Apple Service Guide Laserwriter Printers Volume Iv Nov 1995
The Apple Service Guide for LaserWriter Printers, Volume IV, November 1995 is devoted to a single machine: the Color LaserWriter 12/600 PS.
It is the most component-aware of the four volumes. It carries a block diagram, named DC and Mechanical Controller Boards, two wiring diagrams, and a symptom-driven print-quality section written in the language of what the user actually sees.
Contents, with the guide's own page numbers
[edit | edit source]- Chapter 1 Introduction - Introduction (p. 2), Safety (p. 3), LaserWriter Safety Rules (p. 4), Toner Safety (p. 4), Laser Safety (p. 4), ESD Damage Prevention Rules (p. 5), Setting Up an ESD-Safe Workstation (p. 6)
- Chapter 2 Printer Connections - LocalTalk connection (p. 9), parallel port (p. 10), Ethernet transceivers and connections (pp. 11-12), cable connectors (p. 13)
- Chapter 3 Parts - Front and Back Views (p. 20), Internal Views (p. 21), Exploded View of the printer (p. 23) and the Sheet Feeder (p. 25), Parts List (p. 26), Finished Goods Parts (p. 29), Replacing Consumables (p. 30), DC and Mechanical Controller Boards (p. 45)
- Chapter 4 Specifications - including a Block Diagram (p. 51)
- Chapter 5 Upgrades - Hard Disk Drive Upgrade (p. 54), connecting a previously used or external hard drive (p. 54), adding an internal drive (p. 54), RAM Upgrade (p. 56), Sheet Feeder Upgrade (p. 58)
- Chapter 6 Printer Diagnostics - Status Panel (p. 62), Density Control Panel (p. 73), Density Adjustments (p. 74), Test Page Pattern Selection (p. 75), Separation Voltage Designation (p. 76), Diagnostic Utility (p. 77)
- Chapter 7 Troubleshooting - Checklist (p. 80), Tools (p. 81), Verifying Printer Operation (p. 82), Observing the Printer in Validation State (p. 84), Troubleshooting Flowcharts (p. 85), Symptom-Driven Troubleshooting (p. 91) covering front door opens too easily, paper jams or blank pages, loud grinding from the toner carousel, paper not taken off the transfer drum, printing software not installed, and a fuser oil pump error caused by moving the printer (p. 92); Print Quality Issues (p. 93) - one colour too light, excessive background toner, banding, oil spots on the paper, small amounts of toner on the page; Troubleshooting Tables (p. 98); Paper Transport Troubleshooting (p. 118); Sheet Feeder Wiring Diagram (p. 130); Color LaserWriter 12/600 PS Wiring Diagram (p. 131); Power and Drive Train Views and Disassembly (p. 133)
Two items are distinctive and are worth knowing before touching one of these printers: the fuser oil pump error that moving the printer can cause, and the Separation Voltage Designation setting, which is a service adjustment rather than a user one.
What this guide does not contain
[edit | edit source]No schematic. The block diagram and wiring diagrams show function and interconnection; the controller-board pages are locators. No component values, and the parts list is Apple's selection of service modules and consumables.
This copy is 136 pages. A second, fuller scan of the same guide is on this wiki as Laserwriter Printers Service Guide Volume Iv Color Laserwriter 12-600ps November 1995 (146 pages); prefer that one.
Pages that cite this document
[edit | edit source]- Laserwriter Printers Service Guide Volume Iv Color Laserwriter 12-600ps November 1995
- The Laser Writer Family 1992
Download: Apple Service Guide LaserWriter Printers Volume IV Nov 1995.pdf
