Apple Desktop Bus
Revision as of 14:28, 6 September 2025 by Josh (talk | contribs)
Apple Desktop Bus
ADB connector (female socket)
Type Computer peripheral interface
Designer Steve Wozniak
Design date 1985-1986
Manufacturer Apple Computer
Production 1986-1999
Superseded USB
External Yes
Hot-pluggable Technically capable but not recommended
Cable 4-conductor shielded
Pins 4
Connector Mini-DIN 4 (same as S-Video)
Electrical Single data line, open collector
Maximum devices 16
Protocol Serial, self-clocking
Data signal Bidirectional serial
Data rate 10-125 kbit/s
Style Serial
Apple Desktop Bus (ADB) is a proprietary bit-serial peripheral bus connecting low-speed input devices to computers. Designed by Steve Wozniak and introduced on the Apple IIGS in September 1986, ADB was created to provide a simple, low-cost method for connecting keyboards, mice, and other input devices in a daisy-chain configuration without requiring hubs. The technology was quickly adopted for the Macintosh line beginning with the Macintosh SE and Macintosh II in March 1987, and remained Apple's standard peripheral interface until its replacement by USB in 1998-1999.
History and Development
Origins
During the early development of the Macintosh in the 1980s, Apple engineers had selected the sophisticated Zilog 8530 for serial communications. However, this solution was expensive and complex for simple input devices. Steve Wozniak, working on the Apple IIGS project in 1985-1986, developed ADB as a simpler, more cost-effective alternative that could support multiple devices on a single bus.
The design philosophy emphasized simplicity and low cost while maintaining reliability. Wozniak's solution used a single data line with self-clocking signals, eliminating the need for separate clock lines and reducing component count. The protocol was sophisticated enough to support device enumeration, collision detection, and service requests, yet simple enough to implement with minimal hardware.
Implementation Timeline
  • September 1986: First implementation in Apple IIGS
  • March 1987: Adopted by Macintosh SE and Macintosh II
  • 1987-1998: Standard on all desktop Macintosh computers
  • 1991-1998: Used in PowerBook line
  • 1989-1996: Implemented in some NeXT computer models
  • 1998: Phased out with introduction of iMac G3 (USB-based)
  • 1999: Last external ADB port on Power Macintosh G3 (Blue and White)
  • 2000-2005: Internal ADB protocol continued in some PowerBooks for built-in keyboards/trackpads
Technical Specifications
Physical Interface
ADB Connector Pinout (Mini-DIN 4)
Pin Signal Description Specifications
1 ADB Data Bidirectional serial data Open collector, 5V pull-up
2 PSW Power switch Direct connection to power supply
3 +5V Power supply 500mA total, 100mA per device max
4 GND Ground reference Common ground
The connector is physically identical to the 4-pin mini-DIN used for S-Video, leading to potential confusion. However, pins 1 and 2 are bridged in some S-Video cables, which can cause catastrophic damage if used with ADB devices.
Electrical Characteristics
  • Bus topology: Multi-drop, daisy-chain capable
  • Signal type: Open collector with 5V pull-up resistors
  • Logic levels: TTL compatible (0V = low, 5V = high)
  • Cable length: Maximum 5 meters total bus length
  • Power distribution: 500mA at 5V total available
  • Device power limit: 100mA per device maximum
Protocol Specifications
Bit Encoding
ADB uses self-clocking duty-cycle modulation where each bit period is 100μs:
  • Logic 0: 65μs low, 35μs high
  • Logic 1: 35μs low, 65μs high
  • Start bit: Always logic 1
  • Stop bit: Always logic 0
Transaction Structure
Each ADB transaction consists of:
  1. Attention signal: Host pulls bus low for 800μs
  2. Sync signal: Bus high for 70μs
  3. Command byte: 8 bits transmitted by host
  4. Stop bit: Logic 0
  5. Service Request window: 65-300μs (device can assert SRQ)
  6. Stop-to-start time (Tlt): 140-260μs bus high
  7. Data transfer: 2-8 bytes (if applicable)
Command Format
Commands are 8 bits structured as:
  • Bits 7-4: Device address (0-15)
  • Bits 3-2: Command type
  • Bits 1-0: Register number
ADB Command Types
Command Binary Description Action
SendReset 00 System reset All devices reset to default state
Flush 01 Flush device Clear device buffer for specified register
Reserved 10 Reserved Not used
Reserved 11 Reserved Not used
Listen 10 Write to device Host sends data to device register
Talk 11 Read from device Device sends register contents to host
Device Registers
Each ADB device implements four registers:
Standard ADB Register Definitions
