Apple Joystick IIe/IIc
| Apple Joystick IIe/IIc | |
| Apple Joystick IIe IIc.jpg | |
| Apple Joystick (Model A2M2012) | |
| Type | Joystick (analog) |
| Discontinued | 1993 |
| Price | US$49 |
| Interface | DE-9 (game port) |
| Compatible | Apple IIe, Apple IIc, Apple IIc Plus, Apple IIGS |
| Dimensions | ~115 mm × 115 mm × 70 mm (4.5" × 4.5") |
| Weight | ~200 g |
| Predecessor | Apple II Joystick (A2M2002) |
| Successor | None |
| Model | A2M2002, A2M2012 |
The Apple Joystick (models A2M2002 and A2M2012) was Apple's analog joystick for the Apple IIe, Apple IIc, and Apple IIGS computers. Used primarily for games, the self-centering joystick provided proportional control through two potentiometers.
Models
Apple produced two joystick models with identical external appearance but different model numbers:
| Model | Description | Period |
| A2M2002 | Original Apple II Joystick | 1983-1985 |
| A2M2012 | Apple IIe/IIc Joystick (revised) | 1984-1993 |
The case dimensions appear identical between models. Internal components may vary.
Design
Physical Construction
The joystick features a compact beige plastic housing:
- Square base approximately 4.5" × 4.5" (115 mm × 115 mm)
- Central stick with rounded knob
- Two fire buttons on the base
- Adjustable centering controls on bottom
- Fixed DE-9 cable
Self-Centering Mechanism
The joystick uses spring-loaded centering:
- Springs return the stick to center when released
- Center position represents "no input"
- Trim controls on bottom allow fine adjustment
- Prevents drift in software that relies on neutral position
Analog Operation
Unlike digital joysticks with simple on/off contacts, the Apple Joystick provides proportional control:
- Two potentiometers (approximately 100-150 kΩ)
- Variable resistance indicates stick position
- Allows gradual movement vs. binary direction
- Similar principle to modern analog thumbsticks
Measured potentiometer values vary between units (114k, 118k, 136k observed), requiring calibration for optimal performance.
Connection
The joystick connects via a DE-9 connector:
- Direct connection to Apple IIc and IIc Plus game port
- Requires interface card or adapter for Apple II and II Plus
- Compatible with Apple IIGS
Apple II Compatibility
The packaging stated Apple II compatibility, but this required an adapter. Southern California Research Group sold adapters for:
- Apple II and II Plus connection
- Dual joystick support on Apple IIGS
The green wire present in the cable is unused.
| Parameter | Value |
| Model numbers | A2M2002, A2M2012 |
| Dimensions | ~115 mm × 115 mm × 70 mm |
| Weight | ~200 g |
| Potentiometers | ~100-150 kΩ (varies) |
| Buttons | 2 fire buttons |
| Interface | DE-9 connector |
| Cable length | ~1.5 m |
| Case color | Beige (Apple II matching) |
| Case material | ABS plastic |
Internal Components
Potentiometers
Two potentiometers control X and Y axes:
- Rotary type with gear linkage to stick
- Values observed: 114k, 118k, 136k ohms
- Variation between units may require calibration
- Some Apple IIe units need capacitor adjustment for full range
Buttons
Two momentary switches provide button inputs:
- Standard NO (normally open) contacts
- Connect to Button 0 and Button 1 inputs
- Located on base flanking the stick
Springs
Centering springs provide return force:
- Loaded around the stick pivot
- Force increases with deflection
- Springs can weaken over decades of use
Maintenance
Calibration
Centering adjustments are accessible on the bottom:
- Locate two trim controls
- Adjust while monitoring center position in software
- Small screwdriver required
- Test in multiple applications
Potentiometer Cleaning
Erratic movement often indicates dirty pots:
- Open case (screws on bottom)
- Apply contact cleaner to potentiometer openings
- Work stick through full range multiple times
- Allow to dry before reassembly
Spring Replacement
Weak centering indicates worn springs:
- Disassemble joystick
- Identify spring type and dimensions
- Source replacement springs (uncommon)
- Reassemble with correct tension
| Problem | Cause | Solution |
| No response | Cable damage, card issue | Test cable continuity, verify card |
| Drift from center | Calibration needed | Adjust trim controls |
| Erratic movement | Dirty potentiometers | Clean with contact cleaner |
| Limited range | Pot mismatch with system | May require capacitor adjustment |
| Weak centering | Worn springs | Replace springs (difficult) |
| Button stuck | Debris, worn switch | Clean or replace switch |
Collecting
Condition Assessment
- Mint: Original box, fully functional, clean
- Excellent: Functional, minimal wear
- Good: Functional, cosmetic wear
- Fair: Functional but needs calibration
- Poor: Non-functional or damaged
Original Box
Boxed examples are more valuable. The packaging includes:
- Joystick unit
- Brief documentation
- Apple II compatibility note
3D Printed Reproductions
Due to rising prices, some collectors create 3D printed cases:
- Dimensions available from community measurements
- Original internal components still required
- Considered replicas, not original units
- Applefritter community discussions
- The Liberator — joystick disassembly documentation
- Computer History Museum collection records
