Battery Explosion, Capacitor or Corrosion Damage
Battery explosions, capacitor failures, and electrolyte corrosion are among the most common and destructive problems affecting vintage electronics. This guide provides a structured approach to assessing damage, cleaning affected areas, and restoring functionality to damaged circuit boards.
Overview
Electronic devices from any era can suffer from corrosive damage, but vintage equipment from the 1980s through early 2000s is particularly susceptible. The primary sources of corrosive damage include:
Battery Leakage
Batteries are electrochemical cells that convert chemical energy into electrical energy. When they fail, the chemicals inside can leak out and cause significant damage to surrounding components.
- Alkaline batteries (AA, AAA, C, D, 9V) โ The most common household batteries, containing potassium hydroxide (KOH) as their electrolyte. When they leak, they produce a white, chalky crystalline residue that is highly caustic (pH ~14). The leakage typically occurs when batteries are left in devices for extended periods, especially when depleted, as internal pressure builds up. Temperature fluctuations accelerate this process.
- Lithium batteries (3.6V PRAM/CMOS batteries, CR2032 coin cells) โ Used in computers and electronics to maintain clock and configuration data. When these fail, they can leak lithium compounds and organic solvents. The 1/2 AA sized lithium cells commonly found in vintage computers (particularly those from the late 1980s and early 1990s) are notorious for leaking as they approach 15-20 years of age.
- NiCd batteries (Nickel-Cadmium) โ Rechargeable batteries that also use potassium hydroxide as their electrolyte. They leak in the same manner as alkaline cells but are often found in sealed battery packs where the damage can go unnoticed for years.
- Lead-acid batteries โ Found in UPS systems, emergency lighting, and some portable equipment. They contain sulfuric acid (HโSOโ) which is highly corrosive to metals and can cause severe chemical burns. These require different neutralization procedures.
Capacitor Failure
Capacitors store electrical energy and are essential components in virtually all electronic circuits. They can fail in several ways, with leakage being the most damaging to surrounding components.
- Through-hole electrolytic capacitors โ Traditional upright cylindrical capacitors with wire leads. They contain a liquid or gel electrolyte that becomes increasingly corrosive as it ages. When the internal seal fails (due to age, heat, overvoltage, or manufacturing defects), this electrolyte leaks onto the PCB and attacks copper traces, solder joints, and nearby components. The electrolyte typically contains ethylene glycol, boric acid, and ammonium borate.
- Surface-mount electrolytics (SMD) โ Smaller versions of electrolytic capacitors designed for automated assembly. These are particularly notorious for failure, especially units manufactured between 1999 and 2007 during the "capacitor plague" era. The problem stemmed from stolen and incorrectly copied electrolyte formulas that caused premature failure. Devices from this era (including computers, monitors, televisions, and game consoles) are especially prone to capacitor failure.
- Tantalum capacitors โ Solid-state capacitors that can fail catastrophically, sometimes with fire or small explosions. When they fail, they typically short-circuit rather than leak, but the heat generated can damage surrounding components and traces.
- Polymer capacitors โ Modern solid polymer capacitors that are generally more reliable than traditional electrolytics but can still fail. They are increasingly used as replacements for problematic electrolytic capacitors in restoration work.
Both types of leakage are progressiveโif left untreated, corrosion will continue spreading along traces and through vias, eventually rendering the board unrepairable. The electrolyte can travel considerable distances along traces, under components, and through via holes to affect components on both sides of a PCB.
