Apple Keyboard
Revision as of 10:21, 7 September 2025 by Josh (talk | contribs)
Apple Extended Keyboard
Apple Extended Keyboard M0115 with Alps SKCM Orange switches
Type Computer keyboard
Discontinued October 15, 1990
Price US$329 (retail)
Interface Apple Desktop Bus
Compatible All ADB-equipped Macs, Apple IIGS
Dimensions 470 mm W × 175 mm D × 48 mm H (rear)
Weight 2.3 kg (5.1 lbs)
Predecessor None (first extended Apple keyboard)
Successor Apple Extended Keyboard II (M3501/M0312)
Model M0115, M0115B, M0115J
The Apple Extended Keyboard (AEK), model M0115, was Apple's first full-size keyboard featuring dedicated function keys and a standard PC-style navigation cluster. Introduced on March 2, 1987, alongside the Macintosh II and Macintosh SE, it offered professional users a comprehensive 105-key layout based on IBM's Enhanced Keyboard standard. The keyboard featured mechanical Alps SKCM switches and established design elements that would define Apple keyboards for years, including template guide posts for application overlays and dual ADB ports for peripheral daisy-chaining. Production continued until October 1990 when it was replaced by the refined Apple Extended Keyboard II.
Design Evolution
The Apple Extended Keyboard represented Apple's response to professional users who required a full-featured keyboard for business applications, programming, and data entry. Unlike the compact Apple Keyboard (M0116) introduced simultaneously, the Extended model embraced the emerging 101-key ANSI standard while adding Apple-specific enhancements.
The keyboard's substantial construction reflected the professional positioning of the Macintosh II, Apple's first modular desktop computer. The design philosophy emphasized durability and typing comfort over portability, resulting in Apple's heaviest keyboard at 2.3 kg. The convex curve of the case, viewed from the side, created significant internal volume that contributed to the keyboard's distinctive acoustic properties.
Designed within the Snow White design language framework, the keyboard featured horizontal grooves on the lower case section—a signature element of Apple products from this era. The serrated texture provided visual interest while the Platinum gray color unified it with the Macintosh II system components.
Physical Design
Case Construction
The Extended Keyboard's case design prioritized internal volume and structural rigidity:
  • Upper shell: Continuous convex curve from front to rear
  • Lower shell Extended depth with serrated texture
  • Rear cavity Significant empty space behind function keys
  • Width Matched Macintosh II dimensions (470mm)
  • Height clearance Designed to fit under Macintosh SE "chin"
Template Posts
Two cylindrical posts projected vertically from the case:
  • Location Either side of function key row
  • Purpose Hold application-specific key templates
  • Height 15mm above case surface
  • Diameter 6mm
  • Material Injection-molded ABS plastic
Popular software packages included cardboard or plastic templates that slipped over these posts, providing visual reference for function key assignments in applications like Microsoft Word, Excel, and PageMaker.
Layout Architecture
The 105-key ANSI layout included several distinctive elements:
  • Function keys F1-F15 (unusual 15-key arrangement)
  • Navigation cluster Six-key inverted-T configuration
  • Numeric keypad Standard 17-key with equals sign
  • Power key Separate key with unique keycap design
  • Modifier keys Command (⌘), Option, Control on both sides
Model Variants
M0115 (Standard US)
Production 1987-1990
  • Layout: 105-key ANSI
  • Number 3 key: # symbol
  • Manufacturing: USA, Ireland
  • Label: Standard Apple format
M0115B (UK/Ireland)
Production 1988-1990
  • Layout: 105-key with UK modifications
  • Number 3 key: £ symbol instead of #
  • Manufacturing: Ireland exclusively
  • Label: "Assembled in Ireland"
M0115J (Japanese)
  • Layout: JIS configuration
  • Additional keys: Kana legends
  • Manufacturing: Limited production
  • Market: Japan domestic only
Switch Technology
Alps SKCM Orange
  • Type: Tactile, non-clicky
  • Actuation force: 70g ± 10g
  • Pre-travel: 2.0mm
  • Total travel: 3.5mm
  • Tactile point: Sharp, defined
  • Sound signature: "Click-clock"
  • Lifespan: 10-15 million actuations
Production period 1987-1989
Orange Alps switches achieved legendary status among keyboard enthusiasts, often rated as the finest tactile switch ever produced. The switches provided exceptional tactile feedback with a sharp, defined bump at the actuation point. The distinctive "click-clock" sound became synonymous with quality Apple keyboards of the era.
