Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
Recent changes optionsShow last 50 | 100 | 250 | 500 changes in last 1 | 3 | 7 | 14 | 30 days
Hide registered users | Hide anonymous users | Hide my edits | Show bots | Hide minor edits
Show new changes starting from 18:54, 23 September 2026
Page name:
List of abbreviations:
N
This edit created a new page (also see list of new pages)
m
This is a minor edit
b
This edit was performed by a bot
(±123)
The page size changed by this number of bytes
23 September 2026
     18:18  Macintosh Classic II diffhist −1,624 Josh talk contribs (Rebuilt against Apple Classic/Classic II/Performa 200 Service Source: DELETED fabricated memory map, V8 Lite/MEMCjr chipset claims, 53C96 and Egret attributions, ROM module table, MacBench comparison table, Paris codename/Eiffel silkscreen, JP3 debug jumper and the cold-start easter egg; SIMM speed 80ns -> 120ns or faster, single SIMM claim corrected to a pair, dimensions/weight/model number corrected; region-specific analogue board warning added; release_date parameter fixed; refs and reflist)
     18:12  Macintosh Classic / Classic II General Maintenance 2 changes history +2,109 [Josh (2×)]
18:12 (cur | prev) +1,639 Josh talk contribs (Sourced to Apple Classic/Classic II/Performa 200 Service Source: battery 3.0V threshold and lithium chemistry (bicarbonate not vinegar), DELETED invented maintenance intervals, added Apple eight-chip SIMM rule and jumper check, noted Dead Mac Scrolls does not cover these models, refs and reflist)
01:47 (cur | prev) +470 Josh talk contribs (Removed unsourced rail tolerance table (+5V 4.90-5.15, +12V 11.9-12.7) and the R56 trimmer adjustment: Apple's Classic/Classic II Service Source publishes no rail figures and its Adjustments chapter covers video only. Added Apple's actual Electrical spec (100-120 VAC, 47-63 Hz, 100 W max))
     02:15  Capacitor Failure Symptoms 2 changes history +12,684 [Josh (2×)]
02:15 (cur | prev) −40 Josh talk contribs (Remove self-referential wording per house rule)
02:07 (cur | prev) +12,724 Josh talk contribs (Rewrite with full citations (Nichicon CAT.8101H hosted here, Vishay 40110, KEMET F3011): corrected 60 Hz hum to twice mains frequency, corrected bulging mechanism to Nichicon gas generation, added missing film/X2 suppression section, added tantalum derating 60-50 percent, added Class II ceramic DC-bias behaviour, replaced Japanese-brand rule with no-datasheet-no-purchase, replaced IPA-only cleanup with Nichicon soap-and-water plus never acidic/alkaline, replaced reforming folklore with Nichic...)
     02:15  CRT Discharge Procedure 2 changes history +11,081 [Josh (2×)]
02:15 (cur | prev) −45 Josh talk contribs (Remove self-referential wording per house rule)
02:05 (cur | prev) +11,126 Josh talk contribs (Rewrite against Apple Service Guide 1990 and Goldwasser CRT notes: corrected earth-return point (ground lug, never logic board), added never-wear-a-wrist-strap rule and implosion/goggles hazard, replaced unsourced 25 kV blanket with sourced per-class figures, replaced dead-short tool with resistive tooling, removed invented 30-min wait / 10-s hold / 10-15-min re-discharge interval, added ongoing shorting lead and aquadag mechanism; full ref citations)
     01:47  Macintosh Classic / Classic II Troubleshooting diffhist +392 Josh talk contribs (Removed unsourced rail tolerance figures (+5V 4.90-5.10, +12V 11.9-12.7): Apple's Classic/Classic II Service Source publishes no rail voltages. Replaced with Apple's actual Electrical spec and a sourced +-5% logic-supply check)
     01:36  Battery Explosion, Capacitor or Corrosion Damage diffhist +12,961 Josh talk contribs (Verification drive: corrected chemistry (Li-SOCl2 half-AA neutralised with bicarbonate not IPA/water; capacitor electrolyte washed not neutralised - no published pH); added cadmium hazard for NiCd; added damaged-cell handling section incl. accurate lithium fire guidance; fixed +5V range 4.75-5.25 V; corrected United Chemi-Con/Nippon Chemi-Con and OS-CON/Panasonic; removed arbitrary '100 ohm' rail threshold and Kapton '400C' claim; added IEC 60086-1 cell designations; all figures now <ref>-cit...)
21 September 2026
     21:50  Battery Explosion, Capacitor or Corrosion Damage diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source)
