Macintosh LC 630 DOS Compatible Troubleshooting
Troubleshooting is essential for diagnosing and resolving issues with your Macintosh LC 630 DOS Compatible. This guide covers both standard LC 630 problems and issues specific to the DOS Compatibility Card. The dual-processor nature of this system introduces unique failure modes not present in standard Macintosh computers.
Before detailed troubleshooting, verify:
- Power cable is securely connected
- Power outlet is functioning (test with another device)
- All external cables are properly seated
- PRAM battery has not leaked (remove if suspect)
- DOS card is firmly seated in both CPU socket and PDS slot
Power Supply Specifications:
| Rail | Nominal | Acceptable Range |
| +5V | 5.00V | 4.85V – 5.15V |
| +12V | 12.00V | 11.9V – 12.7V |
| -12V | -12.00V | -11.5V – -12.5V |
| No response when power button pressed | Dead power supply | Test outlet; verify power cable; check PSU fuse |
| Clicking or ticking from PSU | Power supply failure | PSU capacitors likely failed; recap or replace PSU |
| Fans spin briefly then stop | Short circuit on logic board | Remove all cards and RAM; test with minimal config |
| Power LED on but no boot | Logic board failure | Check capacitors; verify DOS card properly seated |
| Intermittent power-on | Failing PSU capacitors | Recap power supply |
| Powers on with case open only | Interlock switch issue | Check rear panel interlock mechanism |
Power Supply Testing
- Disconnect all drives and expansion cards
- Power on and measure voltages at SIMM socket or test points
- If voltages are low or unstable, PSU needs recap or replacement
- Check for swollen or leaking capacitors in PSU (discharge before opening)
Chime but No Video
| Chime, no video on Mac | Monitor connection | Check DA-15 cable; test with known-good monitor |
| Chime, no video, drive activity | RAM issue | Reseat/test SIMM modules; try known-good RAM |
| Video works briefly then fails | Failing capacitors | Inspect and replace logic board capacitors |
| Distorted or rolling image | Video timing issue | Check monitor compatibility; verify refresh settings |
| Correct colors but dim | Monitor aging | Adjust monitor brightness; consider CRT rejuvenation |
| Stuck in PC mode (no Mac video) | DOS card mode conflict | Remove DOS card; boot Mac side; check PC Setup settings |
Video Troubleshooting Procedure
- Verify monitor works with another system
- Try a different video cable
- Remove DOS card temporarily to test base Mac video
- Reseat SIMM modules
- Check for capacitor leakage near video circuits
DOS Card Specific Issues
The DOS Compatibility Card introduces unique problems not found in standard LC 630 systems:
DOS Card Not Detected
| PC Setup shows "No card installed" | Poor card seating | Reseat DOS card in both CPU socket and PDS slot |
| Card detected but won't initialize | Corrupted PC Setup software | Reinstall PC Setup from original disks |
| Intermittent detection | Oxidized connectors | Clean card edges and sockets with DeoxIT |
| Mac boots, PC Setup crashes | Extension conflict | Boot with extensions disabled; reinstall PC Setup |
| DOS card worked then stopped | Capacitor failure on card | Inspect DOS card for leaking capacitors |
Switching Problems
| Command-Return doesn't switch | Hot-key conflict | Check PC Setup for hot-key setting; try alternative combo |
| Switch causes system hang | RAM allocation conflict | Reduce RAM allocated to DOS card |
| PC mode shows garbled video | Video configuration mismatch | Check PC video settings in AUTOEXEC.BAT |
| PC mode has no sound | SoundBlaster driver issue | Verify SOUND.COM loaded; check CONFIG.SYS |
| Mouse doesn't work in PC mode | Missing mouse driver | Install Microsoft or PS/2 mouse driver for DOS |
| Can't switch back to Mac | DOS card crash | Hard reset required; check for DOS software conflicts |
PC Mode Performance Issues
| Very slow PC performance | Shared RAM mode | Install dedicated RAM on DOS card |
| Windows 3.1 crashes frequently | Insufficient RAM | Allocate more RAM to DOS card (8 MB minimum recommended) |
| Games run slowly | CPU limitation | 486DX2/66 is period-appropriate; no significant upgrade available |
| DOS programs crash on exit | Memory manager conflict | Check CONFIG.SYS memory manager settings |
| CD-ROM not accessible in DOS | Driver not loaded | Install MSCDEX and CD-ROM driver in CONFIG.SYS |
DOS Card RAM Issues
| PC Setup shows 0 MB for DOS | SIMM not recognized | Reseat DOS card SIMM; try different SIMM |
| Less RAM than expected | SIMM compatibility | Use 80ns or faster 72-pin SIMM; 32 MB maximum |
| DOS reports less than allocated | DOS conventional memory limit | Normal DOS limitation; use memory manager for extended |
| Random crashes in PC mode | Bad SIMM | Test SIMM in Mac slots; replace if faulty |
