Sega CD (Model 1)
Revision as of 11:18, 27 April 2025 by Josh (talk | contribs)
Sega CD Model 1 ("Front-Loader")
North-American Sega CD Model 1 attached to an early VA2 Genesis Model 1
ManufacturerSega Enterprises Ltd.
Optical block by Sony (KSS-240A/KSS-240R)
TypeCD-ROM add-on console
ReleasedDecember 12, 1991 (JP Mega-CD)
October 15, 1992 (US Sega CD)
May 1, 1993 (EU Mega-CD)
Discontinued1994 (superseded by Side-loader & Model 2)
Intro priceJP ยฅ49 800 โ€ข US US$299 โ€ข EU ยฃ270
CPUMotorola MC68EC000 @ 12.500 MHz (primary)
Sega ASIC โ€œSCD ASICโ€ with embedded 68000 bus arbiter & rotation/scale unit
Memory768 KB Word-RAM (dual-ported)
512 KB Program RAM
64 KB Back-up RAM (SRAM, battery)
128 KB PCM sample RAM
Storage1ร— 1 ร—-speed CD-ROM (150 kBยทsโปยน)
internal back-up RAM (32 KB user-accessible)
Display320 ร— 224 / 256 ร— 224 px, 5-bit RGB, 128 sprites (Genesis VDP)
SoundGenesis PSG & YM2612 FM plus Ricoh RF5C164 8-ch PCM @ 32 kHz โ€ข 10-bit DAC
Dimensions294 mm W ร— 212 mm D ร— 80 mm H
Weightโ‰ˆ 2.0 kg (drive + PSU shielding)
OS / FirmwareMega CD System ROM v1.x (128 KB mask ROM)
Predecessorโ€“ (first Sega optical system)
SuccessorSega CD (Model 2) / Wondermega / CDX
CodenameTMR-50 (Japan R&D), โ€œTopazโ€ (US)
Model no.HAA-2910 (JP), MK-1601 (US), MK-1690-50 (EU)
The Sega CD Model 1 โ€“ marketed in Japan as the Mega-CD โ€“ is the original front-loading compact-disc add-on for the Sega Mega_Drive / Genesis Model 2. Released in late 1991, it augmented the base console with a faster 12.5 MHz 68EC000, hardware scaling/rotation ASICs, 8-channel PCM audio and the ability to stream full-motion video (Cinepak) from CD-ROM.
๐Ÿ•ฐ๏ธ Historical context & sales
  • Concept (1989โ€“1990): Sega R&D2 (Hisashi Suzuki) partnered with Sony Devices Div. to adopt the KSS-240 laser deck.
  • Launch: 12 Dec 1991, JP ยฅ49 800 โ€“ initial shipment 100 k; supply shortages until Feb 1992.
  • US debut: 15 Oct 1992 at US$299 bundled with โ€˜โ€™Sewer Sharkโ€™โ€™ (first US CD-ROM pack-in).
  • Total Model 1 units: โ‰ˆ 600 k worldwide (of 2.2 M total Sega CD family).
๐Ÿง  Architecture overview
Sub-system IC(s) Notes
Primary CPU MC68EC000FN12 16-bit, no MMU, bus-master shares Genesis address lines
Scaling / Rotation Sony CXD1161P + CXD1162P 1024ร—1024 pixel source; affine transform to 320ร—224
PCM audio Ricoh RF5C164 (QFP-80) 8 voices, 10-bit DAC, 32 kHz max
CD controller Hitachi HD641709 MCU (a 6301) + Sega CXD1800 drive DSP Sub-CPU executes CD-DA and ISO9660 BIOS
Gate-array Sega 315-5548 (ASIC) Bus control, battery SRAM decode, host port, DMA to word-RAM
RAM 2 ร— OKI M514256 (256 Kร—4) word-RAM
8 ร— HM514170 (64 Kร—4) program-RAM
Dual-port by ASIC
Optical deck Sony PU-18 mech. w/ KSS-240A lens 1 ร— CLV, spindle @ 530 rpm (innermost)
๐Ÿ“Š Technical specification (Model 1, BIOS v1.10)
Processing
12.500 MHz (25 MHz รท 2) wait-stated 3โ€“4 cycles to word-RAM
3.58 MHz (NTSC crystal) โ€“ handles CD block decode, seek, audio FIFO
5.0 MBยทsโปยน peak hostโ‡„word-RAM
Memory map (simplified)
2 MB Program RAM
256 KB Word-RAM bank 0
256 KB Word-RAM bank 1 (dual-port)
PCM regs & sample RAM (128 KB windowed)
Backup SRAM 64 KB (battery)
ASIC / host control regs
Sub-CPU I/O FIFO
BIOS ROM 128 KB (mirrored)
Video timing
  • Pixel clock 13.5 MHz (NTSC) / 13.32 MHz (PAL) via VDP master.
