BBC Micro B+ Capacitor Replacement Guide
This guide documents capacitor diagnosis and replacement for the BBC Micro Model B+ and B+128. The B+ has two distinct capacitor populations: the Astec linear power-supply module (mains-side), and the main board (low-voltage decoupling). Mains-side work is significantly more dangerous and is described first.
Safety Warning
[edit | edit source]The B+ PSU has lethal mains-side capacitance that retains charge after disconnection. Before any service work:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge the primary bulk electrolytic (C9) through a 1 kΩ / 5 W resistor.
- Verify all PSU outputs read 0 V with a multimeter.
The RIFA-branded X2 mains-suppression caps (C1, C2) are the single most common preventive-replacement target on B+ machines. They fail open and vent acrid white smoke under continued use — at which point they cannot be recovered, only replaced.[1][2]
Astec Power Supply Capacitors
[edit | edit source]The B+ uses an Astec linear PSU module identical to that fitted to late-issue Model Bs. Refer to the PSU schematic for component placement and reference designators.
| Ref | Value | Voltage | Type | Function | Notes |
| C1 | 0.1 µF (100 nF) | 250 V AC (X2 class) | Mains-suppression film | Live–neutral RFI suppression | Replace if RIFA-branded (preventive). Use modern X2 0.1 µF 275 V AC. |
| C2 | 0.01 µF (10 nF) | 250 V AC (X2 class) | Mains-suppression film | Live–earth / neutral–earth RFI suppression | Replace if RIFA-branded (preventive). Use modern Y2 4.7 nF or X2 10 nF 275 V AC depending on board issue. |
| C9 | 220 µF | 200 V (or 250 V) | Aluminium electrolytic, 105 °C | Primary bulk smoothing after bridge | Replace if any sign of bulging, leakage, age. This part causes intermittent cold-start failures on ageing PSUs. |
| C10 | 4700 µF | 16 V | Low-ESR aluminium electrolytic, 105 °C | +5 V secondary bulk | Replace as preventive measure; failure causes voltage sag under disc load. |
| C11 | 470 µF | 25 V | Aluminium electrolytic, 105 °C | +12 V secondary bulk | Replace as preventive measure. |
| C12 | 220 µF | 16 V | Aluminium electrolytic, 105 °C | −5 V secondary smoothing | Replace as preventive measure. |
| C13–C16 | 0.1 µF | 50 V | Ceramic / polyester | Regulator bypass × multiple | Ceramic; rarely fail. Inspect only. |
Values above are taken from the Acorn BBC Microcomputer Service Manual, October 1985, Section 2 PSU schematic and have been cross-checked against Stardot recapping threads.[3]
PSU Recap Procedure
[edit | edit source]- Discharge the PSU as above.
- Remove the four screws holding the Astec module in its shielding can.
- Unplug the four-pin output Molex from the main board.
- Lift the PSU PCB out of the can.
- Photograph the board from both sides at high resolution before desoldering anything.
- Mark each electrolytic's polarity (positive lead) before desoldering — even if the silkscreen is clear, faded markings are common.
- Desolder C9, C10, C11, C12 with solder wick at no more than 350 °C, 5–7 seconds per cycle.
- Replace C1, C2 with modern X2 / Y2 parts (Kemet R46/R41 series, EPCOS B32921/B32932 series, or Vishay BFC233 series — never another RIFA-branded part).
- Fit electrolytic replacements matching the silkscreen polarity.
- Solder both leads; inspect for clean fillets; trim flush.
- Verify continuity across the new caps and to ground before re-fitting.
