Apple Desktop Bus Mouse
| Apple Desktop Bus Mouse | |
| Apple Desktop Bus Mouse (Model M0142) | |
| Type | Pointing device |
| Discontinued | January 1993 |
| Price | US$119 (retail) |
| Interface | Apple Desktop Bus |
| Compatible | Apple IIGS, Macintosh SE, Macintosh II, all ADB-equipped Macs |
| Dimensions | 93 mm L × 61 mm W × 36 mm H |
| Weight | 175 g (6.2 oz) |
| Predecessor | Apple Mouse (DE-9) |
| Successor | Apple Desktop Bus Mouse II |
| Model | M0142, G5431, A9M0331 |
The Apple Desktop Bus Mouse was the first mouse designed for the Apple Desktop Bus (ADB) interface, introduced in September 1986 with the Apple IIGS. Released alongside Apple's transition from proprietary connectors to the standardized ADB system, it became the standard mouse for Macintosh computers from the Macintosh SE and Macintosh II through early 1993. The mouse retained the angular, blocky design of its DE-9 predecessor but adopted the Snow White design language with uniform Platinum gray coloring.
Model Variants
Three model numbers were assigned to the Apple Desktop Bus Mouse during its production run:
- A9M0331 – Original model introduced with the Apple IIGS (September 1986)
- G5431 – Version bundled with Macintosh II and SE (March 1987)
- M0142 – Consolidated model number used from 1988-1993
Despite different model numbers, all variants were functionally identical. Manufacturing occurred in Taiwan (early models), Ireland, and later Singapore facilities.
Design & Construction
Physical Characteristics
The ADB Mouse maintained the rectangular footprint of earlier Apple mice but featured a lower, triangular profile measuring 93mm × 61mm × 36mm. The single button spanned the entire front section of the mouse, providing a large clicking surface. The case was injection-molded ABS plastic in Apple's standard Platinum gray (Pantone 423C), with only the cable and connector retaining the darker "Smoke" gray color.
Internal Components
The mouse utilized mechanical ball tracking with the following key components:
- Tracking mechanism: 19mm rubber-coated steel ball
- Optical encoders: Two perpendicular slotted wheels with infrared LED/phototransistor pairs
- Controller chip: Various manufacturers including:
- Mitsumi custom ADB controller
- Logitech 42c60p5625
- IC Designs custom ASIC
- Microswitch: Omron D2F series rated for 1 million clicks
- Circuit board: Single-sided PCB with through-hole components
Manufacturing Variations
Two primary internal designs existed:
Taiwan/Singapore manufacture:
- Single consolidated PCB
- Integrated controller chip
- Cost-reduced component count
Ireland manufacture:
- Dual PCB design (main board + switch board)
- Discrete logic implementation
- Higher component quality
Technical Specifications
ADB Interface
The Apple Desktop Bus Mouse communicated using the ADB protocol over a 4-pin mini-DIN connector:
| Pin | Signal | Description |
| 1 | ADB Data | Bidirectional serial data line |
| 2 | PSW | Power switch signal (unused on mouse) |
| 3 | +5V | Power supply (100mA max draw) |
| 4 | GND | Ground reference |
Communication Protocol
- Data rate: Up to 125 kbit/s theoretical (typically 10-50 kbit/s)
- Bit encoding: Self-clocking duty cycle modulation
- Logic 0: Low 65μs, High 35μs
- Logic 1: Low 35μs, High 65μs
- Default address: $3 (reassignable via bus enumeration)
- Polling rate: ~100 Hz typical
Device Registers
The ADB Mouse implemented standard ADB register functionality:
- Register 0: Mouse movement data (2 bytes)
- Byte 0: Button state (bit 7) + X movement delta
- Byte 1: Button state (bit 7) + Y movement delta
- Register 1: Reserved (unused)
- Register 2: Reserved (unused)
- Register 3: Device identification and address
- Default handler ID: $01 (standard mouse)
Tracking Performance
- Resolution: 100 counts per inch (CPI)
- Maximum tracking speed: 10 inches/second
- Sampling rate: Mechanical encoder dependent (~200 Hz)
ADB System Architecture
The Apple Desktop Bus represented a major shift in Apple's peripheral connectivity strategy. Key features included:
- Multi-device support: Up to 16 devices on a single bus
- Daisy-chaining: Devices could be connected in series
- Hot-swapping: Theoretical support (not recommended on most systems)
- Power distribution: Bus supplied up to 500mA at 5V total
- Collision detection: Automatic address conflict resolution
The mouse typically operated at address $3, with the keyboard at address $2. During system initialization, the ADB Manager would enumerate devices and resolve any address conflicts through a sophisticated random address generation scheme.
Common Modifications
Two-Button Conversion
Enthusiasts discovered that most ADB controller chips included support for a second button, though Apple never implemented it. Common modifications included:
- Identifying the unused second button pin on the controller chip
- Adding a tactile switch connected to this pin and ground
- Modifying the case to accommodate the additional button
- Software support via third-party control panels
Optical Sensor Upgrade
Modern retrofit kits allow replacement of the mechanical ball system with optical tracking:
- TT Design's ADB Optical Mouse Retro Board
- Uses RP2040 microcontroller with modern optical sensor
- Maintains original 100 CPI default with adjustable settings
- Compatible with original ADB protocol and timing
Maintenance & Repair
Cleaning Procedure
Regular maintenance was essential for reliable operation:
- Remove the retaining ring on the bottom of the mouse
- Extract the tracking ball
- Clean ball with isopropyl alcohol
- Remove lint and debris from encoder wheels using compressed air
- Clean encoder wheel surfaces with cotton swab and IPA
- Reassemble in reverse order
Common Failures
- Erratic cursor movement: Dirty encoder wheels or worn ball
- Button failure: Worn microswitch (replaceable with D2F series)
- Intermittent connection: Broken wires at cable strain relief
- Complete failure: ADB controller chip damage (often from hot-swapping)
ADB Port Safety
The ADB port lacked proper protection against hot-swapping on most systems. Connecting or disconnecting devices while powered could blow the ADB fuse on the motherboard, requiring professional repair or fuse replacement.
Historical Context
The Apple Desktop Bus Mouse marked several important transitions:
- First ADB peripheral: Introduced the new connection standard alongside the Apple IIGS
- Design language shift: Fully embraced Snow White industrial design
- Manufacturing globalization: Production spread across multiple facilities worldwide
- Extended compatibility: Worked with all ADB-equipped systems through 1999
Production estimates suggest over 4 million units manufactured during its 6.5-year production run.
Software Compatibility
System Software
- Apple IIGS: GS/OS with built-in mouse driver
- Macintosh: System 3.2 through Mac OS 9.2.2
- Third-party: MouseKeys, QuicKeys, and other enhancement utilities
Control Panels
- Mouse control panel: Tracking speed adjustment (System 6.0+)
- CloseView:: Cursor size and visibility options
- Third-party tools: Added acceleration curves and button customization
Collector Information
Identification
- Early models (1986-1988): Larger printed label with two screws
- Later models (1988-1993): Smaller label with single center screw
- Serial number format:: First letter indicates year, second indicates country
Condition Assessment
- Case yellowing: Common due to brominated flame retardants or UV light
- Cable integrity: Check for cracks at strain relief points
- Mechanical wear: Test ball retention and encoder wheel movement
- Button feel: Should have distinct tactile feedback
Modern Usage
- ADB-to-USB converters: Griffin iMate (discontinued), Wombat adapter
- Retrobrighting: Possible but risky for painted Platinum plastic
- Replacement parts: NOS balls and microswitches still available
