Apple Lisa General Maintenance
Revision as of 16:42, 9 February 2026 by Josh (talk | contribs)
Apple Lisa interior showing major components
Proper maintenance is essential to extending the lifespan and ensuring reliable operation of your Apple Lisa. As one of the earliest GUI-based personal computers, the Lisa requires special attention due to its age and the complexity of its systems.
Regular Cleaning
Internal Cleaning
  • Power off and unplug the Lisa; allow capacitors to discharge for at least 24 hours before opening
  • Use compressed air to remove dust from the interior, paying special attention to the power supply and cooling vents
  • Clean the motherboard (I/O board) and CPU board with a soft brush
  • Inspect and clean the expansion card slots
  • Check for signs of corrosion or electrolyte leakage from capacitors
External and CRT Cleaning
  • Clean the exterior plastic with a damp cloth and mild soap
  • Use appropriate CRT-safe glass cleaner on the display
  • Clean air vents with compressed air to maintain proper airflow
  • Inspect the rear connector panel for dust buildup
Keyboard and Mouse Cleaning
  • The Lisa keyboard uses capacitive foam pads that deteriorate over time
  • If keys are unresponsive, the foam and foil pads may need replacement
  • Clean the keyboard housing with isopropyl alcohol
  • The Lisa Mouse uses a steel ball that should be cleaned regularly
PRAM/Parameter RAM
The Lisa uses parameter memory to store configuration settings:
  • Located on the I/O board
  • Powered by a battery on some models
  • Battery leakage can cause significant board damage
  • Inspect the battery area regularly and remove or replace failing batteries
Power Supply Maintenance
Critical Safety Capacitors
The Lisa power supply contains several RIFA-style safety capacitors that are prone to failure:
  • These capacitors can crack, smoke, or explode when they fail
  • Common values include 0.1µF, 0.22µF, and 0.047µF at 250V
  • Replace with modern X2-rated safety capacitors
  • ALWAYS replace RIFA caps preventatively before powering on a long-stored Lisa
Electrolytic Capacitors
  • Power supply electrolytics should be replaced if the unit has not been serviced
  • Check for bulging, leaking, or corroded capacitor cans
  • Use capacitors rated for the appropriate voltage and temperature
Common Failure Points
Power Supply
  • RIFA safety capacitors (most common cause of smoke/failure)
  • Electrolytic capacitors in both high and low voltage sections
  • Power transistors and voltage regulators
Memory Cards
  • The Lisa uses proprietary 512K memory cards
  • RAM chip failures are common
  • Oxidation on edge connector contacts
  • Clean contacts with isopropyl alcohol and a soft eraser
I/O Board
  • IWM (Integrated Woz Machine) chip failures affect disk operations
  • ROM chip failures (version should be H/88 for Lisa 2/10)
  • Serial port driver chips
Floppy Drives
  • Sony 400K drives in Lisa 2 models often have seized mechanisms
  • Lubrication dries out over time
  • Head cleaning may be required
  • See Macintosh Floppy Drive Maintenance for compatible procedures
Widget Hard Drive (Lisa 2/10)
  • The internal Widget drive is notorious for reliability issues
  • No low-level format utility is publicly available
  • Modern alternatives include X/ProFile or IDEfile emulators
  • Consider ProFile emulation for long-term reliability
CRT Maintenance
Discharge Procedure
  • The CRT operates at high voltage and retains charge after power-off
  • Always discharge the CRT anode before working near it
  • Use proper CRT discharge procedures (see CRT Discharge Procedure)
Display Adjustments
  • Horizontal and vertical size/position adjustments are on the analog board
  • Focus and brightness controls may require adjustment after capacitor replacement
  • Some adjustments require accessing the deflection yoke
Voltage Checks
After any power supply work, verify output voltages:
  • +5V rail: 4.85V – 5.15V
  • +12V rail: 11.9V – 12.7V
  • -12V rail: within 5% of nominal
  • Check under load for proper regulation
