The Sega Dreamcast is a home video game console released by Sega in late 1998 in Japan and worldwide in 1999. As Sega's final console, it introduced several innovations, including built-in modem support for online play and a versatile architecture aimed at both arcade and home gaming.
Sega Dreamcast
Sega Dreamcast console, controller, and VMU
ManufacturerSega
TypeHome video game console
Released27 November 1998 (JP); 9 September 1999 (NA); 14 October 1999 (EU); 30 November 1999 (AU)
Discontinued31 March 2001 (hardware)
Intro priceJP¥29,000 (JP launch); US$199 (NA launch)
CPUHitachi SH-4 RISC @ 200 MHz
Memory16 MB main RAM, 8 MB video RAM, 2 MB sound RAM
StorageGD-ROM (1.2 GB), VMU flash memory (128 KB)
Display640×480 pixels, 16.77 million colours (24-bit), VGA output supported
SoundYamaha AICA, 64-channel PCM/ADPCM, 32-bit ARM7 @ 45 MHz
Dimensions190 mm × 195 mm × 76 mm
Weight1.5 kg
OS / FirmwareSega OS (Katana SDK), custom middleware
PredecessorSega Saturn (Model 2)
CodenameKatana
Model no.HKT-3000 (JP/NA/EU/AU)
🧠 Architecture and Processor
At its core, the Dreamcast is powered by a Hitachi SH-4 32-bit RISC CPU running at 200 MHz, delivering 360 MIPS and 1.4 GFLOPS. The SH-4 features a superscalar architecture with a 128-bit SIMD DSP for fast floating-point operations, making it well-suited for 3D graphics and arcade-quality games.
The system’s graphics are handled by the PowerVR2 CLX2 GPU, developed by NEC and VideoLogic, capable of hardware transform and lighting, bump mapping, anti-aliasing, and order-independent transparency.
💾 Memory and Storage
The Dreamcast’s memory subsystem comprises:
  • 16 MB 64-bit main RAM
  • 8 MB video RAM (VRAM)
  • 2 MB sound RAM (AICA)
For storage, the Dreamcast uses proprietary GD-ROM discs (1.2 GB capacity), providing more space than standard CDs. Save data is stored on VMU (Visual Memory Unit) memory cards, each with 128 KB flash memory, which also function as mini-game devices and secondary screens.
🖥️ Display and Graphics
The graphics subsystem is built around the PowerVR2 CLX2 GPU, offering:
  • 640×480 pixels maximum resolution (progressive scan)
  • 16.77 million colours (24-bit RGB)
  • VGA output (via optional cable), S-Video, composite, and RGB SCART (region dependent)
  • Advanced features: hardware Z-buffering, anti-aliasing, environment mapping, and real-time texture decompression
The GPU can render approximately 3–5 million polygons per second in real-world scenarios, enabling arcade-quality visuals.
🔊 Sound Capabilities
Audio is managed by the Yamaha AICA sound processor, which includes:
  • 64 hardware channels (PCM/ADPCM)
  • 32-bit ARM7 RISC CPU @ 45 MHz dedicated to audio tasks
  • 2 MB dedicated sound RAM
  • 44.1 kHz/48 kHz stereo output, with real-time effects and MIDI synthesis
This architecture allows for complex soundtracks, voice samples, and immersive sound effects.
🎮 Input/Output and Expansion
The Dreamcast features a range of I/O and expansion options:
  • Four controller ports for standard controllers, light guns, arcade sticks, and other peripherals
  • Visual Memory Unit (VMU) slots in each controller for save data, mini-games, and status displays
  • Built-in 56k modem (RJ-11) for online multiplayer and web browsing (10BASE-T LAN adapter available in Japan)
  • AV output supporting composite, S-Video, RGB, and VGA (with adapter)
  • Serial expansion port (for link cable, debugging, or broadband adapter)
  • Optional peripherals: keyboard, mouse, microphone, camera, and more
🔍 PCB Schematics & Service Manual
Mainboard Mainboard Schematic
Sega Dreamcast mainboard
Dreamcast Power Supply Unit
The Dreamcast’s mainboard integrates the SH-4 CPU, PowerVR2 GPU, AICA sound processor, and RAM. The power supply board is a separate, easily replaceable module. Official service manuals and schematics are available via Sega Dreamcast Service Manual (PDF) and enthusiast resources.
