Disk II
Revision as of 13:18, 9 February 2026 by Josh (talk | contribs) (Fix image syntax to File:...)
Disk II
Disk II Floppy Disk Subsystem (Model A2M0003)
Manufacturer Apple Computer, Inc. (Shugart/Alps mechanisms)
Type Floppy disk drive
Discontinued 1985
Price US$595 (with controller)
Interface 20-pin ribbon to controller card
Compatible Apple II, Apple II Plus, Apple IIe
Dimensions ~215 mm × 180 mm × 90 mm
Weight ~2 kg
Predecessor Cassette tape storage
Successor Apple DuoDisk
Model A2M0003
The Disk II Floppy Disk Subsystem (often rendered Disk ][, model A2M0003) is a 5¼-inch floppy disk drive designed by Steve Wozniak for the Apple II. Released in June 1978 at US$595 (including controller card), the Disk II was the cheapest floppy disk system sold up to that point and was instrumental in establishing the Apple II as a serious business computer capable of running VisiCalc.
Background
The Apple II originally used cassette tape storage like other microcomputers of the era. Apple investor Mike Markkula asked Wozniak to design a disk drive after finding that a checkbook-balancing program he had written took too long to load from tape.
Wozniak studied IBM and North Star disk controller designs, then created a dramatically simplified controller using only a handful of chips—about one-tenth the chip count of existing controllers. He called the Disk II "my most incredible experience at Apple and the finest job I did."
Design
Drive Mechanism
The original Disk II used modified Shugart SA-400 mechanisms:
  • Apple purchased bare mechanisms without standard controller boards
  • Wozniak's controller board replaced Shugart's
  • Apple logo stamped on faceplate
  • Early production: 30 drives assembled per day by two people
  • By 1982, switched to Alps mechanisms for cost reasons
Controller Card
The Wozniak-designed controller features:
  • Software-driven operation (total user control over format)
  • Group Coded Recording (GCR) encoding
  • 13 sectors per track (DOS 3.2) or 16 sectors per track (DOS 3.3)
  • Supports two drives per card
  • Up to 14 drives possible (7 cards × 2 drives)
Head Load Solenoid
The standard SA-400 had a head load solenoid to lift heads when not accessing. Wozniak removed this, proving it unnecessary for 5.25" drives. Most manufacturers subsequently omitted the feature.
Storage Format
DOS Version Sectors/Track Capacity Encoding
DOS 3.2.1 and earlier 13 113.75 KB GCR "5 and 3"
DOS 3.3 16 140 KB GCR "6 and 2"
ProDOS 16 140 KB GCR "6 and 2"
The 16-sector upgrade (1980) modified only controller card firmware—no drive changes required. This format provided nearly 20% more storage than standard FM drives.
Flippy Disks
Users commonly cut a second write-enable notch to use the disk's opposite side, effectively doubling capacity. Commercial software often shipped on such "flippy" disks.
Parameter Value
Model number A2M0003
Capacity 113.75 KB (DOS 3.2) / 140 KB (DOS 3.3)
Media 5.25-inch single-sided floppy
Tracks 35
Sectors 13 or 16 per track
Encoding GCR (5&3 or 6&2)
Transfer rate ~15 KB/s
Interface 20-pin ribbon cable
Controller card Required (slot 6 typical)
Case Beige-painted metal
Price (1978) US$595 with controller
Variants
Apple produced multiple 5.25-inch drive variants:
Model Name Year Notes
A2M0003 Disk II 1978 Original, full-height
A3M0004 Disk III 1980 Apple III, plastic case
A9M0108 DuoDisk 1984 Dual half-height drives
A2M4050 Disk IIc 1984 Half-height for IIc
A9M0104 UniDisk 5.25 1985 Single half-height
A9M0107 Apple 5.25 Drive 1986 Platinum gray
All variants use the same low-level disk format and are interchangeable with simple adapters.
Connection
The 20-pin ribbon cable connector is easy to misalign, which shorts an IC in the drive. A damaged drive will delete data from any inserted disk as soon as it spins—even write-protected disks. Apple printed warning messages about proper connector installation.
Later drives adopted the DB-19 connector standard to prevent this issue.
Copy Protection
The software-driven controller allowed elaborate copy protection schemes:
  • Total control over disk format
  • Non-standard sector layouts
  • Timing-based protection
  • Spiral tracks
  • Half-tracks
This made the Apple II platform notorious for copy protection innovation.
Bell & Howell Version
Apple manufactured a black-painted Disk II to match the Bell & Howell version of the Apple II Plus, sold to educational markets.
Maintenance
Head Cleaning
  • Use 5.25-inch head cleaning disk
  • Single head on bottom of mechanism
  • Clean periodically, especially with read errors
Speed Adjustment
The drive motor speed may drift over time:
  • Requires oscilloscope or specialized software
  • Adjustment potentiometer on mechanism
  • Incorrect speed causes read/write errors
Common Issues
Problem Cause Solution
Won't read Dirty head, speed drift Clean head, adjust speed
Destroys disks Misaligned connector damage Replace damaged IC
Intermittent Worn drive belt Replace belt
No spin Motor failure Replace motor or mechanism
Legacy
The Disk II was revolutionary:
  • Cheapest floppy system to date
  • Enabled VisiCalc and business applications
  • Established 5.25" format on microcomputers
  • Wozniak's most elegant engineering achievement
The drive's success was crucial to Apple II's dominance in the late 1970s and early 1980s.
Collecting
Identification
  • Model A2M0003 on controller card
  • Full-height beige metal case
  • 20-pin ribbon cable (not DB-19)
  • Shugart or Alps mechanism
Condition Assessment
  • Mint: Original box, functional, clean
  • Excellent: Functional, minimal wear
  • Good: Functional, cosmetic wear
  • Fair: Needs adjustment but works
  • Poor: Non-functional
Controller Card
The controller card is essential—the drive alone is incomplete. Cards are reusable with later drives via adapters.
  • Wikipedia — Disk II
  • Byte Magazine (January 1985) — Wozniak interview
  • folklore.org — Macintosh development history
