AppleVision 850 and 850AV Displays User's Manual
The AppleVision 850 and 850AV Displays User's Manual is Apple's owner's manual for the AppleVision 850 and 850AV 20-inch displays. The hosted file is the 112-page PDF edition Apple produced in 2001; its document title, "0309653AAV850850AVUM", suggests Apple document number 030-9653-A. It has no cover or title page: it opens at chapter 1 and the contents list is at the back (PDF pp. 108-111).[1]
Contents
  • 1 Setting up your monitor: safety and cleaning, the 850AV and 850 at a glance, video cards, location, connecting power, Mac OS and Windows computers, keyboard and mouse, sound equipment (850AV), more than one monitor
  • 2 Installing and using AppleVision software: Monitors & Sound, the Control Strip, DigitalColor Meter, Energy Saver
  • 3 Using sound and video with the 850AV: sound sources, recording video with sound, playing audio CDs through the monitor
  • 4 Using the monitor with Windows-based computers: on-screen controls
  • 5 Tips and troubleshooting (PDF pp. 65-80): care and cleaning, security slot, troubleshooting by symptom
  • Appendix A, Using ColorSync (PDF p. 81 on)
  • Appendix B, Technical information (PDF p. 89 on): tube, input signals, power-saving modes, controls, factory preset timings[1]
What it settles
Power modes (Appendix B, p. 90)[1]
Mode Power Power light
Normal Under 150 W (850); under 180 W (850AV) Green
Monitor sleep Under 30 W Orange
System sleep Under 5 W (850 and 850AV with speakers off); under 30 W (850AV with speakers on) Orange
  • Clean the screen with a mild, non-abrasive cleaner on a soft cloth; cleaners containing alcohol or acetone can damage it (p. 66).
  • Restarting with Command-Option-A-V held down resets the display to its factory settings (p. 68).
  • One or two thin grey lines near the top and bottom of the screen are a normal feature of the Trinitron tube (p. 70).[1]
What it does not contain
No service information: it warns against removing the cover and refers repairs to Apple. The Service Source gives 190 W maximum for the 850AV against the manual's "under 180 W" in normal use.[1][2]
Pages that cite this document
Download: AppleVision 850 and 850AV Displays Users Manual.pdf
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Apple Computer, AppleVision 850 and 850AV Displays User's Manual, 112 pp., hosted as File:AppleVision 850 and 850AV Displays Users Manual.pdf.
  2. ↑ Apple Computer, 20" ColorSync Displays (Service Source), hosted as File:Colorsync 20 displays.pdf. Specifications, physical and electrical, p. 20 (PDF p. 35).
