Atari 5200
Revision as of 10:01, 21 September 2025 by Josh (talk | contribs) (→Schematics)
Atari 5200
Atari 5200 4-port model with controllers (1982)
ManufacturerAtari, Inc.
TypeHome video game console
ReleasedNovember 1982 (4-port)
May 1983 (2-port)
Discontinued21 May 1984
Intro priceUS$269 (1982)
CPUMOS 6502C "Sally" @ 1.79 MHz
Memory16 KB RAM
StorageROM cartridge (4 KB - 32 KB)
Display384 × 240 pixels maximum, 256 colors (16 hues × 16 luminance)
SoundPOKEY 4-channel PSG
Dimensions330 mm W × 260 mm D × 95 mm H
Weight2.0 kg (4-port)
OS / Firmware2 KB BIOS (1 KB character ROM)
PredecessorAtari 2600
SuccessorAtari 7800
CodenamePAM, Super Stella, Video System X
Model no.CX5200
The Atari 5200 SuperSystem is a home video game console released by Atari, Inc. in November 1982. Based on the architecture of the Atari 8-bit computer line, the system features the 6502C processor running at 1.79 MHz alongside the custom ANTIC, GTIA, and POKEY chips. The console was discontinued on May 21, 1984, after selling approximately 1 million units.
System Architecture
Sub-system Specification
CPU MOS 6502C "Sally" @ 1.79 MHz
Custom 6502 variant with HALT line for DMA operations
Graphics GTIA (CO14805 NTSC / CO14889 PAL)
256 colors from palette of 256 (16 hues × 16 luminance)
Display Controller ANTIC (CO12296)
Alphanumeric Television Interface Controller
Hardware display list processing, character/bitmap generation
Audio/I/O POKEY (CO12294)
4-channel square wave/noise generation
Keyboard scanning, serial I/O, timers
RAM 16 KB (8× 4516 DRAM chips @ 150ns)
ROM 2 KB BIOS (CO19156A)
1 KB character set, 1 KB boot/initialization code
Video Modes 14 display modes
Text: 40×24, 20×24, 20×12 characters
Graphics: 320×192 (2 colors), 160×192 (4 colors), 80×192 (16 colors)
Sprites 4 players (8 pixels wide) + 4 missiles (2 pixels wide)
Hardware collision detection
Controller Ports 4 ports (4-port model) or 2 ports (2-port model)
Analog joystick with 12-key keypad support
Memory Map
6502C Address Space
Range Size Purpose
$0000-$3FFF 16 KB RAM
$4000-$BFFF 32 KB Cartridge ROM space
$C000-$C0FF 256 bytes GTIA chip registers
$D400-$D5FF 512 bytes ANTIC chip registers
$E800-$E8FF 256 bytes POKEY chip registers
$F800-$FBFF 1 KB Character set ROM
$FC00-$FFFF 1 KB System ROM/BIOS
Custom Chip Registers
Key Hardware Registers
Chip Address Range Function
GTIA $C000-$C01F Player/missile graphics, collision detection
$C020-$C02E Color palette registers
$C02F Console keys (Start/Select/Option)
ANTIC $D400-$D40F Display list, DMA control, interrupts
$D410-$D5FF Hardware scrolling, display mode
POKEY $E800-$E80F Audio frequency/control registers
$E810-$E81F Paddle/keyboard input, serial I/O
Model Variants
Production Models
Model Years Ports PCB Key Features
4-Port Original 1982-1983 4 CA018087 Combined power/RF switchbox, controller storage
4-Port Universal 1983 4 CA020108 CX55 2600 adapter compatible (with asterisk serial)
2-Port 1983-1984 2 CA021374 Separate power supply, standard RF switch, CX55 compatible
The 4-port models use a unique switchbox that combines RF output with power delivery through a single cable. The 2-port model reverted to a conventional separate 9V DC power adapter and standard RF switch box.
Motherboard Revisions
PCB Number Controller Ports ICs Notes
CA018087 4 28 Original design, not CX55 compatible without modification
CA020108 4 26 Universal board, late units with asterisk serial support CX55
CA021374 2 24 Cost-reduced, natively supports CX55 2600 adapter
The Atari 5200 requires periodic maintenance to address controller degradation and RF modulator oxidation. The non-centering analog controllers are prone to flex circuit failure and require regular cleaning of the carbon contacts with isopropyl alcohol. The 4-port model's combined power/RF switchbox frequently develops cold solder joints that cause intermittent power loss. Controller storage compartments should be kept clean to prevent dust accumulation on the exposed controller ports.
Troubleshooting Guide
Common failures include blank screens from dirty cartridge edge connectors, controller drift from worn potentiometers, and power issues in 4-port models from faulty switchbox connections. The POKEY chip (CO12294) can fail causing loss of controller input or audio. Video problems often stem from failed GTIA (CO14805) or aging electrolytic capacitors. The 7805 voltage regulators run hot and may require heatsink replacement or upgraded thermal compound.
