Sega Master System II Capacitor Replacement Guide
Replacing the ageing electrolytic capacitors in your Sega Master System II is a vital preventative measure to ensure stable power delivery, crisp video output, and reliable sound. Decades-old capacitors can cause random crashes, distorted graphics, muted audio, or even prevent the console from powering on. Proactive recapping restores original performance and protects your SMS II from future failures.
๐Ÿ” Visual Inspection & Failure Signs
Before starting, examine all electrolytic capacitors on the motherboard for:
  • Bulging or domed tops โ€“ Indicates internal pressure and imminent failure.
  • Leaking electrolyte โ€“ Brown, white, or green residue at the base or on the PCB.
  • Corrosion or PCB staining โ€“ Darkened or tarnished areas around capacitor pads.
  • Random resets, video glitches, or weak audio โ€“ Often traceable to high-ESR or failed capacitors.
If any capacitor shows these symptoms, replace all electrolytics on the board for long-term reliability.
๐Ÿ“‹ Sega Master System II Capacitor List
The SMS II has a compact mainboard with a modest number of electrolytic capacitors. Values may vary slightly between regional models and board revisions; always cross-check against silkscreen markings.
Sega Master System II Mainboard Electrolytic Capacitors
Ref. Designator Capacitance Voltage Circuit / Function
C1 220 ยตF 16 V Audio output DC-block
C2 1000 ยตF 16 V Main +5 V input filter (bulk smoothing)
C3 100 ยตF 16 V Video encoder supply decoupling
C4 10 ยตF 16 V Reset circuit timing
C5 10 ยตF 16 V VRAM decoupling
C6 10 ยตF 16 V CPU decoupling
C7 1 ยตF 50 V Composite video coupling
C8 22 ยตF 16 V Audio preamp coupling
C9 47 ยตF 16 V RF modulator supply filter
C10 100 ยตF 16 V Power rail decoupling (near VDP)
Some board revisions may omit C9 (RF modulator) or combine C5/C6. Replace all electrolytics present on your specific board.
๐Ÿ› ๏ธ Recapping Procedure
  1. Open the console โ€“ Remove the six screws on the underside and gently lift the top shell.
  2. Remove the mainboard โ€“ Disconnect the controller ports and LED wires if present.
  3. Inspect and note capacitor orientation โ€“ Take reference photos; most are polarised.
  4. Desolder old capacitors โ€“ Use solder wick or a pump; avoid overheating pads.
  5. Clean pads โ€“ Remove old flux and residue with isopropyl alcohol.
  6. Install new capacitors โ€“ Match polarity (long lead = positive), and fit values as per table.
  7. Trim leads and solder โ€“ Ensure clean, shiny joints and no solder bridges.
  8. Reassemble and test โ€“ Power up and check for correct operation.
  • Temperature-controlled soldering iron (15โ€“40 W, fine tip)
  • Desoldering braid or pump
  • High-quality 105 ยฐC, low-ESR radial capacitors (Nichicon, Panasonic, Rubycon)
  • Isopropyl alcohol (99%) and ESD-safe brush
  • Small side-cutters for lead trimming
  • Multimeter (for continuity and voltage checks)
โš™๏ธ Post-Recap Voltage & Signal Checks
After reassembly, verify the following at the mainboard test points or cartridge slot (console powered on, no cartridge):
Expected Rails โ€“ Sega Master System II
Test Point Expected Value Max Ripple (p-p)
+5 V (main regulator output) 4.90 โ€“ 5.10 V < 50 mV
Composite video (pin 1, AV out) 1.0 V p-p (with colour bar test) Clean, no hum
Audio out (pin 2, AV out) 0.5โ€“1.0 V p-p (with game sound) No buzz or distortion
If you observe visible video noise, hum on audio, or voltage sag below 4.85 V, re-check capacitor polarity and solder joints.
๐Ÿ’ก Extra Tips
  • Use the correct polarity! Electrolytic capacitors are polarised; reversing them can damage the SMS II.
  • Keep capacitor height โ‰ค 13 mm to avoid fouling the top shell.
  • Replace the power supply capacitors if using the original Sega โ€œbrickโ€ โ€“ these are now over 30 years old.
  • Clean up any electrolyte residue thoroughly to prevent future corrosion.
  • Test with a known-good game after recapping to confirm full functionality.
  • Label removed screws and cables for easier reassembly.
