Apple Monochrome Monitor Documentation
Documentation for the Apple Monochrome Monitor (A2M6016): Apple's Technical Procedures, the owner's guide, and Apple's 1988 data sheet for the Apple II monochrome monitors. All three are hosted here and embedded below.
Monochrome Monitor Technical Procedures is the monitor's section of Apple Service Technical Procedures: Apple II Family, Volume Two, part number 072-0229, November 1991 build. The hosted file is 52 pages: the volume's two-page table of contents and the whole section, with pages dated between October 1986 and April 1990.
Contents
  • Section 1, Basics (p. 1.2): product description and the rear controls (H-HOLD, HEIGHT, V-HOLD)
  • Section 2, Take-Apart (pp. 2.2-2.24): rear cover, discharging the CRT (tool 076-0381), anode cap, main logic board with switch case and AC cord, transformer, CRT, fuse, power switch, contrast control, LED assembly, bezel
  • Section 3, Adjustments (pp. 3.3-3.9): safety instructions, set-up with the Apple IIGS Diagnostics diskette, sub-brightness, horizontal hold, focus
  • Section 4, Troubleshooting (pp. 4.2-4.3): symptom chart
  • Section 5, Illustrated Parts List (pp. 5.1-5.9): rear cover, CRT, main logic board and transformers, bezel, other parts
No schematic, component values, voltages or anode figure, and no fuse rating (only part number 740-0308). Apple forbids yoke adjustments on this monitor, so there are none. The CRT safety section the procedures refer to (Section 8 under the binder's "You Oughta Know" tab) is not included.
Download: Apple Monochrome Monitor Technical Procedures.pdf
Owner's guide
Apple Monochrome Monitor Owner's Guide, Apple II series, for the Apple IIc and Apple IIGS, copyright 1986. The hosted scan is 23 pages: setting up (including the detachable cord on 220/240 V models), the controls, the Height-Adjustment bar, cleaning, service and support, and an appendix of specifications.
No service information.
Download: Apple Monochrome Monitor Owner's Guide 1986.pdf
Data sheet
Apple II Monochrome Monitors, Apple data sheet, September 1988, A2F2221/A, four pages. It sets out the specifications of the Apple Monochrome Monitor (A2M6016) beside the green-screen Apple Monochrome Monitor IIe (A2M6017), with ordering information and the Apple Monitor Stand (A2M4029). It is also described on Apple Monitor II Documentation.
Download: Apple II Monochrome Monitors Data Sheet 1988.pdf
Pages that cite these documents