Capacitor Replacement
Critical capacitors include the main filter capacitors near the voltage regulators and various bypass capacitors throughout the board. The 4-port models contain larger filter capacitors due to the switchbox power design. All electrolytic capacitors should be replaced with 105°C rated equivalents. The styrene capacitors used for audio coupling are particularly failure-prone and should be replaced with polystyrene or ceramic types.
Power Supply
The power requirements differ between models:
  • 4-Port Models: 9.3V AC @ 3.5A via switchbox
  • 2-Port Models: 9V DC @ 1.95A via barrel jack (5.5mm × 2.1mm, center positive)
Internal regulation provides:
  • +5V: Logic supply via dual 7805 regulators (VR1, VR2)
  • Unregulated: Direct to analog circuits
Both voltage regulators should measure 4.85-5.15V output. Heat sinking is critical as regulators run at elevated temperatures.
Controller System
The 5200 controllers use analog potentiometers for X/Y positioning with a 12-button keypad matrix and dual fire buttons. Key specifications:
  • Potentiometers: 500KΩ linear taper
  • Keypad: 4×3 matrix scanned by POKEY
  • Flex Circuit: Carbon traces on mylar substrate
  • Connection: 15-pin connector per port
The non-centering design uses a rubber boot instead of springs, leading to the notorious control issues. The flex circuits deteriorate over time, causing button failures.
Cartridge Slot
The 36-pin edge connector accepts cartridges up to 32 KB:
  • Standard 4K/8K: Direct mapped
  • 16K: Two 8K banks
  • 32K: Four 8K banks (rare)
Unlike the 2600, the 5200 cannot use bank-switching schemes beyond basic 32K mapping due to BIOS limitations.
Video Output
The system generates composite video internally, output through RF modulator on channel 2 or 3:
  • Horizontal: 228 color clocks per line
  • Vertical: 262 lines (NTSC), 312 lines (PAL)
  • Frame rate: 59.92 Hz (NTSC), 49.70 Hz (PAL)
  • Color burst: 3.579545 MHz (NTSC)
Common modifications include composite and S-Video output by tapping signals from the GTIA chip.
Audio System
POKEY generates four independent audio channels:
  • Frequency control: 8-bit divisor
  • Volume: 4-bit per channel (0-15)
  • Waveforms: Pure tone, polynomial noise
  • Clock source: 1.79 MHz or 64 kHz
Audio output is mixed to mono and routed through the RF modulator or can be tapped for line-level output modifications.
Common IC Identification
Atari Part Function Location
CO14806 6502C CPU A2/U2
CO12296 ANTIC A3/U3
CO14805 GTIA (NTSC) A5/U5
CO14889 GTIA (PAL) A5/U5
CO12294 POKEY A7/U7
CO19156A ROM/BIOS A8/U8
Controller Port Pinout
15-pin Controller Connector
Pin Signal Function
1 Keypad Row 0 Keyboard matrix scanning
2 Keypad Row 1 Keyboard matrix scanning
3 Keypad Row 2 Keyboard matrix scanning
4 Keypad Row 3 Keyboard matrix scanning
5 Keypad Column 2 (Reset) Reset button input
6 Keypad Column 0 Keyboard matrix scanning
7 +5V Power supply
8 Keypad Column 1 Keyboard matrix scanning
9 POT0 (Horizontal) X-axis potentiometer
10 POT1 (Vertical) Y-axis potentiometer
11 +5V Power supply
12 Fire Button (Bottom) Secondary fire button
13 Fire Button (Top) Primary fire button
14 Ground Common ground
15 NC Not connected
Technical Specifications Summary
  • Clock Speed: 1.79 MHz (NTSC), 1.77 MHz (PAL)
  • Colors: 256 (16 hues × 16 luminance levels)
  • Resolution: Up to 384×240 overscan, 320×192 standard
  • Sprites: 4 players + 4 missiles, hardware collision detection
  • Sound: 4-channel square wave/noise generation
  • Controllers: Analog with 360° non-centering movement
Service Information
Service documentation is available in the CX5200 Field Service Manual. The system uses all through-hole components except for some RF modulator sections. Common replacement parts:
  • 7805 voltage regulators: Standard TO-220 package, 1A minimum
  • Power jack (2-port): 5.5mm × 2.1mm barrel connector
  • Controller port connectors: 15-pin card edge
  • Cartridge connector: 36-pin (2×18) edge connector
Schematics
Atari 5200
Motherboard RF Switch Box Accessories
Atari 5200 Console Schematic
Atari 2600 RF Switchbox Schematic
Atari 5200 Accessories Schematic