Main Board Capacitors
[edit | edit source]The B+ main board has ≈40 electrolytics of mixed values plus a substantial population of ceramic and polyester decoupling caps. The electrolytics are the primary recap targets; ceramics rarely fail and are not normally replaced.
| Value | Voltage | Type | Position / Function |
| 10 µF | 16 V | Radial aluminium electrolytic, 105 °C | +5 V local bypass × multiple |
| 22 µF | 16 V | Axial aluminium electrolytic, 105 °C | DRAM array bypass × multiple |
| 47 µF | 16 V | Radial aluminium electrolytic, 105 °C | Video DAC supply filtering |
| 100 µF | 16 V | Axial aluminium electrolytic, 105 °C | ROM bank bypass × multiple |
| 220 µF | 16 V | Radial aluminium electrolytic, 105 °C | ULA supply local filtering × 2–3 |
| 470 µF | 16 V | Radial aluminium electrolytic, 105 °C | Main rail decoupling near PSU connector |
| 1 µF | 50 V | Axial aluminium electrolytic, 105 °C | Analogue / ADC bypass × 2 |
| 4.7 µF | 25 V | Tantalum bead | Analogue input network (joystick port) |
| 0.47 µF | 50 V | Polyester film | Sync separator network on composite output |
| 100 µF | 25 V | Radial aluminium electrolytic, 105 °C | Cassette amplifier supply bypass |
The most failure-prone parts on the B+ main board are the axial 22 µF and 100 µF bypass caps near the DRAM array, because their leads were dipped in flux that wicks under the seal over time, eventually allowing electrolyte to evaporate. Symptoms are flaky DRAM behaviour when the machine is fully warmed up.
Main Board Recap Procedure
[edit | edit source]- Power off, unplug, discharge PSU.
- Remove the four case screws and lift the top assembly off.
- Disconnect the keyboard ribbon, speaker connector, and any floppy / printer leads.
- Photograph both sides of the main board at high resolution.
- Tag each electrolytic's polarity and the associated reference designator with masking tape if necessary.
- Desolder each cap one at a time with solder wick at no more than 350 °C, 5 seconds per cycle to avoid lifting the through-hole plating.
- Fit modern radial replacements matched for value, voltage, ESR, polarity and lead spacing. Mind the case-height clearance under the keyboard.
- Verify no shorts across the main rails (DMM diode-test mode is sufficient for triage).
Recommended Modern Replacements
[edit | edit source]- X2 / Y2 mains-suppression: Kemet R46/R41 series, EPCOS B32921/B32932, Vishay BFC233. Never RIFA.
- Bulk electrolytic: Panasonic FR / FM / FC series; Nichicon HE / HZ series (2007+ date codes); Rubycon ZLH / ZLJ / YXJ series.
- Small-signal electrolytic: Panasonic FC, Nichicon UPM, United Chemi-Con KZH.
- All replacements should be 105 °C rated and matched to or higher than the original voltage rating.
- Verify lead spacing — many original axials need to be replaced with radial parts on dropper leads, which works but should be done neatly with heat-shrink-insulated lead extensions.
Post-Recap Verification
[edit | edit source]- Power on with a bench load on +5 V (2.5 Ω / 25 W is a good test load).
- Verify all rails before connecting the main board.
- Reconnect main board; verify the banner displays on first power-on.
- Run *FX 0 self-test and *HELP to verify all ROMs and BASIC are present.
- Insert a known-good DFS disc; verify CAT lists it correctly.
- Test under sustained warm operation (1 h+) for the disc-load voltage-sag symptom.
When Not to Recap
[edit | edit source]If the B+ powers on cleanly, beeps, displays a perfect banner, runs BASIC II, reads and writes discs cleanly, and the PSU's RIFA caps have already been replaced or are confirmed not RIFA-branded, then the caps are within tolerance.
Always recap if:
- RIFA-branded C1 or C2 present — preventive replacement, no exceptions.
- Visible cap failure on the PSU or main board (bulging, leakage, crusty residue).
- PSU smoke, fishy odour, or audible whine.
- Random reboots when warm but stable when cold (suggests C9 PSU primary bulk ageing).
- DRAM errors only when warm (suggests local DRAM bypass cap ageing).
- B+128 reports reduced memory when warm (suggests sideways RAM bypass cap ageing).
Related Pages
[edit | edit source]- BBC Micro Model B+
- BBC Micro B+ General Maintenance
- BBC Micro B+ Troubleshooting Guide
- BBC Micro Model A/B Capacitor Replacement Guide
- Capacitor Failure Symptoms
