Atari 1027
| Atari 1027 Letter Quality Printer | |
| Atari 1027 letter quality printer | |
| Manufacturer | Atari, Inc. |
| Type | Letter quality impact printer (type wheel) |
| Release date | Announced June 1983; shipping from autumn 1983[1] |
| Interface | Atari SIO, two I/O connectors[2] |
| Compatible | Atari 8-bit computers[2] |
| Power | External AC adaptor, 9.5 V AC, 40 VA[2][1] |
| Media | 8.5 × 11 inch single sheets[2] |
The Atari 1027 Letter Quality Printer is an 80-column impact printer for the Atari 8-bit computers that prints fully formed characters from a rubber type wheel inked by a roller. Atari announced it at the June 1983 Summer CES and shipped it that autumn.[1] It connects directly to the SIO bus.[2] The FAQ identifies it as a version of the Mannesmann Tally Riteman LQ.[1] In January 1985 Atari announced a 130XE bundle that included the 1027, a 1050 disk drive and AtariWriter.[1]
| Print method | Type wheel and hammer, fully formed characters[2] |
| Pitch | 12 characters per inch, 80 columns (prestige elite)[1] |
| Speed | Averages 10 characters per second (Atari service manual); 20 characters per second (FAQ)[2][1] |
| Paper | Single sheets, 8.5 × 11 inches (service manual); single sheets or roll paper (FAQ)[2][1] |
| Character sets | Standard and international, with underlining[2][3] |
The two speed figures and the two paper statements come from different sources and are given as published. Atari's service manual forbids roll paper, labels and adhesive-backed material, and asks for good quality unlined paper fed one sheet at a time.[2]
[edit | edit source]Atari's 1027 Printer Field Service Manual (FD100670 Rev. 01, October 1983) describes the mechanism and electronics.[2]
Mechanism
[edit | edit source]A DC motor turns the type wheel shaft through an idle gear. When the wanted character faces the hammer, solenoid A (character select) stops the wheel. A wheel select stepper moves the wheel along its shaft by a wire and pulley, and a hammer stepper moves the hammer to match; a cam on the type wheel shaft then fires the hammer and, when a blank is selected, advances the paper through a rubber roller. Photosensors read each character position, the type wheel home position and the hammer home position. The ink roller snaps onto a post in front of the type wheel.[2]
Electronics
[edit | edit source]| Location | Part | Atari part number |
| A1 | 8049 microprocessor, custom, with 2 KB ROM and 128 bytes of RAM | FC100619 |
| A2 | 14050 hex buffer | FC100629 |
| A3 | 74LS09 | FC100632 |
| A4 | 17806P regulator (6 V) | FC100611 |
| A5 | 17805P regulator (5 V) | FC100612 |
| A6 | LB1259 transistor array | FC100630 |
| C1 | 15,000 µF 25 V capacitor | FC100627 |
| D1 | Rectifier | FC100628 |
| XTL1 | 6 MHz crystal | FC100631 |
| IR2 | Ink roll | FC100626 |
| ADP | AC adaptor | FC100623 |
The adaptor is rated 9.5 V at 40 VA. The board rectifies it and regulates two rails: Vc, 5 V ±5 %, for the logic and sensors, and Vp, 6 V ±10 %, for the stepper motors, DC motor and solenoids.[2] The FAQ lists the adaptor as 9.5 V AC, 4.2 A, Atari CO61636.[1] Atari's schematic shows a 5 A fuse inside the adaptor.[2] The LB1259 drives the two steppers with two-phase excitation and clock pulses of about 5 ms; solenoid B (hammer select) takes a pulse of about 10 ms and solenoid A (character select) one of about 8 ms. The power-on reset holds the 8049 for about 100 ms, and the crystal runs at 6 MHz ±0.3 %.[2]
Known faults
[edit | edit source]- The rubber type wheel perishes, going soft and crumbling inside the printer.[4] In 2017 a forum member offered 3D-printed silicone replacement rubbers ("Revive1027"), warning that their print quality was at the limit of what the printing process could resolve.[5]
- Dry ink rollers, which can be re-inked with stamp pad ink.[6]
- Garbled lines when the type wheel loses its alignment, cleared by switching off and on.[3]
The Atari 1027 Maintenance Guide and Atari 1027 Troubleshooting pages cover these in detail. Atari's parts list and schematic give a value only for the main filter capacitor, C1 (15,000 µF 25 V); the other capacitors are shown on the schematic by position only.[2]
[edit | edit source]- Atari 1027 Documentation: the field service manual and owner's guide, with contents.
- 1027 Printer Field Service Manual, FD100670 Rev. 01 (October 1983).
- The Atari 1027 Letter Quality Printer Owner's Guide (1983).
Gallery
The type wheel and ink roller seen through the open cover
[edit | edit source]- Atari 1027 Maintenance Guide
- Atari 1027 Troubleshooting
- Atari 1025
- Atari 1050
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Michael D. Current (ed.), Atari 8-Bit Computers: Frequently Asked Questions, comp.sys.atari.8bit FAQ, last modified 29 November 2009: section 4.2 (the 1020, 1025, 1027 and 1029 printers), section 6.7 (power requirements) and section 11.1 (history, June 1983 to January 1985). faqs.org. Community reference.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 Atari, Inc., 1027 Printer Field Service Manual, FD100670 Rev. 01, October 1983. Theory of operation (pp. 1-1 to 1-10); testing (pp. 2-1 to 2-6); disassembly and preventive maintenance (pp. 3-1 and 3-2); symptom checklist and diagnostic table (pp. 4-1 to 4-3); schematic, silkscreen and parts list (pp. 5-3 to 5-11). Hosted here as File:Atari 1027 Printer Field Service Manual FD100670 Rev 01.pdf.
- ↑ 3.0 3.1 Atari, Inc., The Atari 1027 Letter Quality Printer Owner's Guide (1983): set-up, paper, troubleshooting questions, lubrication and the international character table. Hosted here as File:Atari 1027 Letter Quality Printer Owner's Guide.pdf.
- ↑ "Any cool use for 1027 printers with shattered/dead print wheels?", comp.sys.atari.8bit, posts by John Miskinis and others, 7-14 April 2004. comp.sys.atari.8bit.narkive.com. Community discussion.
- ↑ "\"Revive1027\" Order thread", AtariAge Forums, Atari 8-Bit Computers, 2017. forums.atariage.com. Community project.
- ↑ Phil Rae, "Atariwriter and the 1027", Page 6 no. 16 (July/August 1985), p. 28. page6.org. Magazine article.
