Goldstar GDO-101M Capacitor Replacement Guide
The Goldstar GDO-101M has 48 electrolytic capacitors on four boards: the main board, the power supply board, the CD interface board and the CD drive board. The 3DO Development Repo lists all of them as a common failure on the GDO-101 and GDO-202.[1] The values below are Console5's, read from production boards and listed by board number.[2] GoldStar published no parts list for the console. The power supply values have been checked against a community drawing of the 6870S-263AA board.[3]
Before you start
[edit | edit source]- Unplug the console. The mains goes straight to the transformer, and the POWER switch acts only on the regulators, so the transformer is live whenever the plug is in.[3]
- Note each capacitor's polarity before removing it. Two positions on the drive board are non-polarised.[2]
- Check the board numbers against the headings below. The lists are for the boards Console5 used; other production runs may differ.[2]
Power supply board 6870S-263AA
[edit | edit source]| Console5 ref | Ref on the drawing | Capacitance | Voltage | Position on the drawing |
| C2 | C3 | 4700 µF | 35 V | Reservoir after the bridge DB1, about 18 V |
| C4 | C4 | 1000 µF | 16 V | +12 V output of the PQ12RF2 (IC1) |
| C8 | C9 | 1000 µF | 16 V | +5 V output of the L4960 (IC2) |
| C10 | C10 | 10 µF | 50 V | L4960 soft-start pin 6 |
[2][3] Console5 and the drawing agree on the values but number two of the positions differently: Console5 calls the 4700 µF reservoir C2 and the 5 V output capacitor C8, while the drawing calls them C3 and C9 and uses C2 for a 0.1 µF (104) capacitor across the AC input. Identify the parts by value and position before ordering.[2][3] The L4960's soft-start pin is pin 6.[4]
Main board 6870S-260AA (940914-1)
[edit | edit source]| Ref | Capacitance | Voltage |
| C3, C22, C35, C39, C78, C80, C91, C93, C111, C112, C120, C121, C124, C125, C127 | 100 µF | 16 V |
| C32, C68, C73 | 470 µF | 10 V |
[2] ConsoleMods reports cold-boot faults on the GDO-101M cured by replacing C123, beside the coin cell, with a 22–100 µF capacitor of 16 V or more. C123 is not on Console5's list, so check whether it is fitted on your board.[5][2]
CD interface board 1EA4B11A09900
| C809 | 100 µF | 6.3 V |
| C814 | 470 µF | 16 V |
| C816 | 470 µF | 16 V |
CD drive board 1EA4B11A09800
[edit | edit source]| Ref | Capacitance | Voltage | Notes |
| C401 | 470 µF | 16 V | |
| C403 | 1 µF | 50 V | |
| C404 | 100 µF | 10 V | |
| C501 | 10 µF | 16 V | |
| C504 | 33 µF | 10 V | |
| C507 | 100 µF | 6.3 V | |
| C508 | 100 µF | 10 V | |
| C510 | 33 µF | 10 V | |
| C517 | 100 µF | 10 V | |
| C518 | 10 µF | 16 V | Non-polarised |
| C524 | 100 µF | 10 V | |
| C525 | 100 µF | 10 V | |
| C528 | 0.22 µF | 50 V | Non-polarised, miniature |
| C530 | 100 µF | 10 V | |
| C535 | 0.47 µF | 50 V | |
| C540 | 100 µF | 10 V | |
| C542 | 22 µF | 16 V | |
| C548 | 33 µF | 10 V | |
| C701 | 100 µF | 6.3 V | |
| C707 | 100 µF | 6.3 V | |
| C901 | 470 µF | 16 V | |
| C903 | 470 µF | 16 V | |
| C909 | 100 µF | 16 V |
[2] Console5's kit replaces the miniature 0.22 µF non-polarised capacitor with a ceramic capacitor.[6]
Procedure
[edit | edit source]- Unplug the console and open it. Lift the shield off the top of the drive to reach the drive boards.[7]
- Take out one board at a time. Unplug the drive's flexible cable gently: it is fragile and a common failure in its own right.[8]
- Photograph each board and mark the polarity of every electrolytic before removing it.
- Remove each capacitor, clean the pads of any electrolyte, and fit the new part with the same polarity. Fit C518 and C528 either way round; they are non-polarised.[2]
- Use parts of the same capacitance and at least the same voltage rating, and of the same diameter where space is tight.
- Refit the boards, reconnect every cable and check the supply before playing a disc.
After the recap
[edit | edit source]Measure the supply at the power board's output connector CON3 and compare it with the drawing:[3]
| Point | Expected |
| Reservoir capacitor (4700 µF) | About 18 V |
| CON3 pins 3 and 4 | 11.88 V |
| CON3 pins 5 and 6 | 5.05 V |
| CON3 pin 7 (CTL), console on | 4.80 V |
Then load a game disc and an audio CD. A console that still loops at the logo after a recap usually has a drive cable or microswitch fault; see the Goldstar GDO-101M Troubleshooting Guide.[8]
GDO-101 (Korea)
[edit | edit source]The Korean GDO-101 is the same design with a 220 V, 60 Hz mains rating.[9] archive3do reports that the Korean consoles share the hardware revisions of their export counterparts, so use these lists where the board numbers match those above.[9] Console5's power supply list is for the North American console's 6870S-263AA board, so check the number on the Korean console's power board before ordering.
[edit | edit source]- Goldstar GDO-101M 3DO
- Goldstar GDO-101M General Maintenance
- Goldstar GDO-101M Troubleshooting Guide
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ General Hardware Repair and Maintenance, 3DO Development Repo, 7 November 2022—link(accessed 2026-10-01) Community repair notes: common failures by model and common symptoms.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 Goldstar 3DO, Console5 TechWiki, 15 February 2024—link(accessed 2026-10-01) Capacitor lists for main PCB 6870S-260AA 940914-1, power PCB 6870S-263AA, CD interface PCB 1EA4B11A09900 and CD drive PCB 1EA4B11A09800. Secondary source, compiled from production boards.
- ↑ 3.0 3.1 3.2 3.3 3.4 GoldStar GDO101M 3DO Interactive Multiplayer (NTSC-US region) Power Supply 6870S-263AA (941012-2) 120V/60Hz 30W schematic diagram, one sheet. A community redrawing with measured voltages, from the 3DO Development Repo; not a GoldStar document. Hosted here as File:GoldStar 3DO GDO-101M Power Supply 6870S-263AA Schematic.pdf.
- ↑ STMicroelectronics, L4960 2.5A Power Switching Regulator, datasheet, farnell.com. Pin 6 is the soft-start terminal.
- ↑ 3DO:General Troubleshooting, ConsoleMods Wiki, 10 May 2026—link(accessed 2026-10-01) Section "Reboot Loop".
- ↑ Goldstar 3DO Cap Kit, Console5—link(accessed 2026-10-01) Note on the 0.22 µF non-polar capacitor on the CD-ROM board.
- ↑ Quick Fix: Goldstar 3DO CD Drive Tray Not Staying Closed, SgtMo—link(accessed 2026-10-01) Repair account: tray closes then reopens; fixed by bending the close-detect tab.
- ↑ 8.0 8.1 3DO:Sanyo Disc Drive Repair, ConsoleMods Wiki, 25 June 2025—link(accessed 2026-10-01) Community repair guide for the Sanyo drive used in the GoldStar models and the Sanyo IMP-21J.
- ↑ 9.0 9.1 Korean Retail, archive3do.com—link(accessed 2026-10-01) Photographs of the GDO-101 Alive and GDO-203 Alive II, including their rating plates.