Register Purpose Size Description
0 Device data 2-8 bytes Primary data (keyboard keys, mouse movement)
1 Device-specific Variable Extended features or configuration
2 Device-specific Variable Additional features (e.g., keyboard LEDs)
3 Status/Command 2 bytes Device ID, address, and handler ID
Register 3 Format
Register 3 contains device identification and configuration:
  • Bits 15-8: Exceptional event flags (device-specific)
  • Bits 7-0: Device handler ID
  • Bits 11-8: Device address (when read)
  • Service Request Enable: Bit 13
Device Addressing and Enumeration
Default Addresses
ADB Default Device Addresses
Address Device Type Notes
$0 Reserved SendReset command
$1 Security dongles Copy protection devices
$2 Keyboards All keyboards default to this
$3 Mice/Pointing devices Mice, trackballs, trackpads
$4 Graphics tablets Absolute positioning devices
$5 Reserved Vendor-specific
$6 Reserved Vendor-specific
$7 Reserved Vendor-specific
$8-$E Relocated devices Collision resolution addresses
$F Reserved Global polling address
Enumeration Process
The ADB Manager performs device enumeration at startup:
  1. Reset: SendReset command clears all devices
  2. Discovery: Poll each default address with Talk Register 3
  3. Collision Detection: If multiple devices respond:
    • Devices detecting collision stop transmitting
    • Non-colliding device completes transmission
  4. Address Resolution:
    • Send Listen Register 3 with new address ($8-$E) and handler ID $FE
    • Only non-colliding device moves to new address
    • Repeat until all devices have unique addresses
  5. Verification:: Poll new addresses to confirm relocation
  6. Handler Installation:: Install appropriate device drivers
Service Requests
Devices can request service by:
  1. Pulling bus low during stop bit of any transaction (65-300μs)
  2. Host detects extended stop bit as Service Request (SRQ)
  3. Host polls all devices' Register 0 sequentially
  4. Device with data becomes new active device
  5. Active device is polled continuously until another SRQ
Device Handler IDs
Device handlers define how the host interprets device data. Standard handler IDs include:
Common ADB Handler IDs
Handler ID Device Type Description
$00 Self-test fail Device failed internal diagnostics
$01 Standard mouse 100 CPI relative positioning
$02 Standard keyboard Original keyboard protocol
$03 Extended keyboard Supports extended key codes
$04 ISO keyboard International layout support
$05-$07 Reserved keyboards Vendor-specific
$08-$0F Reserved mice Vendor-specific
$10-$1F Graphics tablets Absolute positioning devices
$20-$2F Other devices Joysticks, special controllers
$30-$FD Vendor-specific Custom implementations
$FE Change address Special collision resolution
$FF Self-test pass Device diagnostics successful
Hardware Implementation
Host Controllers
Different Apple systems used various ADB controller implementations:
ADB Controller Implementations
System Controller Type Implementation Details
Apple IIGS Custom ASIC Integrated with Mega II chip
Macintosh SE PIC16CR54 Microchip microcontroller (Apple-branded)
Macintosh II/IIx VIA + transceiver 6522 VIA with discrete transceiver
Macintosh IIfx IOP processor Dedicated I/O processor
Macintosh Portable Power Manager Integrated with PMU chip
PowerBook series PMU Power Management Unit integration
Later Macs Cuda/Egret Combined ADB and power management
VIA Implementation
On most 68k Macintoshes, ADB was implemented using:
  • VIA (Versatile Interface Adapter): 6522 chip for CPU interface
  • Transceiver IC: Handles bus electrical interface
  • State lines (ST0, ST1): Define transaction states
Transaction states:
  • State 0: Even byte from application
  • State 1:: Odd byte from application
  • State 2:: Even byte to application
  • State 3:: Odd byte to application
Standard Devices
Keyboards
ADB keyboards implemented two protocols:
Standard Keyboard Protocol:
  • Register 0: Two key events (2 bytes)
  • Each byte: Key code (7 bits) + up/down flag (1 bit)
  • Rollover: 2-key guaranteed
Extended Keyboard Protocol:
  • Distinguishes left/right modifiers
  • Handler ID change from $02 to $03
  • Additional key codes for extended keys
  • Used by Apple Extended Keyboard and later models
Mice and Pointing Devices
Standard Mouse Protocol:
  • Register 0: Button state and movement deltas (2 bytes)
  • Byte 0: Button (bit 7) + X delta (bits 6-0)
  • Byte 1: Button (bit 7) + Y delta (bits 6-0)
  • Resolution: 100 counts per inch typical
  • Movement range: -64 to +63 per packet
Extended Mouse Protocol:
  • Supports multiple buttons
  • Higher precision movement data
