Acorn System 3
Acorn System 3
Acorn System 3
TypeModular microcomputer (Eurocard)
Released1980
Intro price£775 (£1075 with PSU and casing); keyboard £136 (1982)
CPU6502 @ 1 MHz (6809 option)
Memory8 KB RAM + 4 KB BASIC ROM (minimum)
Storage5.25" floppy disc (100 KB), DOS in ROM
Display40×25 teletext VDU (40 or 80 column)
Sound
OS / FirmwareAcorn DOS; Acorn System BASIC (FLEX on 6809)
PredecessorAcorn System 2
SuccessorAcorn System 4
The Acorn System 3 (1980) added a floppy-disc controller card, a 5.25-inch drive and a disc operating system to the Eurocard rack, replacing the cassette interface of the Acorn System 2.[1] The System 3 became the standard development machine in the Acorn lab: the Acorn Atom has been described as a cut-down System 3, and much of the BBC Micro development was done on it.
Configuration
A minimum System 3 contained:[1][2]
  • A 1 MHz 6502 CPU card (a 6809 card was available for running FLEX)
  • A 40×25 teletext VDU card (an 80×25 card was also used)
  • 8 KB RAM with a 4 KB Acorn System BASIC ROM
  • A floppy-disc controller card (Intel 8271)
  • One 100 KB 5.25-inch disc drive mounted in the card frame
Further Eurocards could be added as required. In 1982 the System 3 cost £775, or £1075 with power supply, casing and two further 8 KB RAM cards, plus £136 for the keyboard.[1]
Maintenance and repair
  1. 1.0 1.1 1.2 "Acorn System", Wikipedia. Source for the System 3 minimum configuration, the disc-based design, the 1982 prices, and the System 3's role as the Acorn lab workhorse from which the Atom was derived and the BBC Micro developed.
  2. Whytehead, Chris. "Acorn System 3", Chris's Acorns / The Centre for Computing History. Source for the minimum configuration (1 MHz 6502 CPU, VDU, 8K RAM + 4K BASIC ROM, floppy-disc controller, 100K 5.25-inch drive), the 6809/FLEX option, and the Intel 8271 floppy controller.