| Random freezes on Mac side | Failing capacitors | Recap logic board |
| Freezes when accessing floppy | Floppy drive failure | Clean/replace floppy drive |
| Freezes when accessing HD | IDE drive or cable | Check IDE cable; try different drive |
| Freezes after sleep/wake | PRAM corruption | Zap PRAM (Cmd-Opt-P-R at startup) |
| Freezes with specific software | Software incompatibility | Test with clean System install |
| Freezes when switching Mac/PC | DOS card connector issue | Reseat and clean DOS card connections |
Sad Mac Error Codes
See the Sad Mac Error Codes page for a complete reference. Common codes for LC 630 systems:
| Code | Meaning | Action |
| 0000000F 00000001 | ROM test failed | Check ROM chips; logic board may need replacement |
| 0000000F 00000002 | Memory (RAM) test exception | Test/replace SIMM; check SIMM sockets |
| 0000000F 00000003 | Memory (RAM) test error | Reseat/replace RAM; clean SIMM sockets |
| 0000000F 00000004 | Memory (RAM) addressing failure | Try individual SIMMs to isolate failure |
| 0000000F 00000005 | Memory (RAM) addressing failure | SIMM compatibility issue; try different SIMM |
| 0000000F 00000010 | NuBus/PDS test failure | DOS card may have issues; remove and test Mac boot |
| 0000000D 0000XXXX | Exception in boot code | Logic board issue; check capacitors |
Interpreting Sad Mac Codes
The Sad Mac code consists of two hex numbers:
- First number: Error class
- Second number: Specific error within that class
For RAM errors, the second number often indicates which SIMM bank failed.
Floppy Drive Issues
| Disk not recognized | Dirty heads | Clean heads with cleaning disk |
| Disk stuck in drive | Mechanical failure | Manually eject with paper clip; inspect mechanism |
| Read errors only | Failing drive | Clean heads; replace drive if persistent |
| Write errors | Write-protect tab on | Check disk write-protect; try different disk |
| Drive makes grinding noise | Mechanical wear | Replace floppy drive mechanism |
| PC mode can't access floppy | Driver issue | Check BIOS settings; verify floppy enabled in PC Setup |
Capacitor Failure and Recapping
Capacitor failure is the most common issue in 30+ year-old LC 630 systems:
| Capacitor Location | Symptom | Fix |
| Audio section | Distorted or no sound | Replace audio capacitors |
| Power regulation | Unstable operation, random resets | Replace all electrolytic capacitors |
| Video circuits | Image distortion, color issues | Replace capacitors near video circuits |
| Clock circuits | Incorrect time, PRAM not saved | Replace capacitors; check battery |
| DOS card | PC mode failures, detection issues | Inspect and replace DOS card capacitors |
See Macintosh LC 630 DOS Compatible Capacitor Replacement Guide for complete specifications and procedures.
IDE Drive Issues
| Drive not recognized | Old drive formatting | Use Drive Setup 1.0.3+ (System 7.5.2+) |
| Drive spins but not mounted | Partition corruption | Initialize with Drive Setup or third-party tool |
| Slow drive access | PIO mode limitation | Normal for 630; max PIO Mode 3 (11.1 MB/s) |
| "The disk is unreadable" | Modern drive incompatibility | Use Drive Setup; format with 630-compatible utility |
| Drive works on Mac but not PC | FAT partition issue | Create proper DOS partition using PC FDISK |
| Clicking from drive | Drive failure | Backup immediately; replace drive |
IDE Controller Limitations:
- Single device only (no master/slave)
- 8 GB addressing limit
- PIO Mode 3 maximum
CD-ROM Issues
| CD not recognized in Mac | Driver not loaded | Check System extensions for Apple CD driver |
| CD not recognized in DOS | MSCDEX not loaded | Install MSCDEX in AUTOEXEC.BAT |
| Audio CDs play but data fails | SCSI issue | Check internal SCSI cable; clean connectors |
| Tray won't eject | Mechanical failure | Use paperclip emergency eject; clean mechanism |
| Random read errors | Dirty lens | Clean laser lens with CD cleaning disc |
Troubleshooting Flowchart
System Won't Power On:
- Check power cable and outlet → Working? Continue.
- Open case, check for obvious damage → Found? Repair first.
- Disconnect all drives and cards → Boot now? Reconnect one at a time.
- Still dead → Power supply needs recap or replacement.
System Powers But No Boot:
- Listen for chime → No chime? RAM or logic board issue.
- Chime heard? → Check monitor connection.
- Reseat all RAM → Try with minimal RAM.
- Remove DOS card → Mac boots? DOS card connection issue.
- Still no boot → Check capacitors; consider recap.
Mac Works, DOS Card Fails:
- Open PC Setup → Card detected? If no, reseat card.
- Clean DOS card edge connectors with DeoxIT.
- Check for capacitor leakage on DOS card.
- Try reinstalling PC Setup software.
- Test with different DOS card if available.
