Macintosh Centris 610 Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh Centris 610 (or Macintosh Quadra 610) is essential for long-term reliability. The original surface-mount capacitors leak electrolyte over time, causing corrosion and potential component damage.
Note: The Centris 610 and Quadra 610 share the same logic board. This guide applies to both models.
Why Recap?
The Centris/Quadra 610 logic board uses surface-mount electrolytic capacitors manufactured in the early 1990s. These capacitors:
- Leak electrolyte as they age
- Cause corrosion on PCB traces
- Lead to intermittent failures and crashes
- Can damage nearby components if left unchecked
Capacitor Inspection
Before recapping, inspect the logic board for signs of failure:
- Bulging Tops – The top of the capacitor is domed instead of flat
- Leaking Electrolyte – Brown or amber residue around the capacitor base
- Corrosion or PCB Staining – Discoloration on the board near capacitors
- Crystalline Deposits – White or tan crystalline buildup
Macintosh Centris 610 Capacitor List
Logic Board Capacitors
| Designation | Capacitance | Voltage | Type | Quantity |
| All positions | 47µF | 16V | SMD Electrolytic | 10× |
All 10 capacitors on the Centris/Quadra 610 logic board are the same value: 47µF 16V surface-mount electrolytics.[1]
Replacement Options
Electrolytic (traditional):
- Nichicon, Rubycon, or Panasonic SMD electrolytics
- 47µF 16V or higher voltage rating
- Match original footprint (6.3mm diameter typical)
Tantalum (longer life):
- KEMET T491 series: T491D476K016AT (47µF 16V)
- More reliable, lower ESR
- Observe correct polarity (tantalums fail short if reversed)
Power Supply Capacitors
The Centris 610 uses the ASTEC AA16990 power supply (Apple part 614-0022). The PSU also contains electrolytic capacitors that may need replacement. Consult the power supply service guide for cap values and locations.
⚠️ Warning: Power supplies contain high voltages. Discharge all capacitors before servicing.
- Prepare the workspace – Use an ESD mat and wrist strap
- Remove the logic board – Disconnect all cables, remove screws, slide board out
- Document capacitor positions – Note polarity markings (stripe = negative)
- Remove old capacitors – Use hot air or low-temp solder paste to desolder
- Clean pads – Remove old solder with wick, clean with isopropyl alcohol
- Inspect for damage – Check traces for corrosion; repair if necessary
- Install new capacitors – Observe correct polarity; stripe = negative
- Solder carefully – Use appropriate temperature for SMD work
- Clean residue – Remove flux with isopropyl alcohol
- Inspect solder joints – Check for bridges or cold joints
- Reinstall and test – Power on and verify operation
Recommended Tools
- Hot air rework station (optional but helpful for SMD)
- Solder wick or desoldering pump
- Fine leaded solder (0.5mm or 0.3mm)
- Flux (no-clean or water-soluble)
- Isopropyl alcohol (90% or higher)
- ESD brush for cleaning
- Multimeter
- Magnification (loupe or microscope)
- ESD mat and wrist strap
Post-Recap Testing
After recapping:
- Visual inspection of all solder joints
- Continuity test on replaced capacitors
- Power-on test (listen for startup chime)
- Extended run test (several hours)
- Check voltages if experiencing issues
Additional Tips
- Work in a well-lit, clean environment
- Take photos before removing capacitors
- If traces are damaged, repair with wire or conductive ink before recapping
- Consider replacing the PRAM battery at the same time
- Clean the entire logic board with isopropyl alcohol after recapping
- Store removed capacitors for reference if needed
