Acorn System 1 Technical Manual
The Acorn Technical Manual for the System 1 Micro-Computer is Acorn Computers Ltd's own construction and reference manual for the Acorn System 1, copyright 1979. 31 pages, with a text layer and searchable. The title page gives the machine as two Eurocards: 6502 C.P.U., 200,000 and Keyboard, 200,001.
Contents
[edit | edit source]Acorn's own contents list, with printed page numbers:
- Introduction โ 1
- Construction procedure โ 2
- Power supply โ 13
- Cassette interface โ 14
- Address selection โ 15
- Fitting EPROMs โ 19
- Extending the system โ 21
- P.C.B. layouts โ 24
- Parts list 6502 C.P.U. โ 25
- Parts list keyboard โ 27
- Parts list 6502 S.B.C. โ 29
- Circuit diagram 6502 C.P.U. โ loose
- Circuit diagram keyboard โ loose
What it settles
[edit | edit source]- Three separate parts lists, not one: the 6502 CPU Eurocard, the keyboard/display/cassette Eurocard, and the 6502 single-board controller configuration. The System 1 was sold in several forms and the SBC build populates a different set of positions from the full two-card machine, so the list that applies depends on which configuration the board in front of you is.
- Acorn's introduction spells out those three configurations: single-board controller with firmware in a pair of 74S571 PROMs or an EPROM; the machine-code microcomputer with the hex keypad, eight-digit seven-segment display and cassette interface on the second board; and as the CPU of a larger Eurocard system, with all 6502 address, data and control lines brought out on a 32-way DIN connector.
[edit | edit source]- The circuit diagrams are not in it. Acorn's own contents page marks both as "Loose" โ they were supplied as separate sheets, and they are hosted here as Acorn System 1 Circuit Diagrams.
- No fault-finding procedures and no diagnostic flowcharts.
- No power supply component values. Page 13 specifies what the boards need, not what is inside a supply.
- No coverage of the later Acorn System machines; for those see Acorn System 5 Handbook and Acorn System Catalogue.
Pages that cite this document
[edit | edit source]- Acorn System 1 ยท Acorn System 1 Maintenance Guide ยท Acorn System 1 Troubleshooting Guide ยท Acorn System 1 Capacitor Replacement Guide
Download here: Acorn System 1 Technical Manual.pdf