  • Additional registers for extended features
  • Handler ID varies by capability
Graphics Tablets
Graphics tablets could operate in two modes:
  • Relative mode:: Emulates standard mouse
  • Absolute mode:: Reports absolute position
  • Required vendor-specific drivers
  • No standard protocol defined by Apple
Limitations and Issues
Hot-Swapping
While ADB protocol supports hot-swapping, most implementations were unsafe:
  • Problem:: No current limiting on ADB ports
  • Risk:: Hot-swapping could blow motherboard fuse (typically 1.1A polyfuse)
  • Exceptions:: PowerBook G3 "Wall Street" had protected ports
  • Repair:: Required fuse replacement or expensive motherboard swap
Collision Issues
  • Multiple identical devices caused address collisions
  • Resolution process could fail with >3 identical devices
  • Some devices had non-random address generation
Performance Limitations
  • Bandwidth:: Limited to 125 kbit/s theoretical (10-50 kbit/s typical)
  • Latency:: Polling-based system introduced input lag
  • Device limit:: 16 devices maximum, practically fewer
  • Cable length:: 5 meters total maximum
Power Limitations
  • Total power:: 500mA at 5V for entire bus
  • Per device:: 100mA maximum
  • PowerBooks:: Reduced to 200mA total on battery
Software Support
ADB Manager
The ADB Manager in Mac OS handled:
  • Device enumeration and address assignment
  • Polling active devices
  • Service request handling
  • Device handler installation and management
  • Register read/write operations
Key ADB Manager routines:
  • ADBOp: Perform ADB transaction
  • ADBReset:: Reset bus and enumerate devices
  • SetADBInfo:: Install device handler
  • GetADBInfo:: Query device information
  • CountADBs:: Return number of devices
System Software Compatibility
  • Apple IIGS:: GS/OS with built-in ADB support
  • Mac OS:: System 3.2 through Mac OS 9.2.2
  • A/UX:: Full ADB support in Unix environment
  • NeXT:: Limited support on some models
  • BeOS:: Third-party drivers available
  • Linux:: Kernel support for PowerPC Macs
Modern Usage and Adapters
ADB to USB Adapters
  • Griffin iMate:: Original commercial adapter (discontinued)
  • Wombat:: Modern bidirectional ADB-USB converter
  • Belkin F5U118:: Simple ADB to USB adapter
USB to ADB Adapters
  • Wombat:: Allows USB devices on ADB Macs
  • DIY solutions:: Arduino-based converters
Replacement Controllers
  • PIC16F87/88:: Drop-in replacement for failed SE controllers
  • Custom ASICs:: Modern reproductions for restoration
Legacy and Impact
ADB represented several important innovations:
  • First successful hot-pluggable peripheral bus (though implementation issues limited this)
  • Automatic device enumeration and configuration predating USB
  • Low-cost implementation enabling affordable peripherals
  • Power distribution through the peripheral bus
  • Collision detection and resolution without user intervention
The protocol influenced later designs:
  • USB adopted similar enumeration concepts
  • NeXT used ADB on some models
  • Protocol concepts influenced FireWire development
  • Demonstrated viability of serial peripheral buses
Technical Documentation
Patents
Key Apple patents related to ADB:
  • 4,875,158 - Method for requesting service by a device
  • 4,910,655 - Apparatus for transferring signals and data
  • 4,912,627 - Method for storing information
  • 4,918,598 - Method for selectively activating and deactivating devices
Developer Resources
  • Inside Macintosh: Devices - Complete ADB programming guide
  • Technical Note HW01 - "ADB - The Untold Story: Space Aliens Ate My Mouse"
  • Guide to Macintosh Family Hardware - Hardware specifications
Common ADB Devices
Apple Devices
Third-Party Devices
  • Kensington TurboMouse trackballs
  • Gravis GamePad and MouseStick
  • Wacom ArtZ graphics tablets
  • CalComp DrawingBoard tablets
  • CoStar LabelWriter printers
  • Hardware copy-protection dongles
  • Modems and telecommunications devices
Common Problems
ADB Troubleshooting Guide
Problem Possible Cause Solution
No devices recognized Blown ADB fuse Replace fuse or motherboard repair
Intermittent device Damaged cable Check continuity, replace if needed
Device not found Address collision Disconnect other devices, restart
Erratic behavior Bus termination issue Check cable length (<5m total)
Power issues Overloaded bus Remove devices, check power draw
Random disconnects Failing transceiver Replace ADB controller
Diagnostic Tools
  • ADB Parser:: Classic Mac OS tool for bus analysis
  • TechTool:: Hardware diagnostic suite
  • MacsBug:: Low-level debugging access to ADB