Understanding the Chemistry
Knowing what you're dealing with helps you choose the correct cleaning approach. Different contaminants require different neutralizing agents:
| Source | Chemical Composition | pH | Neutralizing Agent | Notes |
| Alkaline batteries | Potassium hydroxide (KOH) | ~14 (highly alkaline) | White vinegar (acetic acid) | Most common type of battery damage |
| NiCd batteries | Potassium hydroxide (KOH) | ~14 (highly alkaline) | White vinegar (acetic acid) | Often found in older laptops and power tools |
| Zinc-carbon batteries | Ammonium chloride, zinc chloride | ~4-5 (mildly acidic) | Baking soda solution | Older battery technology, now less common |
| Lithium batteries | Lithium salts, organic solvents | Varies | Isopropyl alcohol, then water rinse | Handle with care; compounds may be flammable |
| Lead-acid batteries | Sulfuric acid (HโSOโ) | ~1 (highly acidic) | Baking soda solution | Extremely dangerous; use appropriate PPE |
| Electrolytic capacitors | Ethylene glycol, boric acid, ammonium borate | ~4-7 (mildly acidic to neutral) | Baking soda solution or IPA | Most common cap damage source |
| Tantalum capacitors | Manganese dioxide, tantalum pentoxide | N/A (solid) | IPA only (remove debris) | Usually fails short, may cause fire |
Never mix cleaning agents. Combining acids and bases can cause violent reactions. Rinse thoroughly with IPA between different cleaning solutions. Always work in a well-ventilated area. |
The Science of Corrosion
Understanding how corrosion works helps explain why prompt treatment is essential:
Electrochemical corrosion occurs when an electrolyte (the leaked battery or capacitor contents) bridges two dissimilar metals, creating a galvanic cell. This causes the more reactive metal (usually the copper traces) to oxidize and dissolve. The process is self-perpetuating because:
- The corrosion products are often hygroscopic (they absorb moisture from the air)
- Moisture accelerates the electrochemical reaction
- The reaction produces more corrosive compounds
- The cycle continues until the copper is completely consumed or the contamination is removed
Through-via migration is particularly insidious. Electrolyte that reaches a via (a plated-through hole connecting traces on different PCB layers) can travel through capillary action to affect components on the opposite side of the board. This is why visible damage on one side of a board often indicates hidden damage on the other.
Damage Assessment
Before beginning any repair, thoroughly assess the extent of the damage to determine if the board is salvageable.
Visual Inspection
Systematic visual inspection should be performed under good lighting, preferably with magnification:
| Indicator | Description | Severity | Prognosis | Action Required |
| White/green crystalline deposits | Dried electrolyte residue on surface | Moderate | Usually repairable | Clean and test |
| Brown or tan staining on PCB | Active corrosion spreading through substrate | Moderate to Severe | Repairable if caught early | Immediate cleaning required |
| Green patina on copper traces | Copper oxidation (verdigris) | Severe | May need trace repair | Clean, assess trace integrity |
| Darkened or discolored substrate | Electrolyte has penetrated the FR4 | Severe | Board may be compromised | May need extensive repair or replacement |
| Bubbling or blistering of solder mask | Electrolyte trapped under mask | Severe | Contamination may spread | Remove mask, clean underneath |
| Missing or eaten-through traces | Electrolyte has destroyed copper | Critical | Requires trace jumpers | Document and repair each trace |
| Corroded component leads | Damage spreading to components | Critical | Components may need replacement | Test components before reinstalling |
| Corroded or green socket pins | Damage to IC sockets | Critical | Intermittent failures likely | Replace sockets |
| Lifted solder pads | PCB substrate adhesion failure | Critical | Difficult repair, may not hold | Requires careful pad repair |
| Swollen or delaminated PCB | Substrate damage from chemical attack | Critical | Board may be unrepairable | Assess if structurally sound |
Electrical Testing
Before cleaning, document the damage electrically:
1. Visual Documentation
- Take high-resolution photographs from multiple angles
- Use consistent lighting to show corrosion extent
- Photograph both sides of the board
- Create a diagram marking affected traces and components
- These records will be invaluable during repair
2. Continuity Testing
- Use a multimeter in continuity mode (or low resistance mode for longer traces)
- Test traces that pass through the affected area from end to end
- Document which traces are broken โ you may not see breaks under corrosion
- Test for shorts between adjacent traces (corrosion can be conductive when wet)
- Pay special attention to power and ground traces
3. Power Rail Testing
- Check for shorts between VCC and GND
