50 V  1
CP12  1000 µF  16 V  1
CP13  220 µF  250 V  1
CP2  470 µF  50 V  1
CP34  1 µF  50 V  1
CP36  2200 µF  10 V  1
CP4  47 µF  25 V  1
CP5  1 µF  50 V  1
CP6  2200 µF  10 V  1
CP7  1000 µF  10 V  1
CP8  2200 µF  16 V  1
CP9  470 µF  25 V  1
CV2  470 µF  10 V  1
CP3  10 µF  25 V  1
CP37  1 µF  50 V  1
CL11  47 µF  16 V  1
CF2  220 µF  16 V  1
CF1  47 µF  25 V  1
  • Note: Values may vary between revisions—always cross-check your board.*
Macintosh Classic II Analog Board Recap Diagram [1]
🔧 Logic Board Capacitors
Two logic board revisions exist—Rev A has 13 caps, Rev B has 17.
Logic Board Capacitor Specifications
Revision Value Voltage Qty
Rev A  47 µF  16 V  3
 10 µF  16 V  8
 1 µF  50 V  2
Rev B  47 µF  16 V  3
 10 µF  16 V  12
 1 µF  50 V  2
  • Tip: If substituting tantalum, choose 25 V ratings for the 47 µF positions.*
File:MacintoshClassicII LogicBoardRecap.jpg
Macintosh Classic II Logic Board Recap Diagram [2]
🛠️ Capacitor Replacement Procedure
  1. Discharge the CRT – Follow standard CRT discharge steps before opening the case.
  2. Remove the Boards – Label connectors; carefully extract the logic and analog boards.
  3. Desolder Old Caps – Use a temperature‑controlled iron with braid or pump for clean removal.
  4. Clean the PCB – Remove all electrolyte residue with 99 % IPA and an ESD‑safe brush.
  5. Install New Caps – Observe polarity (negative stripe); seat flush to the board.
  6. Solder Carefully – Aim for shiny, sloped joints; avoid cold bridges.
  7. Trim Leads & Inspect – Cut excess lead length and check with magnification.
  8. Test for Shorts – Verify with a multimeter across each power rail.
  • Temperature‑controlled soldering iron (fine tip)
  • Desoldering braid or vacuum pump
  • Leaded solder, ~0.5 mm diameter
  • 99 % isopropyl alcohol & ESD‑safe brush
  • Multimeter
  • Safety goggles & insulated gloves
⚙️ Voltage Adjustment After Recap
With boards reinstalled, measure at the floppy‑drive power pins:
  • +5 V rail: 4.90 – 5.15 V
  • +12 V rail: 11.9 – 12.7 V
Use the analog board’s variable resistor (PP1) to fine‑tune.
💡 Tips for Best Results
  • Recap the logic board first—its leakage often damages the analog side.
  • Use top‑tier caps (Nichicon, Panasonic, Rubycon).
  • Power on the machine periodically after recap to “exercise” new caps.
  • Replace complete sets for uniform aging and reliability.
  • Always clean the board thoroughly post‑recap.
  1. ↑ ​:contentReference[oaicite:0]{index=0}
  2. ↑ ​:contentReference[oaicite:1]{index=1}
