Macintosh Performa 466
Revision as of 12:12, 10 February 2026 by Josh (talk | contribs) (Add Service Documentation section with embedded Apple Service Source PDF)
TypePersonal Computer
ReleasedOctober 18, 1993
DiscontinuedNovember 1, 1993
Intro priceUS$1,500
CPUMotorola 68030 @ 33 MHz
Memory4 MB RAM (expandable to 36 MB)
Storage160 MB SCSI hard drive, 1.44 MB floppy
Display512x384-832x624 (up to 16-bit)
Sound8-bit mono
Dimensions2.9" H x 12.2" W x 15.3" D
Weight8.8 lbs (4 kg)
OS / FirmwareSystem 7.1P - 7.6.1
PredecessorPerforma 460
SuccessorPerforma 475
Model no.M1254
The Macintosh Performa 466 is a consumer-oriented personal computer introduced by Apple Computer on October 18, 1993.[1] It is a rebrand of the LC III+ and is identical to the Performa 460, but shipped with a larger 160 MB hard drive.
The Performa 466 uses a Motorola 68030 processor running at 33 MHz with a 32-bit data path. It shipped with 4 MB of RAM (expandable to 36 MB using a single 72-pin SIMM), 512 KB of VRAM (expandable to 768 KB), and a 160 MB SCSI hard drive. An optional 68882 FPU could be installed.
Component Specification
CPU Motorola 68030 @ 33 MHz (32-bit data path)
FPU Optional 68882
System Bus 33 MHz
ROM 1 MB
RAM 4 MB onboard (expandable to 36 MB via 72-pin SIMM)
VRAM 512 KB onboard (expandable to 768 KB)
Storage 160 MB SCSI hard drive, 1.44 MB floppy
Expansion 1x LC III PDS slot
Ports ADB, SCSI, 2x Serial (Modem/Printer), Audio out
Display Up to 832x624 @ 8-bit (512 KB), 832x624 @ 16-bit (768 KB)
Power 100V-240V AC, 50 W max
Relationship to LC III+
The Performa 466 is identical to the LC III+ and Performa 460 internally. The only difference from the Performa 460 is the larger 160 MB hard drive.
For detailed maintenance procedures including cleaning, PRAM battery management, and connector maintenance, refer to the Macintosh LC III General Maintenance page.
A troubleshooting guide addressing common issues is available on the Macintosh LC III Troubleshooting page.
Capacitor replacement information for the logic board can be found on the Macintosh LC III Capacitor Replacement Guide page.
  1. โ†‘ Macintosh Performa 466 Specs, EveryMac.comโ€”link(accessed 2026-02-10)
