Macintosh Plus Capacitor Replacement Guide
Revision as of 12:54, 12 March 2025 by Josh (talk | contribs) (Created page with "Replacing electrolytic capacitors (recapping) in your Macintosh Plus is crucial for ensuring reliability, stable voltages, and a crisp video image. Due to age, capacitors can dry out, leak, or lose effectiveness. === Capacitor Inspection === Regularly inspect capacitors for these signs of failure: * '''Bulging Tops''': A dome-shaped or expanded capacitor top. * '''Leaking electrolyte''': Brownish or white crust near capacitor leads. * '''Corrosion''': Discoloration or...")
  • Bulging Tops: A dome-shaped or expanded capacitor top.
  • Leaking electrolyte: Brownish or white crust near capacitor leads.
  • Corrosion: Discoloration or corrosion on the PCB around capacitors.
File:MacintoshPlus CapacitorFailure.jpg
Typical capacitor failures
Capacitor List
Replace all major capacitors proactively to prevent potential failures. Here is the detailed list:
Analog Board Capacitors
  • C1: 3.9µF 35 V non-polarized (recommended replacement: 4.7µF 100V non-polar film capacitor)
  • Main Filter Capacitor: 4700µF (270 V rating, axial)
  • High-voltage Capacitors: 10µF (160 V)
  • Medium-value Capacitors: 22µF, 33µF, 47µF (typically 16–50 V)
Analog board capacitor locations
Logic Board Capacitors
The logic board rarely needs recapping but if done, these capacitors are required:
  • 5x 33µF (16 V axial capacitors)
  • 1x 1µF (50 V axial capacitor)
File:MacintoshPlus RecapProcess.jpg
Desoldering capacitors safely
  1. CRT Safety: Fully discharge the CRT and ensure the system is unplugged.
  2. Disassembly: Remove analog board carefully, noting connector placements.
  3. Desoldering: Carefully desolder old capacitors, using a solder sucker or braid.
  4. Replacement: Install new capacitors with correct polarity (observe + and - markings).
  5. Soldering: Solder the new capacitor leads and trim excess lead length.
  6. Inspection: Check all solder joints to confirm clean, secure connections.
  7. Final Check: Verify no shorts between power rails with a multimeter before powering on.
  • Soldering iron (temperature-controlled recommended)
  • Desoldering pump or braid
  • Multimeter (for voltage verification)
  • Anti-static brush, isopropyl alcohol
  • Safety glasses and insulated gloves
File:MacintoshPlus RepairTools.jpg
Tools for recapping
Voltage Adjustment Post-Recap
After recapping, verify and adjust voltages for optimal stability:
  • +5 V Line: Should measure between 4.85 V–5.15 V
  • +12 V Line: Should measure around 11.9–12.7 V
  • Adjust using the trim potentiometer (R56) on the analog board as needed.
File:MacintoshPlus VoltageAdjustment.jpg
Adjusting voltage on the analog board
Additional Tips
  • Periodically power on the Macintosh Plus to maintain capacitor health.
  • Always dispose of old capacitors responsibly.