- Measure resistance between all power rails (should not be zero or very low)
- A dead short indicates severe damage or shorted components
- Resistance under 100ฮฉ on a power rail usually indicates a problem
4. Component Testing
- If possible, remove components from the affected area for testing
- Check resistor values (corrosion can change them)
- Test diode polarity and forward voltage drop
- Measure capacitor ESR if you have an ESR meter
- Note any components that will need replacement
Assessing Repairability
After inspection, make an honest assessment:
Likely Repairable:
- Surface corrosion that hasn't penetrated traces
- A few broken traces that can be jumped
- Damage limited to one area of the board
- Non-critical support circuitry affected
Questionable:
- Multiple layer damage (traces on both sides affected)
- Many vias compromised
- Damage to dense component areas (BGAs, fine-pitch ICs)
- Critical timing-sensitive circuits affected
Probably Not Repairable:
- Extensive substrate delamination
- Hundreds of broken traces
- Main processor or memory areas destroyed
- Multilayer boards with internal layer damage
- When repair cost exceeds replacement cost
Required Materials and Tools
Cleaning Supplies
| Item | Purpose | Notes |
| White vinegar (5% acetic acid) | Neutralize alkaline corrosion | Standard household vinegar works well |
| Baking soda (sodium bicarbonate) | Neutralize acidic corrosion | Mix 1 tablespoon per cup (240ml) of distilled water |
| Distilled water | Diluting solutions, rinsing | Never use tap water โ mineral content causes new corrosion |
| 99% Isopropyl alcohol (IPA) | Final cleaning, moisture displacement | 99% is essential; 70% contains too much water and won't dry properly |
| Soft plastic brushes | Scrubbing | Toothbrush, ESD-safe PCB brush, acid brush, or dedicated electronics brush |
| Cotton swabs | Detail cleaning | Both standard and pointed tip varieties; lint-free foam swabs for critical areas |
| Melamine foam ("Magic Eraser") | Stubborn deposits | Use with very light pressure to avoid abrading traces |
| Lint-free cloths | Drying, wiping | Microfiber or cleanroom wipes; avoid paper towels which leave fibres |
| Wooden or plastic toothpicks | Removing deposits | Safe for use near components; won't scratch |
| Masking tape (low-tack) | Protecting clean areas | Blue painter's tape is ideal |
| Compressed air | Drying, debris removal | Canned air or compressor with water trap and oil filter |
| Plastic containers | Soaking baths | For IPA or cleaning solution immersion |
Repair Tools
| Temperature-controlled soldering iron | Component removal/installation | 60W+ recommended for ground planes; fine tip for SMD work |
| Hot air rework station | SMD removal, even heating | Essential for damaged pads; prevents further damage |
| Solder wick/braid | Removing excess solder | Multiple widths (1.5mm, 2.5mm, 3.5mm) useful |
| Flux (no-clean or rosin) | Improving solder flow | Gel flux easiest to control; paste flux for stubborn joints |
| Quality solder | Re-soldering joints | 63/37 leaded preferred for repair work; 0.5mm and 0.8mm diameters |
| 30 AWG kynar wire | Trace jumpers | Also called wire-wrap wire; available in multiple colours for organization |
| Kapton tape | Insulation, securing jumpers | Heat resistant to 400ยฐC; won't melt during soldering |
| Multimeter | Testing | Continuity, voltage, resistance; auto-ranging preferred |
| Magnification | Inspection | 10x loupe, stereo microscope, or USB microscope (40x-100x useful) |
| Fibreglass scratch pen | Exposing copper for jumpers | Use sparingly and carefully; don't over-abrade |
| Craft knife or scalpel | Precise work | Removing solder mask, cutting traces if needed |
| Helping hands/PCB holder | Steady work surface | Essential for delicate work |
| Desoldering pump (solder sucker) | Clearing through-holes | Spring-loaded type with silicone tip |
Safety Equipment
- Safety glasses โ Essential when scrubbing (chemicals can splash) and during soldering
- Nitrile gloves โ Protect skin from chemicals and prevent contamination of the board
- Adequate ventilation โ Especially when using solvents or hot air rework
- Fume extraction โ For soldering work; protects against flux fumes
- ESD protection โ Wrist strap and mat when handling sensitive components
- First aid kit โ Including eyewash solution for chemical splashes
Lead-acid battery damage requires extra precautions. Sulfuric acid causes severe burns. Wear chemical-resistant gloves, full eye protection, and protective clothing. Work outdoors or in a well-ventilated area. Have baking soda and water ready to neutralize spills. |
Cleaning Procedure
Step 1: Preparation
- Disconnect all power sources โ Remove batteries, unplug power supplies, discharge any large capacitors
- Photograph the damage โ Document everything before disturbing anything; take photos from multiple angles
- Remove socketed components โ Carefully pull ICs, RAM, ROM chips, and CPUs; set aside in antistatic containers
