Acorn A3010, A3020 and A4000 Technical Reference Manual
The Acorn A3010/A3020/A4000 Technical Reference Manual is Acorn Computers' hardware reference for the Acorn Archimedes A3010, Acorn Archimedes A3020 and Acorn Archimedes A4000, Issue 1, January 1993, copyright Acorn Computers Limited 1991, 1992, published by Acorn Computers Technical Publications Department. 66 pages. The scan has no text layer, so it cannot be searched and values must be read from the page images.
Contents
[edit | edit source]- About this manual; Safety
- Part 1 — System description: ARM250, system timing, memory system, I/O system, floppy disc drive, IDE hard disc interface (not A3010), video circuit, audio circuit, keyboard and mouse, power supply, ARM250 pin out, links, plugs, sockets
- Part 2 — Parts lists, one per assembly: A4000 main PCB; A3010 1M and 2M final assembly; A3010 1M and 2M main PCB; A3010 1M and 2M (ARM250) main PCB; A3020 2M and A3020 2M HD final assembly; A3020 2M main PCB; A3020/A4000 Econet PCB; A3020/A3010 CPU module PCB
- Appendix A — monitor adaptor cables; Appendix B — timing diagrams; Appendix C — RAM chip signals
- Appendix D — engineering drawings: final assembly drawing, main PCB assembly drawing, main PCB circuit diagram, 4 MB RAM upgrade circuit diagram, backplane circuit diagram, keyboard adaptor PCB circuit diagram
Part 2 is the part worth having: a separate bill of materials for each board and each memory variant, so a reader can tell which parts list applies to the board in front of them rather than assuming the three machines share one.
What it settles
[edit | edit source]Acorn's own comparison table, on the first page of Part 1, gives the supply rating for each machine and rules out any shared figure:
| Feature | A3010 | A3020 | A4000 |
| Design | Single box | Single box | Twin box |
| Computer system IC | 12 MHz ARM250 | 12 MHz ARM250 | 12 MHz ARM250 |
| Base memory | 1 MB DRAM | 2 MB DRAM | 2 MB DRAM |
| Expandable to | 2 or 4 MB | 4 MB | 4 MB |
| Hard disc | N/A | Optional internal 2.5 inch IDE | Optional internal 3.5 inch IDE |
| Keyboard | 103 switch, integral | 103 switch, integral | 103 switch, separate |
| PSU | 10 W | 12.5 W | 24 W |
| Colour TV modulator | Yes | No | No |
| Internal network expansion slot | No | Yes | Yes |
| Switched joystick inputs | 2 | No | No |
| Rechargeable battery to power RTC | Yes | Yes | Yes |
All three carry a rechargeable cell for the real-time clock, which is why a leaked cell is a routine fault on these machines and why a primary lithium cell is the wrong substitute.
[edit | edit source]- No fault-finding procedures and no repair chapter. This is a reference, not a service manual; for diagnosis see Acorn A3010, A3020 and A4000 Service Manual.
- No power supply parts list. The supply is rated in watts in the comparison table and described in Part 1, but no component-level breakdown is given.
- No monitor coverage.
- No text layer, so the parts lists cannot be searched or copied — only read.
Pages that cite this document
[edit | edit source]- Acorn Archimedes A3010 · Acorn Archimedes A3020 · Acorn Archimedes A4000
- Acorn Archimedes A3010 Capacitor Guide · Acorn Archimedes A3020 Capacitor Guide · Acorn Archimedes A4000 Capacitor Guide
Download here: Acorn A3010 A3020 A4000 Technical Reference Manual.pdf