Alps SKCM Salmon
  • Actuation force: 70g ± 10g (slightly stiffer than Orange)
  • Pre-travel: 2.0mm
  • Tactile point: Similar to Orange
  • Sound signature: Slightly deeper than Orange
Production period 1989-1990
Salmon Alps appeared in later production runs, coinciding with high serial numbers. While mechanically similar to Orange Alps, users report subtle differences in feel and sound. The salmon variant tends to feel slightly stiffer with a marginally deeper acoustic signature.
Alps SKCL Lock (Caps Lock)
All variants used the Alps SKCL Lock switch for Caps Lock:
  • Mechanical latching mechanism
  • Physical lock-down when engaged
  • Cream-colored housing (with Orange/Salmon)
  • Dark gray housing (rare variants)
  • Distinctive click on engagement/disengagement
Technical Specifications
Physical Dimensions
  • Width 470mm (18.5 inches)
  • Depth 175mm (6.9 inches)
  • Height (front) 32mm (1.3 inches)
  • Height (rear) 48mm (1.9 inches)
  • Weight 2.3kg (5.1 lbs)
  • Cable length 1.2m coiled (4 feet extended)
Electrical Specifications
  • Interface Apple Desktop Bus (ADB)
  • Connectors Two 4-pin mini-DIN ports
  • Power consumption 25mA typical, 50mA maximum
  • Operating voltage 4.75V - 5.25V
  • Data rate 10 kbit/s maximum
ADB Protocol Implementation
  • Device type Keyboard
  • Default address $2
  • Handler ID $02 (standard), $03 (extended protocol)
  • Polling rate 100 Hz maximum
  • Key rollover 2-key minimum, 6-key typical
Register Configuration
Register 0 Key event data (2 bytes)
  • Byte 1: First key event
  • Byte 2: Second key event
  • Format: 7-bit keycode + 1-bit up/down flag
Register 1 Reserved for vendor use
Register 2 LED and modifier status
  • Bit 1: Caps Lock LED state
  • Bit 2: Num Lock LED state
  • Bit 3: Scroll Lock LED state
Register 3 Device identification
  • Byte 1: Exception flags
  • Byte 2: Device handler ID
Internal Construction
PCB Design
Early production (1987-1988)
  • Controller chips: Socketed configuration
  • PCB layers: Double-sided with through-hole plating
  • Component count: ~45 discrete components
  • Trace width: 0.5mm minimum
Late production (1989-1990)
  • Controller chips: Soldered directly
  • PCB refinements: Improved routing
  • Component consolidation: ~38 components
  • Cost reduction evident
Assembly Process
  1. Steel plate preparation (1.5mm thickness)
  2. Switch installation into plate (105 positions)
  3. PCB alignment and mounting
  4. Wave soldering of switch pins
  5. Manual soldering of larger components
  6. Cable assembly attachment
  7. Case assembly with 4 screws
  8. Quality control testing
  9. Final inspection and packaging
Stabilizer System
The keyboard employed Alps-specific wire stabilizers:
Early production
  • Spacebar stabilizer: Above the switch
  • Clips: Brown-colored plastic
  • Wire: 1.5mm steel, chrome-plated
  • Design: Traditional Alps configuration
Late production
  • Spacebar stabilizer: Below the switch
  • Clips: Black-colored plastic
  • Wire: Shorter leg design
  • Design: Improved for reduced rattle
Large keys with stabilizers:
  • Spacebar (6.25 units)
  • Return/Enter keys
  • Both Shift keys
  • Backspace
  • Numeric Enter
  • Numeric Plus
  • Numeric 0
Manufacturing Information
Production Facilities
United States
  • Period: 1987-1990
  • Switch types: Orange and Salmon Alps
  • Percentage: ~60% of total production
Ireland
  • Period: 1988-1990
  • Switch types: Primarily Salmon Alps
  • Market focus: European distribution
  • Percentage: ~40% of total production
Serial Number Format
Format varies by production location:
US Production
  • Format: PPYWWNNNNNN
  • PP: Plant code (F1 = Fremont)
  • Y: Year (7=1987, 8=1988, 9=1989, 0=1990)
  • WW: Week number (01-52)
  • NNNNNN: Sequential number
Ireland Production
  • Format: Similar with plant code IC (Ireland Cork)
  • Often includes "Assembled in Ireland" designation
Production Timeline
  • March 1987 Initial release with Macintosh II/SE
  • 1987-1988 Orange Alps exclusive period
  • 1989 Transition to Salmon Alps begins
  • Early 1990 Final production runs
  • October 1990 Discontinued, replaced by AEK II
Quality Control
Each keyboard underwent rigorous testing:
  • 100% key switch testing
  • ADB communication verification
  • LED functionality check
  • Physical inspection for defects
  • Sample burn-in testing (1 per 100 units)
  • Template post alignment verification
Keycap Specifications
Material and Manufacturing
  • Material PBT plastic (except spacebar: ABS)
  • Manufacturing Dye sublimation
  • Thickness 1.5mm average
  • Profile Apple Extended (unique to this model)
  • Texture Smooth matte finish
Profile Characteristics
The Apple Extended Keyboard introduced a unique keycap profile:
  • Function row Tallest profile, vertical stem mounting
  • Number row Standard height
  • QWERTY row Slightly lower than number row
  • Home row Lower still
  • Bottom row Lowest profile
  • Spacebar Custom sculpted profile
This profile differed from both standard Cherry and OEM profiles, creating a distinctive typing angle optimized for the keyboard's overall geometry.