- Remove accessible connectors โ Ribbon cables, header connectors, anything that could trap contamination
- Remove the battery or failed capacitors โ The source of contamination must be removed before cleaning
- Set up your workspace โ Good lighting, ventilation, all materials at hand, antistatic mat in place
- Plan your cleaning approach โ Note the areas to clean and the order you'll work in
Step 2: Initial Dry Cleaning
Before applying any liquids, remove as much dry contamination as possible:
- Use a soft brush to remove loose debris and crystallized deposits
- Vacuum (with an ESD-safe vacuum if available) or use compressed air to remove particles
- Hold the board firmly when using compressed air to prevent damage
- Do not scrub aggressively โ you may push contamination into vias or under components
- Remove any large chunks of corrosion carefully with plastic tweezers
- Brush out IC sockets, connector housings, and other cavities
Step 3: Identify the Contaminant
Determine what leaked to choose the correct neutralizing agent:
Alkaline battery leak (most common):
- White or blue-green crystalline deposits
- Caustic smell (like bleach or ammonia)
- Chalky texture when dry
- pH test strip shows high alkalinity
- Neutralize with: White vinegar (50/50 with distilled water)
Capacitor electrolyte:
- Brown, tan, or orange sticky residue
- Fishy or chemical smell
- May appear oily or waxy
- Usually localized around capacitor footprints
- Neutralize with: Baking soda solution, then IPA
Unknown source:
- When unsure, treat as acidic first (baking soda)
- Then treat as alkaline (vinegar)
- Rinse thoroughly with IPA between treatments
Step 4: Neutralization
For Alkaline Contamination (batteries, NiCd cells):
- Prepare a 50/50 solution of white vinegar and distilled water in a small container
- Using a brush, apply the solution liberally to the affected area
- You may see fizzing as the acid neutralizes the base โ this is normal
- Gently scrub the affected area, working the solution into all crevices
- Tilt the board to allow the solution to flow under components if possible
- Do NOT let the solution dry on the board โ it will leave acidic residue
- Proceed immediately to Step 5 (water rinse) within 2-3 minutes
For Acidic Contamination (capacitors, lead-acid):
- Prepare baking soda solution: 1 tablespoon (15g) per cup (240ml) of distilled water
- Stir until fully dissolved
- Apply to affected area with a brush
- Gently scrub; the solution will neutralize acidic residue
- Work the solution into all affected areas
Time is critical during neutralization. Vinegar, while neutralizing alkaline damage, is itself acidic and will damage copper if left on the board. Never let neutralizing solutions dry on the board โ always rinse within 2-3 minutes. |
Step 5: Distilled Water Rinse
- Rinse the treated area thoroughly with distilled water
- Use a brush to help remove neutralized residue
- Pay attention to areas under components and in vias
- Ensure all cleaning solution is removed
- Pat dry with lint-free cloth to remove excess water
- Do not wait for complete drying before proceeding to Step 6
Step 6: IPA Flood
This step is critical for removing all moisture and remaining contamination:
- Flood the entire affected area with 99% isopropyl alcohol
- Use a clean brush to scrub thoroughly
- IPA displaces water (which is why 99% is essential) and carries away dissolved contaminants
- Work the IPA into vias and under components
- Tilt the board to allow IPA to flow through affected areas
- Repeat 2-3 times with fresh IPA until runoff appears clean
- For severe contamination, consider submerging the entire board in an IPA bath for 15-30 minutes
- Agitate the board periodically when soaking
Step 7: Detail Cleaning
- Use cotton swabs dipped in fresh IPA for precision cleaning
- Clean inside chip sockets thoroughly โ corrosion on socket contacts causes intermittent failures
- Clean component pins that were in the affected area
- Use pointed swabs to reach into corners and under component edges
- For stubborn spots, use a melamine foam pad with very light pressure
- Use a fibreglass scratch pen only on areas where you intend to solder (exposed copper for jumpers)
- Clean the underside of any components you removed
- Clean the leads of socketed ICs before reinstalling
Step 8: Drying
Thorough drying is essential to prevent new corrosion:
- Use compressed air to blow out vias, socket cavities, and component cavities
- Blow air from multiple angles to ensure water/IPA is pushed out of all crevices
- Allow to air dry for at least 30-60 minutes at room temperature
- For faster drying, use warm air (heat gun on lowest setting, held 15-20cm away)
- Never use high heat โ this can damage components and cause thermal shock
- A fan directed at the board accelerates drying
- Optionally, place in a warm location (on top of a computer, in sunlight, etc.)
