BBC Micro Model B+
| BBC Micro (case and keyboard are externally indistinguishable between the Model B and the B+) | |
| Type | 8-bit home / education microcomputer |
| Released | Mid 1985 |
| Discontinued | Early 1986 |
| Intro price | B+64: ยฃ499; B+128: ยฃ599 (1985, inc. VAT) |
| CPU | Rockwell 6512A @ 2 MHz (NMOS, externally clocked) |
| Memory | B+64: 64 KB; B+128: 128 KB (32 KB main + 20 KB shadow + 12 KB / 76 KB sideways) |
| Storage | Cassette tape; 5.25"/3.5" floppy via on-board WD1770 |
| Display | 8 modes incl. 80ร25 teletext (SAA5050), HD6845 CRTC |
| Sound | Texas Instruments SN76489 (3 tone + 1 noise channel) |
| Dimensions | 40 cm ร 34 cm ร 8 cm |
| Weight | 4.5 kg |
| OS / Firmware | Acorn MOS 2.00, BASIC II, DFS 2.10 |
| Predecessor | BBC Micro Model A/B |
| Successor | BBC Master 128 |
| Codename | Acorn ICA-19 |
| Model no. | B+ (B+64), B+128 |
The BBC Micro Model B+ is an enhanced revision of the BBC Micro Model B released by Acorn Computers in mid-1985 as a stop-gap between the original Proton Model B board and the BBC Master launched later that year.[1] The B+ retained software compatibility with the Model B while addressing the Model B's two biggest limitations โ only 32 K of contiguous RAM and an Intel 8271 floppy controller โ by adding paged shadow screen RAM, sideways workspace RAM and the Western Digital WD1770 disc controller as standard.
Variants
[edit | edit source]Two production variants were sold:
- BBC Model B+ (B+64) โ 64 KB total: 32 KB main RAM + 20 KB shadow screen RAM + 12 KB "S-RAM" sideways workspace.
- BBC Model B+128 (B+128) โ 128 KB total: as B+64 plus an additional 64 KB occupying two sideways RAM banks 4 and 6 (32 K each).[2]
The B+128 was aimed at the schools market for users of large applications such as View and ViewSheet that benefited from extra paged RAM.
Hardware Architecture
[edit | edit source]Processor
[edit | edit source]The B+ uses the Rockwell 6512A, an NMOS variant of the 6502A that runs at 2 MHz and accepts an external clock. This is a notable change from the Model B, which used a 6502A with internal clock. The 6512 was selected so that the 1 MHz bus and the 2 MHz CPU clock could be derived cleanly from the ULA. Despite the part-number change, opcode behaviour is identical to a 6502A.[3]
Memory Map
[edit | edit source]The B+ adds two new RAM blocks beyond the Model B's 32 K main DRAM:
- 20 KB shadow screen RAM โ paged in on demand for the screen, leaving the entire 32 K main RAM available for the user program even in MODE 0 (which on the Model B consumed the top 20 K of RAM for the screen).
- 12 KB sideways "S-RAM" โ accessed in the same paged 16 K window as sideways ROMs, used as workspace by filing systems and printer buffers.
- Optional 64 KB additional sideways RAM on the B+128, mapped as two 32 K banks at sideways ROM slots 4 and 6.
Crucially, the BBC OS keeps the user's program model identical to the Model B, with sideways paging handled by *PAGE-aware MOS calls โ most Model B software runs unchanged on a B+.
Sideways ROM Sockets
[edit | edit source]The B+ has five sideways ROM sockets, repositioned to the top-left corner of the board next to the keyboard cable. (The Model B has four sockets along the front edge.) On the B+128, two of those sockets are populated with the additional sideways RAM banks, leaving three sockets for ROMs.
Floppy Controller
[edit | edit source]The B+ ships with the Western Digital WD1770 as standard, replacing the troublesome Intel 8271 found on early Model Bs. The WD1770 supports both single- and double-density operation, has fewer software workarounds, and reads/writes DFS-format disks with the standard DFS 2.10 filing system supplied in ROM.[4]
Other Hardware
[edit | edit source]- CRTC โ Hitachi HD6845 (same as Model B).
- Teletext / MODE 7 โ Mullard SAA5050 character generator.
- Sound โ Texas Instruments SN76489 three-voice tone + noise generator.
- VIAs โ two 6522s (System VIA and User VIA) at the same addresses as the Model B.
- ADC โ ฮผPD7002 4-channel analogue-to-digital converter (used for joysticks).
- Serial ACIA โ 68B54.
- Power supply โ internal Astec linear PSU producing +5 V, +12 V and โ5 V.
Block Diagram
Firmware
[edit | edit source]- Acorn MOS 2.00 (replaces MOS 1.20 of the Model B).
- BASIC II (Roger Wilson's revised interpreter; same as later Model B production).
- DFS 2.10 for the WD1770 floppy controller.
- No real-time clock โ the B+ has no battery-backed RTC, unlike the Master.
PCB Schematics and Service Manual
[edit | edit source]The B+ inherits the bulk of its main-board schematic from the Model B (Acorn Service Manual Section 1) with B+-specific changes โ shadow RAM paging logic, the WD1770 sub-circuit, and the relocated sideways ROM sockets โ documented in Section 2.
| Block Diagram | Main Schematic |
| PSU Schematic | Keyboard Schematic |
| PCB Layout | PCB Silkscreen |
| PCB Traces | Assembly (Exploded) |
All schematics reproduced from the Acorn BBC Microcomputer Service Manual, October 1985 (Sections 1 & 2), mirrored at the Chris's Acorns archive.[5]
Reception and Legacy
[edit | edit source]The B+ shipped at ยฃ499 for the 64 K version and ยฃ599 for the B+128.[6] It sold modestly in the UK schools market for the second half of 1985 before being superseded by the substantially more capable BBC Master 128 in February 1986. The B+ remained the only BBC Micro that shipped with shadow RAM, the WD1770 and Acorn MOS 2.00 as the standard configuration; the Master's MOS 3.20 carried these features forward.
Related Pages
[edit | edit source]- BBC Micro Model A/B โ predecessor
- BBC Master 128 โ successor
- BBC Micro B+ General Maintenance
- BBC Micro B+ Troubleshooting Guide
- BBC Micro B+ Capacitor Replacement Guide
[edit | edit source]- โ "BBC Microcomputer Model B+", Chris's Acorns
- โ "BBC Microcomputer Model B+128", Chris's Acorns
- โ "6512 vs 6502 in the BBC B+", Stardot Forums
- โ "B+ WD1770 vs Model B 8271", Stardot Forums
- โ Acorn BBC Microcomputer Service Manual, Chris's Acorns
- โ "Acorn BBC Micro Model B+", The Centre for Computing History