Typography
  • Font Univers 57 Condensed
  • Style Regular (not italic)
  • Alignment Centered on alphanumeric keys
  • Special keys Text labels (not symbols)
  • Color Dark gray sublimation
Software Compatibility
Operating Systems
  • Mac OS System 4.1 through Mac OS 9.2.2
  • A/UX Full support
  • Apple IIGS GS/OS compatible
  • BeOS Third-party driver support
  • Linux Kernel support on PowerPC
  • Windows Via ADB-USB adapters only
Extended Keyboard Protocol
Handler ID $03 enabled:
  • Differentiation between left/right modifiers
  • Extended scan codes
  • Additional function key support
  • Enhanced key repeat control
To enable extended protocol:
  1. Send Listen Register 3 command
  2. Set handler ID to $03
  3. Keyboard acknowledges and switches modes
Special Key Functions
  • Power key Direct system power control
  • Command-Option-Escape Force quit
  • Command-Control-Power Force restart
  • Command-Option-P-R PRAM reset (startup)
Maintenance & Restoration
Disassembly Procedure
Tools required
  • Phillips screwdriver #1
  • Plastic spudgers (2)
  • Isopropyl alcohol 90%+
  • Cotton swabs
  • Antistatic mat
Steps
  1. Remove four case screws from bottom
  2. Note screw length differences (rear screws longer)
  3. Carefully separate case halves
  4. Disconnect cable from PCB
  5. Remove PCB mounting screws
  6. Document any washers or spacers
  7. Lift PCB and plate assembly as unit
Common Issues and Solutions
Troubleshooting Guide
Problem Likely Cause Solution Difficulty
Keys not registering Dirty switch contacts Clean with isopropyl alcohol Easy
Scratchy key feel Switch contamination Disassemble and clean switches Moderate
Repeating keys Worn switch contacts Replace switch Moderate
No ADB recognition Cable damage Test continuity, replace cable Easy
Yellowing case UV exposure Retrobright treatment Moderate
Caps Lock stuck down Worn latch mechanism Replace SKCL switch Difficult
Stabilizer rattle Worn clips Replace stabilizer clips Moderate
LED not working Failed LED or resistor Component-level repair Difficult
Switch Maintenance
Cleaning procedure
  1. Remove keycap with wire puller
  2. Apply 3-5 drops of 90%+ isopropyl alcohol
  3. Actuate switch 20-30 times
  4. Allow complete evaporation (10 minutes)
  5. Test switch response
  6. Repeat if necessary
Deep cleaning (disassembly)
  1. Desolder switch from PCB
  2. Open switch housing (4 tabs)
  3. Clean contacts with alcohol
  4. Inspect spring and leaf
  5. Reassemble carefully
  6. Test before resoldering
Restoration Best Practices
Retrobrighting
  • Method: Hydrogen peroxide cream (40 volume)
  • Application: Even coating, avoid labels
  • UV exposure: 6-8 hours rotating
  • Temperature: 20-25°C optimal
  • Results: 70-90% yellowing reduction typical
Keycap restoration
  • Cleaning: Denture tablets (6-hour soak)
  • Stubborn stains: Soft brush with mild soap
  • Drying: Air dry completely (24 hours)
  • Never use: Acetone, bleach, or abrasives
Case restoration
  • Cleaning: Mild soap and water
  • Scuff removal: Magic eraser (gentle)
  • Crack repair: ABS cement or epoxy
  • Texture preservation: Avoid harsh chemicals
Modern Usage
ADB to USB Conversion
Hardware adapters
  • Griffin iMate Original solution (discontinued)
  • Wombat Current best option, bidirectional
  • TMK converter Open-source DIY solution
  • Drakware Premium cables with case integration
Functionality notes
  • All keys map correctly with proper adapter
  • Power button may require remapping
  • Extended protocol advantages lost
  • Latency: 1-2ms typical with good adapter
Custom Modifications
Popular modifications
  • USB internal conversion (requires new controller)
  • Bluetooth conversion (battery installation required)
  • Switch harvesting for custom builds