Step 9: Final Inspection
- Examine under magnification for any remaining contamination
- Look for white residue (indicates incomplete cleaning)
- Check for any damage that became visible after cleaning
- Verify trace continuity with multimeter โ compare to pre-cleaning notes
- Look for lifted pads, cracked traces, or damaged components
- Identify any traces that need repair before proceeding
Component Removal Techniques
Battery and Battery Holder Removal
When the battery itself or its holder is corroded and must be removed:
Through-hole battery holders:
- Apply flux generously to all solder joints
- Add fresh leaded solder to the joints (lowers melting point and improves heat transfer)
- Heat one joint while applying gentle upward pressure on that side of the holder
- Alternate between joints, gradually working the holder free
- If the holder is through-hole, use solder wick to clear the holes afterward
- For stubborn joints, use a desoldering gun or solder sucker
- Clean the area thoroughly with IPA before installing replacement
Direct-soldered batteries:
- Cut the battery leads if possible to remove the battery quickly
- Avoid heating the battery โ lithium cells can catch fire
- Desolder the remaining lead stubs normally
Through-Hole Capacitor Removal
Standard removal (non-damaged boards):
- Heat one lead while applying gentle pressure to that side of the capacitor
- Alternate between leads until the capacitor releases
- Use solder wick to clean the holes
- If holes are blocked, apply flux and fresh solder, then clear with desoldering pump
For corroded boards (pad damage risk):
- Apply flux generously to the joints
- Add fresh solder to improve heat transfer (flux cored solder works well)
- Work quickly โ prolonged heat increases the risk of pad lifting
- If a pad begins to lift, STOP immediately and assess
- Consider using hot air instead of an iron for reduced mechanical stress
- Once removed, add fresh solder to the holes before clearing them (flux helps)
If pads have already lifted:
- Document which pads are damaged
- Trace where each pad connected (continuity test to nearest component)
- You will need to run jumper wires to these points
SMD Capacitor Removal
Hot Air Method (Recommended for damaged boards):
- Apply gel flux to both ends of the capacitor
- Set hot air station to appropriate temperature (typically 300-350ยฐC for lead-free, 260-300ยฐC for leaded)
- Use a medium airflow setting to avoid blowing small components away
- Hold the nozzle 1-2cm above the component
- Apply hot air evenly, moving in small circles
- Watch for the solder to become shiny (indicates melting)
- Use fine tweezers to lift the capacitor once both ends have melted
- Be prepared for a "pop" if the capacitor is internally pressurized (failing caps often are)
- Clean the footprint with solder wick and IPA
Soldering Iron Method:
- Use a wide chisel tip or a specialized SMD tip
- Apply gel flux to both terminals
- If your tip is wide enough, heat both ends simultaneously
- Otherwise, add solder to create a "bridge" connecting both pads, then heat the bridge
- Alternatively, alternate quickly between ends while applying gentle upward pressure
- Work quickly to minimize heat exposure to the pads
Corrosion weakens the adhesive bond between pads and PCB substrate. Work quickly and do not apply excessive mechanical force. A lifted pad requires trace repair. If you feel resistance when the solder is melted, check that both ends are truly liquid before applying force. |
Post-Removal Cleaning
- Clean the footprint thoroughly with IPA
- Remove all old solder if replacing the component (fresh solder only)
- Inspect pads under magnification
- Test trace continuity to the pads before installing new components
- If continuity is lost, you'll need to run a jumper wire
Trace Repair Techniques
When traces have been damaged by corrosion, they must be repaired for the board to function.
