Apple 21" Color Display Troubleshooting Guide
Fault-finding for the Macintosh 21" Color Display. Apple's procedure for a dark screen reads six status LEDs; for everything else it uses symptom charts, with cures listed in order of likelihood. Refit the original module before trying the next cure if a replacement did not help.[1] Rule out the location first: large displays bend near metal and jitter near fluorescent lights and appliances, and module swaps cannot cure that.[2]
The CRT keeps a charge after switch-off. Follow the CRT Discharge Procedure before working inside, and do not wear a grounding wrist strap until it has been discharged. The LED checks below are made with power on and the shields removed: keep clear of the anode, flyback and high-voltage block.[1]
Dark screen: the LED flowchart
editUse this only for a no-raster fault. Switch off, remove the rear cover and the power supply and main board shields, switch on and look at the LEDs. All six are normally lit (steady, not flashing).[1][2]
| LED | Board | Monitors |
| V125 | Main board | Horizontal and vertical sweep |
| V810 | Main board | High voltage |
| V683, V699 | Power supply board | The power supply board |
| V684, V685 | Power supply board | Several conditions; must be on steadily |
- If all four power supply LEDs are on and steady, check V125. If V125 is off, replace the main board. If it is on, check V810: off means the flyback transformer assembly; on means the video assembly.
- If V683 or V699 is off, replace the power supply board.
- If V684 or V685 is flashing, switch off and unplug the ribbon cable from X105 on the main board, then switch on. If the LED still flashes, replace the power supply board. If it stops, reconnect X105 and unplug X303 on the video board; if the flashing stops, replace the video assembly. If not, reconnect X303 and unplug X855 on the magnetometer degauss board; if the flashing stops, replace that board; if not, replace the flyback transformer assembly.
- If all the LEDs are off or flashing, switch off and check the fuse on the on/off switch assembly. If it is intact, replace the power cord. If it has blown, replace it and switch on: if it blows again, replace the power supply board; if not, leave the display running for two hours and check again.[1]
Apple's documents give the fuse no rating and no separate part number; it sits on the on/off switch filter assembly, part 076-0398.[3]
Symptom charts
edit| Symptom | Cures, in Apple's order |
| No raster, LED off | Check the power cord connection. Replace the power cord. Check all internal power connectors. Work through the LED flowchart |
| No raster, LED on | Adjust contrast and brightness. Check the video card. Check the connectors on the main board and power supply board. Work through the LED flowchart |
| Raster too short, tall, narrow or wide | Adjust V-SIZE or H-SIZE. Replace the main board |
| Raster not centred | Move the display. Adjust H-DC SHIFT or V-SHIFT. Replace the main board. Replace the magnetometer degauss board |
| Horizontal linearity bad | Adjust H-LIN. Replace the main board |
| Vertical linearity bad | Adjust V-LIN. Replace the main board |
| Raster tilted | Move the display. Do the geometry adjustments. Replace the magnetometer degauss board. Replace the position sensor board |
| Other distortion (corners not square, sides tilted or barrelled, top stretched or compressed) | Move the display. Check all cables. Work through the LED flowchart. Do the geometry adjustments. Replace the main board. Replace the magnetometer degauss board |
| Picture breaks into diagonal lines | Check the video signal with a known-good monitor. Replace the main board |
| Picture rolls vertically | Check the video card. Replace the main board. Replace the video assembly |
| Picture breaks and rolls horizontally | Check the video card. Adjust H-HOLD. Replace the main board. Replace the video assembly |
| Single vertical or horizontal line | Check the CRT video board is tight on the yoke connector. Replace the main board |
| Predominant red, blue or green tint | Check the video card. Do the video adjustments. Replace the video assembly. Replace the video filter boards. CRT: international units replace it; domestic units call Apple to confirm a CRT failure |
| Picture too dark or too bright | Adjust contrast and brightness. Check the video card. Do the video adjustments. Replace the power supply board, then the video assembly, then the video filter boards. CRT as above |
| Out of focus | Adjust the focus controls. Replace the flyback transformer assembly. Replace the main board. CRT as above |
| Out of convergence | Check the video card. Use the convergence alignment chart and adjust the matching control. Do the convergence adjustments. CRT as above |
| Shuts down intermittently | Replace the flyback transformer assembly. Replace the main board |
| Picture jitters or flashes | Check the ground cables. Check nearby equipment is grounded. Move electrical devices away and switch off fluorescent lights. Replace the main board |
| Jitter or a wavy image at 1152 × 870 on a Power Macintosh 9600 | Not the display: Apple/IMS video cards with serial numbers below Fx705xxx cause it on any monitor; Apple replaced them with part 661-1409 |
| Black spots (burnt phosphor) | CRT as above |
| High-pitched noise | Replace the flyback transformer assembly |
| Does not degauss | Replace the magnetometer degauss board. Replace the position sensor board |
| ADB devices do not work or work erratically | Replace the keyboard, mouse or other ADB device. Replace the ADB cable in the stand |
The adjustments named are on the general maintenance page, including the convergence alignment chart that matches each colour fringe to its control.
Rev. A and Rev. B
editRev. A CRTs need Rev. A main boards and Rev. B CRTs need Rev. B main boards. A Rev. B CRT has a small blue "NEW" label near the anode. A Rev. B main board has capacitor C153, fitted on either the component or the solder side; a Rev. A board has none, and Apple converts a Rev. B board for a Rev. A tube by removing C153.[4]
editReferences
edit- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Apple Computer, Macintosh 21-inch Color Display (Service Source), hosted as File:21 color display.pdf. Troubleshooting: general p. 1, symptom charts pp. 2-18, troubleshooting LEDs flowcharts pp. 19-21 (PDF pp. 20-40).
- ↑ 2.0 2.1 2.2 Macintosh 21-inch Color Display Service Source, Basics, Monitor Distortion pp. 1-6 and Troubleshooting LEDs pp. 7-9 (PDF pp. 3-11).
- ↑ Macintosh 21-inch Color Display Service Source, Exploded View (PDF p. 191).
- ↑ Macintosh 21-inch Color Display Service Source, Additional Procedures, Rev A/B Compatibility, pp. 1-4 (PDF pp. 112-115).
