Apple Lisa DataPower Power Supply Schematic (reverse-engineered)
The Apple X/Lisa "DataPower" Power Supply schematic is a two-sheet drawing of the DataPower supply used in the Apple Lisa and Macintosh XL, revision B, dated 12 January 2002. It was reverse-engineered from the boards; Apple did not issue it. The drawing's own notes say to use it at your own risk.
Contents
  • Sheet 1, the power board (assembly 99P0073-000 rev. J): mains input with a 3 A 250 V fuse, X capacitors C1 and C7 (330 nF), the 470 µF reservoir pair C8 and C9, 115/230 V selection, an LM7805C standby regulator, and the output rectifiers and filter capacitors (C24 4700 µF 6.3 V, C25 1000 µF 50 V, C26 4700 µF 16 V)
  • Sheet 2, the control board (assembly 99P0108-000 rev. C), built round an SG3524 PWM controller
  • Not an Apple document, and not checked against Apple's own drawings. Apple's own Lisa power supply drawing, 050-4011-H, is described at Apple Lisa Schematics.
  • No parts list and no board layout.
Pages that cite this document
Download: Apple Lisa DataPower Power Supply Schematic (reverse-engineered).pdf