Assessing Trace Damage
Before repairing, understand what you're working with:
- Obtain schematics if available โ Makes tracing connections much easier
- Use a multimeter to trace connections โ Test continuity from component to component
- Identify exactly where each trace goes โ Note the start point, end point, and any branches
- Check for via connections โ Traces often connect to other layers via plated-through holes
- Plan your repair route โ Determine the easiest path for jumper wires
- Consider alternatives โ Sometimes it's easier to connect to a different point on the same net
Minor Damage โ Reinforcing Weakened Traces
For traces that are thinned but not completely broken:
- Clean the trace with IPA and let dry
- Gently scrape the solder mask off the thinned area using a craft knife or fibreglass pen
- Apply flux along the exposed copper
- Flow fresh solder along the trace to "tin" it โ this reinforces the remaining copper
- The solder layer provides an additional conduction path
- Test continuity to verify the repair
- Optionally, apply conformal coating or nail polish to protect the repair
Severed Traces โ Jumper Wire Repair
For traces that are completely broken:
- Identify both endpoints of the break
- Find where the trace comes from (which component pin)
- Find where the trace goes to (which other component pin)
- If the trace is very short, you may be able to see both ends
- Expose clean copper at each end:
- Gently scrape the solder mask away using a fibreglass pen or craft knife
- Expose 2-3mm of clean, shiny copper
- Alternatively, solder directly to component legs if they're accessible
- Test points, via pads, and unpopulated pads are also good attachment points
- Prepare the jumper wire:
- Cut an appropriate length of 30 AWG kynar wire
- Leave some slack โ too short is much worse than too long
- Strip 3-4mm of insulation from each end
- Tin both ends with solder
- Attach the jumper:
- Apply flux to the connection points
- Position one end of the wire and solder it in place
- Route the wire neatly (avoid crossing sensitive areas or heat sources)
- Solder the other end
- Use the minimum heat necessary to avoid pad damage
- Verify and secure:
- Test continuity to confirm the connection
- Test for shorts to adjacent traces
- Secure the wire with Kapton tape or a small dab of hot glue
- Document the repair (photograph, note on schematic)
Via Damage โ Through-Board Connections
Damaged vias require connecting traces on opposite sides of the board:
- Identify the trace on each side that connects to the via
- Find suitable solder points on each side (component legs, test points, other vias)
- Route jumper wire through a nearby hole or around the board edge
- Solder both ends and verify continuity
- Note: Via repairs can be complex โ if a via is damaged, look for alternative connection points on the same net
For multilayer boards with internal layer connections, via damage may be unrepairable without adding jumper wires to replicate the connection.
