File:Apple High-Res Monochrome Monitor Technical Procedures.pdf
[edit | edit source]Apple's High-Res Monochrome Monitor Technical Procedures, the section of Apple Service Technical Procedures, Volume Six covering the 12-inch Apple High-Res Monochrome Monitor for the Macintosh II. 57 pages, revised May and June 1987. Contents: Section 1, Basics (product description, safe electrical setup, CRT safety rules, live adjustment rules, CRT disposal); Section 2, Take-Apart (rear cover, discharging the CRT, main logic board, power supply, fuse, contrast control board, video board "C", chassis, CRT, LED cable, power switch, AC inlet); Section 3, Adjustments (subbrightness/cutoff, horizontal size, vertical size, focus); Section 4, Troubleshooting (symptom chart); Illustrated Parts List (internal assembly, CRT case assembly). Described on Apple High-Res Monochrome Monitor Technical Procedures.
Module-level service only: no schematic and no component values. Extracted from PDF pages 400 to 456 of the archive.org scan and converted to 150 dpi greyscale.
[edit | edit source]https://archive.org/details/apple-service-technical-procedures-volume-six (retrieved 2026-09-30)
[edit | edit source]Copyright Apple Computer, Inc., 1987. Hosted for preservation and repair reference.
| Date/Time | Dimensions | User | Comment | |
| current | 13:04, 30 September 2026 | 0 × 0 (5.48 MB) | Josh (talk | contribs) | High-Res Monochrome Monitor section of Apple Service Technical Procedures Vol. 6, from archive.org |