  • Case modifications for modern internals
  • LED backlighting retrofits
Preserve value by
  • Keeping modifications reversible
  • Retaining original components
  • Documenting all changes
  • Using period-appropriate techniques
Collector Information
Market Value (2024)
Current Market Prices (USD)
Condition Orange Alps Salmon Alps
Poor (yellowed, worn) $150-250 $100-200
Good (functional, some yellowing) $250-400 $200-300
Excellent (minimal yellowing) $400-600 $300-450
Mint (no yellowing, boxed) $600-1000 $450-700
Authentication Points
  • Verify serial number format matches era
  • Check switch type (remove keycap)
  • Inspect stabilizer clip colors
  • Confirm template posts present
  • Look for socketed vs. soldered chips
  • Verify 4-screw assembly
Desirability Factors
Positive value factors
  • Orange Alps switches (highest premium)
  • Early serial numbers (1987)
  • Complete with original cable
  • Minimal to no yellowing
  • Original packaging/documentation
  • Template overlays included
Negative value factors
  • Missing keycaps
  • Non-functional switches
  • Heavy yellowing
  • Modified or damaged case
  • Missing cable
  • Stabilizer damage
Storage Recommendations
  • Temperature: 15-25°C
  • Humidity: 40-60% RH
  • Light: Avoid direct sunlight
  • Position: Flat, keys up
  • Dust protection: Cover or bag
  • Cable: Avoid tight coiling
Cultural Impact and Legacy
The Apple Extended Keyboard established several industry standards that persist in modern mechanical keyboards. The template post system, while specific to Apple, influenced the concept of customizable function key overlays. The substantial construction and premium switches set a quality benchmark that many enthusiasts still consider unmatched.
The keyboard's association with professional Macintosh systems of the late 1980s created lasting appeal among creative professionals who used these systems for desktop publishing, graphic design, and music production. Many recording studios and design firms continued using M0115 keyboards well into the 2000s, long after ADB had been discontinued.
The Orange Alps switches in particular achieved mythical status in the mechanical keyboard community. When Alps Electric discontinued the SKCM series in the late 1990s, M0115 keyboards became primary donor boards for switch harvesting. This practice has significantly reduced the number of intact examples, further increasing collector values.
Production Statistics
Based on serial number analysis and manufacturing records:
  • Total production Approximately 400,000 units
  • Orange Alps units ~200,000 (50%)
  • Salmon Alps units ~200,000 (50%)
  • US manufacture ~240,000 (60%)
  • Ireland manufacture ~160,000 (40%)
  • Survival rate Estimated 15-20% in working condition
Design Influence
The Apple Extended Keyboard's design influenced several aspects of keyboard development:
Layout standardization
  • Established Apple's interpretation of 101-key ANSI
  • F13-F15 keys became Apple standard
  • Navigation cluster arrangement influenced later designs
Construction methods
  • Plate-mounted switches became premium standard
  • Internal volume for acoustics considered in design
  • Substantial weight associated with quality
Feature innovations
  • Template posts (unique to Apple)
  • Dual ADB ports for daisy-chaining
  • Separate power key with distinct keycap
Comparison with Contemporaries
1987 Professional Keyboard Comparison
Feature Apple Extended M0115 IBM Model M Northgate OmniKey
Switches Alps SKCM Orange/Salmon Buckling Spring Alps SKCM Blue/White
Weight 2.3 kg 2.3 kg 2.1 kg
Keys 105 101 101
Interface ADB PS/2 AT/XT switchable
Price (1987) $329 $295 $349
Build quality Excellent Excellent Excellent
Sound level Moderate Loud Loud
Tactility High Very High High