Multiple Trace Repair
For extensive damage requiring many repairs:
- Work systematically โ Repair one trace completely before moving to the next
- Use different coloured wires for easier debugging (e.g., red for power, black for ground, other colours for signals)
- Label complex repairs with tape flags or a reference diagram
- Test functionality incrementally if possible โ repair power/ground first, then test for voltage; repair clock/reset, then test for processor activity
- Keep detailed notes โ Future repair work depends on understanding what's been done
- Take photos of completed repairs for reference
Capacitor Replacement
Selecting Replacement Capacitors
When replacing failed capacitors, matching the original specifications is important:
| Parameter | Requirement | Notes |
| Capacitance | Match original value | Exact match preferred; ยฑ20% usually acceptable for filtering/decoupling |
| Voltage rating | Match or exceed original | Higher voltage rating is always acceptable and often preferred |
| Temperature rating | 105ยฐC preferred | Especially important for power supply applications and near heat sources |
| ESR (Equivalent Series Resistance) | Match original for switching supplies | Low-ESR required for switch-mode power supplies; higher ESR acceptable for linear filtering |
| Type | Match original type | Don't substitute electrolytics for tantalum or ceramic without understanding the circuit |
| Size | Must fit footprint | Check both diameter and height; ensure clearance above the capacitor |
| Polarity | Match original orientation | The stripe on electrolytics indicates the negative terminal |
Recommended Capacitor Brands
Use high-quality Japanese or European manufacturers for reliability:
Top Tier (Recommended):
- Nichicon โ Excellent general-purpose electrolytics; wide range available
- Rubycon โ Premium quality, very low failure rates; commonly used in professional equipment
- Panasonic โ Wide range including low-ESR types; good availability
- Nippon Chemi-Con โ High quality, good for audio applications
- United Chemi-Con (UCC) โ Rubycon subsidiary; excellent quality
Good Quality:
- Elna โ Quality audio-grade capacitors; known for audio equipment
- Sanyo/Sun Electronic โ Good quality, especially the OSCON polymer line
- KEMET โ American manufacturer with good quality polymer and tantalum caps
Avoid:
- Generic Chinese capacitors from unknown brands
- Anything suspiciously cheap (quality caps cost money)
- Brands associated with the capacitor plague (CapXon, G-Luxon, some Tayeh products from early 2000s)
- Used or salvaged capacitors (unknown history)
Installation Best Practices
- Verify capacitor polarity โ The stripe indicates the negative lead
- Check the PCB markings โ Look for + or - symbols, or a filled/unfilled semicircle
- Double-check orientation against photographs of the original
- For through-hole capacitors:
- Insert the capacitor with correct polarity
- Bend the leads slightly outward to hold it in place
- Flip the board and solder both leads
- Trim excess lead length
- For SMD capacitors:
- Apply flux to the pads
- Tin one pad with fresh solder
- Position the capacitor and reflow that pad to hold it
- Touch up the first joint if needed
- Clean flux residue with IPA after soldering
- Inspect under magnification for cold joints or bridges
Testing and Reassembly
Initial Power-On Testing
Before reassembling completely, test the repair:
- Visual inspection โ Verify all repairs before applying power
- Check for shorts โ Measure resistance between main power rails
- Use a current-limited power supply if available for first power-on
- Set current limit to slightly above normal operating current
- The supply will limit current if a short exists, preventing further damage
- Monitor current draw โ Compare to known-good specifications
- Listen for unusual sounds โ Buzzing, clicking, or high-pitched whines may indicate problems
- Smell for burning โ Turn off immediately if you smell anything burning
Voltage Verification
Check key voltage rails before installing sensitive components:
| Rail | Typical Range | Common Uses |
| +5V | 4.85V โ 5.25V (ยฑ5%) | Most logic ICs, sensors, USB power |
| +3.3V | 3.135V โ 3.465V (ยฑ5%) | Modern logic, SD cards, some sensors |
| +12V | 11.4V โ 12.6V (ยฑ5%) | Motors, fans, disk drives, analog circuits |
| +9V | 8.5V โ 9.5V | Older systems, MIDI devices |
| -5V | -4.75V to -5.25V | Older computers (ISA bus), some analog circuits |
| -12V | -11.4V to -12.6V | RS-232 interfaces, some analog circuits |
Functional Testing
- Install socketed components one at a time if possible
- Reconnect cables and connectors
- Power on and verify basic operation
- Run diagnostic software if available
- Test all functions that relate to the repaired area:
- If repair was near audio circuits, test audio