  • Scaled plane generated at 256ร—A & line-buffered into Genesis VDP CRAM.
  • V-blank interrupt every 262 lines NTSC (โ‰ˆ 59.92 Hz).
๐Ÿ”Œ Pin-by-pin expansion bus
The 50-pin edge (CN-B) carries the Genesis 68000 bus plus additional DMA and audio lines:
Pin Dir Name Description
B01 โ†’ /AS Address-strobe
B02 โ† IRQ2 CD raises to interrupt Genesis
B03 bi D0 Data bus (even)
โ€ฆ โ€ฆ โ€ฆ โ€ฆ
B25 โ†’ CDCLK 12.5 MHz clock from Sega CD
B26 โ† EXCLK 7.67 MHz clock from Genesis
B45 โ† AUD-L PCM mixed left
B46 โ† AUD-R PCM mixed right
B49 โ€“ +5 V
โ€“ | GND |
Full table with all 50 pins on Mega Drive expansion port pinout.
๐Ÿ› ๏ธ Known hardware revisions & PCB errata
Assy # Board silk Region Notable changes / bugs Service fixes
171-5978A VA0 JP launch KSS-240A lens, BIOS 1.00 CD door switch mis-adjust โ€“ bend lever
171-5978B VA1 BIOS 1.10, word-RAM wait fix Add R511 pull-up (factory bodge)
171-5978C VA2 CXD1162 rev-C, 315-5548A ASIC 74HC00 (IC15) ESD prone โ€“ replace with HCT
๐Ÿ”ง Common failure points
  • โ€œGREEN LED but no spinโ€ โ€“ blown surface-mount fuse F301 (2 A) or shorted 5 V tantalum C230.
  • Tray wonโ€™t eject / belt slip โ€“ 40 mm ร— 1.2 mm neoprene belt hardened. Replace with 41 mm 0.6 mm square belt.
  • No CD audio โ€“ CXD1162P pin 47 mute line held low; open Q203 (mute transistor) or BIOS stuck (bad RAM).
  • Distorted PCM โ€“ leaking SMD electrolytics around RF5C164: C510 /C511 47 ยตF.
  • โ€œERROR 02โ€ (seek timeout) โ€“ dirty rails, laser current low (VR102 โ‰ˆ 50 mV across TP100/101).
  • Backup RAM corrupt โ€“ CR2032 coin cell dead or IC3 SRM2016 failing.
๐Ÿ”ฉ Service manuals & schematics
  • Sega Service Document #170-0436-01 (download mirrored at SegaRetro).
  • Sony PU-18 optical deck manual (exploded view, focus gain pots).
  • Annotated board scans on github.com/arkagame/mega-cd-archivist.
๐Ÿงฐ General maintenance
Full disassembly, recap lists and belt change procedure: see Sega CD (Model 1) General Maintenance Guide. Capacitor map and polarity silks are on Sega CD (Model 1) Capacitor Replacement Guide.
๐Ÿฉบ Troubleshooting
A step-by-step power-on diagnostic flow (LED blink codes, fuse chart, clock probing) is available on Sega CD (Model 1) Troubleshooting Guide.
๐Ÿ”‰ Audio/Video modifications
  • Direct-mix โ€œboard-jailโ€: lift R171 &R172, route RF5C164 output to Genesis EXT stereo jack โ€“ no crosstalk.
  • RGB bypass: use Genesis VDP RGB; Sega CD adds no extra graphics plane, so standard MD RGB mod applies.
  • 50/60 Hz region switch โ€“ tie ASIC pin 4 โ€˜AREAโ€™ to DIP switch + patch BIOS byte $1FE1.
๐Ÿ“€ Software & homebrew
Model 1 BIOS 1.10 supports CD-R if session is MODE1+CDDA (avoid 40ร— burns). Recommended test suites: โ€˜โ€™Sega CD Test Discโ€™โ€™ by discedge; โ€˜โ€™RAM Stressโ€™โ€™ by Luke Usher.
๐ŸŽฒ Trivia & pop-culture
  • โ€˜โ€™Snatcherโ€™โ€™ (JP) used SCD PCM channels for full Japanese voice acting โ€“ a first on 8 Mbit disc.
  • The launch bundle โ€˜โ€™Sol-Feaceโ€™โ€™ shipped on both cart (JP) and CD; players compared load-times as marketing.
  • In TV series โ€˜โ€™Clarissa Explains It Allโ€™โ€™ (1993) a front-loader Sega CD is visible under the CRT.
