DECpc 325 Troubleshooting Guide
Corrosion from a leaking CMOS battery on a DECpc 325sxLP system board (David Hall, zx.net.nz)
Fault-finding on the DECpc 325 (DECpc 325sxLP) using chapter 7 and appendix C of DEC's DECpc 320sxLP/325sxLP User's Guide (EK-DECSX-UG.003), with repair notes from surviving machines.[1][2]
DEC's troubleshooting sequence
  1. Try a reset: Ctrl+Alt+Del, then the reset button on the front panel.
  2. If the fault remains, switch off, wait 5 seconds and switch on again.
  3. Check for loose cables and connections.
  4. Check the system and monitor indicator lights.
  5. Read any power-up test message and correct the cause, then reset to run the test again.
  6. Work through the fault tables below.
[1]
Setup error messages
Setup error messages (DEC Table 7.1)
Message Meaning Action
Clock chip lost power The clock chip is not working Replace the battery, then check all settings in Setup
CMOS checksum invalid Configuration error Check all settings in Setup
Incorrect configuration data in CMOS Setup does not match the fitted components Check all settings; if the error persists, call service
Memory size in CMOS invalid Wrong base memory setting Correct the base memory field in Setup
Disk C failed initialization Incorrect fixed disk type Correct the disk setting in Setup
Time or date in CMOS is invalid Clock does not match Setup Correct the date or time in Setup
[3]
"Clock chip lost power" on every start means the CMOS battery is flat or disconnected. Check the board around it for corrosion before fitting a new one; see DECpc 325 General Maintenance.[2]
System unit faults
System unit troubleshooting (from DEC Table 7.2)
Problem Possible cause Action
No response at power-on Not plugged in Switch off, plug in, switch on
Power on but no picture Monitor off, brightness and contrast turned down, or cable loose Switch the monitor on, adjust the controls, reseat the cable
Hangs or shows a RAM error with an EtherWORKS adapter fitted Two adapters at the same memory address Move one adapter to another address
Will not start from the hard disk No operating system, partition missing or unformatted, or drive jumpers wrong Install the system, partition and format, check the drive jumpers and terminators
Will not start from a diskette Drive switch set wrongly, no system files, empty drive, worn diskette Check the switch and the diskette
Will not restart after power-off Not off long enough Leave it off for at least 5 seconds
No response to the keyboard Keyboard locked by password, not connected, or plugged into the mouse port Enter the keyboard password; plug the keyboard into the keyboard port
[4]
If the front power button does nothing, check the rubber sleeve between the button linkage and the switch inside the power supply. Hall found it perished on every machine he had seen, leaving the linkage out of line with the switch.[2]
Locked out by the security settings
The User Disk readme warns never to disable booting from both drives and the serial port, because the machine can then only be recovered by DEC field service.[5] Jumper J7 on the system board discharges the CMOS RAM: pins 2 and 3 to discharge, pins 1 and 2 for normal running.[6]
POST beep codes
DEC's BIOS reports errors found before the screen works as beep codes: groups of beeps separated by pauses, so 1-2-1 is one beep, two beeps, one beep. Fatal system board errors beep and halt; non-fatal ones show a message and ask for F1. The code written to I/O port 80h identifies the failing area, including tests that run without a beep code.[7]
Beep codes (DEC Table C.6)
Beep code Port 80h Fault
1-1-3 02h CMOS write/read failure
1-1-4 03h ROM BIOS checksum failure
1-2-1 04h Programmable interval timer failure
1-2-2 05h DMA initialisation failure
1-2-3 06h DMA page register write/read failure
1-3-1 08h RAM refresh verification failure
1-3-3 0Ah First 64K RAM chip or data line failure, multi-bit
1-3-4 0Bh First 64K RAM odd/even logic failure
1-4-1 0Ch Address line failure, first 64K RAM
1-4-2 0Dh Parity failure, first 64K RAM
2-1-1 to 2-4-4 10h to 1Fh Bits 0 to 15 of the first 64K RAM, in order
3-1-1 20h Slave DMA register failure
3-1-2 21h Master DMA register failure
3-1-3 22h Master interrupt mask register failure
3-1-4 23h Slave interrupt mask register failure
3-2-4 27h Keyboard controller test failure
3-3-4 2Bh Screen initialisation failure
3-4-1 2Ch Screen retrace test failure
4-2-1 34h Timer tick interrupt
4-2-2 35h Shutdown test
4-2-3 36h Gate A20 failure
4-2-4 37h Unexpected interrupt in protected mode
4-3-1 38h RAM test or address failure above FFFFh
4-3-3 3Ah Interval timer channel 2
4-3-4 3Bh Time-of-day clock
4-4-1 3Ch Serial port
4-4-2 3Dh Parallel port
4-4-3 3Eh Math coprocessor
Low-1-1-2 41h System board select failure
Low-1-1-3 42h Extended CMOS RAM failure
[8]
"Low" means a lower-pitched beep before the three bursts. In the 2-x-x group, 2-1-1 is bit 0 and 2-4-4 is bit 15; for example 2-1-4 is bit 3.[7][8]
Riser card
The expansion slots are on a riser card. Hall found the tantalum capacitor C3 on one riser blown and replaced the riser with one from a second machine.[2]
Diagnostics
The DECpc 325 User Disk carries DEC's configuration utilities and a set of diagnostic programs named for each subsystem: CPU_DIA, CPR_DIA, MEM_DIA, KBD_DIA, MOU_DIA, FDU_DIA, HDU_DIA, VID_DIA, SER_DIA and PAR_DIA. An image of the disk is on archive.org.[5]
  1. ↑ 1.0 1.1 Digital Equipment Corporation, DECpc 320sxLP/325sxLP User's Guide, EK-DECSX-UG.003, June 1992, pp. 7-1 to 7-2 (File:DECpc 320sxLP 325sxLP User's Guide (EK-DECSX-UG.003).pdf). Troubleshooting sequence and power-on test messages.
  2. ↑ 2.0 2.1 2.2 2.3 David Hall, "Digital DECpc 320sxLP/325sxLP", zxnet, last modified 31 May 2024, zx.net.nz.
  3. ↑ DEC, DECpc 320sxLP/325sxLP User's Guide, EK-DECSX-UG.003, p. 7-3, Table 7.1, "Setup Error Messages".
  4. ↑ DEC, DECpc 320sxLP/325sxLP User's Guide, EK-DECSX-UG.003, pp. 7-4 to 7-5, Table 7.2, "System Unit Troubleshooting".
  5. ↑ 5.0 5.1 Digital Equipment Corporation, DECpc 325 User Disk, version 1.00, file list and README_U.HLP (English section), archive.org.
  6. ↑ Digital Equipment Corporation, DECpc 320sxLP/325sxLP Technical Reference Manual, EK-DECSX-TM-001, March 1992, p. 3-7, Table 3-1 (File:DECpc 320sxLP 325sxLP Technical Reference Manual (EK-DECSX-TM-001).pdf). J7 CMOS discharge.
  7. ↑ 7.0 7.1 DEC, DECpc 320sxLP/325sxLP User's Guide, EK-DECSX-UG.003, p. C-12, section C.4, "Beep Codes".
  8. ↑ 8.0 8.1 DEC, DECpc 320sxLP/325sxLP User's Guide, EK-DECSX-UG.003, pp. C-13 to C-16, Table C.6, "Beep Code List".