- If repair was near video circuits, test video
- If repair was near I/O, test those ports
- Run extended tests โ Some problems only appear after warmup
- Monitor for intermittent issues โ These may indicate incomplete repairs
Prevention
Battery Management
- Remove batteries from equipment in long-term storage โ This single step prevents most battery damage
- Check batteries annually in equipment that's stored
- Use high-quality batteries from reputable brands (Duracell, Energizer)
- Avoid mixing old and new batteries โ Depleted cells can reverse-charge and leak
- Inspect batteries periodically for swelling or early signs of leakage
- Consider external battery holders for frequently stored equipment โ keeps the battery physically separate from the PCB
- For PRAM/CMOS batteries: replace proactively every 5-7 years in equipment you intend to keep
- Use lithium replacements where appropriate โ they have lower leakage rates
- Consider supercapacitor replacements for some CMOS battery applications
Capacitor Maintenance
- Proactive recapping โ Replace all electrolytics in equipment over 15-20 years old, even if not yet failing
- Target known problematic equipment โ Some models have higher failure rates; research your specific device
- Power on periodically โ Helps reform the capacitor's oxide layer (at least monthly for stored equipment)
- Avoid extreme temperatures โ Heat accelerates capacitor degradation; ensure adequate ventilation
- Monitor for symptoms โ Audio hum, video distortion, instability, and random resets indicate failing capacitors
- Check capacitors visually during other service โ Look for bulging tops, leaking fluid, or corrosion
- Keep spare capacitors โ Order extras when doing a recap job
Storage Best Practices
- Store in cool, dry environments โ Ideally 15-25ยฐC with 40-60% relative humidity
- Avoid temperature extremes โ Both heat and cold stress components
- Avoid rapid temperature changes โ Causes condensation inside equipment
- Keep away from direct sunlight โ UV and heat degrade plastics and components
- Use desiccant in sealed storage containers
- Store boards in anti-static bags inside boxes for physical protection
- Store vertically if possible โ Reduces stress on through-hole component leads
- Label stored equipment with date and known status
Troubleshooting Common Issues
| Symptom After Repair | Possible Causes | Diagnostic Steps | Solutions |
| No power / Dead | Missed short, broken trace, bad connection, blown fuse | Check for shorts between power rails; verify all connections; check fuses | Fix shorts, repair traces, reflow connections |
| Powers on but nothing else | Missing voltage rails, processor not running, reset stuck | Check all voltages; verify clock signal; check reset line | Repair power supply, check crystal/oscillator, verify reset circuit |
| Intermittent operation | Cold solder joint, damaged socket, marginal trace, dirty contacts | Flex the board gently while operating; test at different temperatures; retest sockets | Reflow suspicious joints; replace sockets; reinforce traces; clean contacts |
| Corrosion returns after days/weeks | Contamination not fully neutralized | Inspect under magnification for residue | Clean again with appropriate neutralizer; ensure complete IPA rinse; consider ultrasonic cleaning |
| Different problem than before | Repair caused new damage, disturbed marginal component, ESD damage | Systematic testing to isolate new issue | Careful examination of work area; test all nearby components |
| Overheating components | Short circuit, wrong value component, failed component | Check for shorts; verify component values; measure current draw | Find and fix short; replace wrong component; test and replace failed parts |
| Audio problems (hum, distortion) | Remaining bad caps, poor ground connection, damaged audio IC | Check audio-related capacitors; verify ground connections; test audio path | Replace audio caps; repair ground traces; replace audio ICs |
| Video problems (lines, distortion) | Bad caps in video circuit, damaged RAM, timing issues | Check video capacitors; test video RAM; verify clock signals | Replace video caps; replace RAM if socketed; check crystals/timing |
External Resources
- Electrolytic Capacitor Failure Modes โ Electronics Notes
- iFixit Electronics Cleaning Guide
- Console5 Capacitor Replacement Guides โ Model-specific recap guides for game consoles and computers
Image Credits
Images on this page are sourced from Wikimedia Commons under Creative Commons licenses:
- PCB battery corrosion โ Binarysequence (CC BY-SA 4.0)
- Leaked alkaline battery โ Roopeank (CC BY-SA 4.0)
- Blown electrolytic capacitor โ Mataresephotos (CC BY 3.0)
- SMD capacitor failure โ Wikimedia Commons (CC BY-SA 2.0)
- Motherboard defective capacitors โ Gms (CC BY-SA 3.0)
